Interim Update? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Interim Update? (/thread-3922.html) |
Interim Update? - Helge Gabert - 05-20-2015 02:35 PM Tim and others from the HP Team, I'd like to know if it would be possible to issue an interim update. The NaN display bug preventing the user from editing/storing complex numbers with the matrix editor in M1..M9 and M0, as well as with EDITMAT (variable_name), is truly annoying. Thanks for your consideration! RE: Interim Update? - salvomic - 05-20-2015 02:56 PM (05-20-2015 02:35 PM)Helge Gabert Wrote: Tim and others from the HP Team, I agree. I appreciate very much the effort and good job of the Team, but this, the bug of Define and few others sure deserve an interim release. If I could help you, sure I'll work hard to help, but I don't know what to do for you, but a beta tester... The rest of the new FW is wonderful, impressive! Thank you Salvo RE: Interim Update? - Michael de Estrada - 05-20-2015 07:32 PM And I thought it was just me that had a problem with Define. The annoying thing is that it often does a sudden reboot / reset, losing all work done since the last normal power off. |
