HP 110 Portable Plus Lattice C - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: Classifieds (/forum-6.html) +--- Thread: HP 110 Portable Plus Lattice C (/thread-400.html) |
HP 110 Portable Plus Lattice C - Michael Fehlhammer - 01-11-2014 12:16 PM I would like to acquire the Lattice C disks for the HP 110 Plus; a copy would do as well. Of course a manual would be nice, but there is a download source, so it's not mandatory. By the way: I am interested in other software or hardware ( like the Ram Drawer ) for that laptop as well. RE: HP 110 Portable Plus Lattice C - Ordins - 06-29-2014 01:11 PM Hello, did you get an answer? I am also interested in the Lattice C Compiler. thank you RE: HP 110 Portable Plus Lattice C - Dave Frederickson - 06-29-2014 04:10 PM I believe the Lattice C disks have proven to be elusive. However, Lattice C Personal 1.0(J) can be found here. The Small C Interpreter is on the Portable Paper 1988 Subscriber's Disk. Dave RE: HP 110 Portable Plus Lattice C - HP67 - 06-29-2014 05:10 PM Is this something specific to the 110 or will any copy of Lattice C for DOS work? RE: HP 110 Portable Plus Lattice C - Dave Frederickson - 06-29-2014 05:54 PM The HP Portables aren't 100% DOS compatible, so some programs run and some don't. Lattice C Compiler 45452D is the product that is compatible with the Portable PLUS. Ed. According to the Nov-Dec 1988 issue of the Portable Paper, Turbo C 1.5 runs well on the Portable PLUS. Dave RE: HP 110 Portable Plus Lattice C - HP67 - 06-29-2014 06:45 PM I probably have a regular DOS version around somewhere. A few years ago I went on a DOS software collecting spree. If anybody wants it badly enough to try to test it or possibly fix it let me know and I'll go looking. Some releases of Turbo C were available on Borland's museum for free since they're so old. I got a bunch of those also. I do not know which versions. I had a disk problem and lost a lot of what I had found but there should still be quite a bit left. Here's the link to Borland. It looks like it's still up. http://edn.embarcadero.com/museum/ By the way AFAIK you do not need product codes or licenses for any of the freebies Borland/Embarcadero is giving away. The download notes say you need to get a registration code but someone from Borland (back then when they first put this stuff up for grabs) noted that isn't correct and everything will work without a license code. RE: HP 110 Portable Plus Lattice C - Dave Frederickson - 06-29-2014 07:00 PM I'll take you up on the offer. Thanks. ![]() Dave RE: HP 110 Portable Plus Lattice C - Massimo Gnerucci - 06-29-2014 07:24 PM (06-29-2014 05:54 PM)Dave Frederickson Wrote: The HP Portables aren't 100% DOS compatible, so some programs run and some don't. Lattice C Compiler 45452D is the product that is compatible with the Portable PLUS. Here you go. ![]() RE: HP 110 Portable Plus Lattice C - Michael Fehlhammer - 07-03-2014 11:58 PM Thank you Massimo and Dave for your hints and help concerning TC 1.5 and the Portable Plus! @ Ordins: Unfortunately no good news about Lattice C for the PP. RE: HP 110 Portable Plus Lattice C - Sylvain Cote - 07-04-2014 01:44 AM (06-29-2014 05:54 PM)Dave Frederickson Wrote: The HP Portables aren't 100% DOS compatible, so some programs run and some don't. Lattice C Compiler 45452D is the product that is compatible with the Portable PLUS. I wonder if Microsoft C v1.0 & 2.0 compilers released in 1983/84 would also run on the HP-110/110+. Those versions were based on the lattice C compiler. Sylvain RE: HP 110 Portable Plus Lattice C - Massimo Gnerucci - 07-04-2014 05:45 AM (07-04-2014 01:44 AM)Sylvain Cote Wrote:(06-29-2014 05:54 PM)Dave Frederickson Wrote: The HP Portables aren't 100% DOS compatible, so some programs run and some don't. Lattice C Compiler 45452D is the product that is compatible with the Portable PLUS. Why not give it a try? |
