[WP 34s] Trapezoidal approximation of area under curve - Printable Version
+--- Thread: [WP 34s] Trapezoidal approximation of area under curve (/thread-4047.html)
[WP 34s] Trapezoidal approximation of area under curve - Marcio - 06-01-2015 01:53 PM
Hello all,
Is it possible to have access to data keyed into the calc using the \(\sum +\) for other procedures other than stat functions? If so, I am planning on creating a program that would take advantage of that so it would be possible to easily calculate the area under a curve defined by data, as shown below:
\[ \int_{x_1}^{x_n} y(x) dx \approx \frac{1}{2} \sum_{k=1}^{n-1} (x_{k+1}-x_{k})(y_{k+1}+y_{k}) \]
Many thanks
Marcio
RE: [WP 34s] Trapezoidal approximation of area under curve - Marcus von Cube - 06-01-2015 03:54 PM
(06-01-2015 01:53 PM)Marcio Wrote:  Is it possible to have access to data keyed into the calc using the \(\sum +\) for other procedures other than stat functions?
The SUMS catalog has all the accumulated data ready for access. All commands in this catalog are programmable.
RE: [WP 34s] Trapezoidal approximation of area under curve - Dave Britten - 06-01-2015 05:36 PM
The problem is that the trapezoidal approximation appears to require the individual data points, and not just the sums. You'll probably have to write a custom program that accumulates its own sums, either on the fly, or by using a block of registers to store x and y data points.
RE: [WP 34s] Trapezoidal approximation of area under curve - Thomas Klemm - 06-01-2015 06:56 PM
(06-01-2015 01:53 PM)Marcio Wrote:  If so, I am planning on creating a program that would take advantage of that so it would be possible to easily calculate the area under a curve defined by data, as shown below:
You could use something like:
001 LBL'TPZ'
002 CLΣ
003 LBL 00
004 STOP
005 R↑
006 RCL+ Z
007 R↑
008 RCL- Z
009 Σ+
010 R↓
011 R↓
012 GTO 00
013 END
Usage:
\(y_1\) ENTER \(x_1\) XEQ'TPZ'
\(y_2\) ENTER \(x_2\) R/S
\(y_n\) ENTER \(x_n\) R/S
Σxy
-2 ÷
Not a sophisticated program but I hope you get the idea.
RE: [WP 34s] Trapezoidal approximation of area under curve - Marcio - 06-02-2015 02:46 AM
Works like a charm.
Thank you
RE: [WP 34s] Trapezoidal approximation of area under curve - Dieter - 06-02-2015 09:23 PM
(06-01-2015 06:56 PM)Thomas Klemm Wrote:  Not a sophisticated program but I hope you get the idea.
A bit of sophistication can be added by using the 34s' complex functions:
01 LBL"TRP"
02 CLΣ
03 CLSTK
04 STOP
05 LBL 01
06 STOP
07 cplx x<> Z
08 +/-
09 cplx RCL+ Z
10 Σ+
11 cplx DROP
12 GTO 01
XEQ"TRP"
y1 ENTER x1 R/S
y2 ENTER x2 R/S
Σxy 2 ÷
Dieter
RE: [WP 34s] Trapezoidal approximation of area under curve - Marcio - 06-16-2015 10:47 AM
Hello again,
Does anyone know how to do \(RCL+ Z\) on the 35s? From what I saw in the manual, one has to use the EQN inside the program in order to recall the \(z\)-register, which is somewhat dangerous.
Thanks.
RE: [WP 34s] Trapezoidal approximation of area under curve - Dieter - 06-16-2015 11:31 AM
(06-16-2015 10:47 AM)Marcio Wrote:  Does anyone know how to do \(RCL+ Z\) on the 35s?
Yes. You can't. Recall-arithmetics is not available for the stack registers.
Of course you can do a RCL+Z with variable Z, but that's a completely different story.
Dieter
RE: [WP 34s] Trapezoidal approximation of area under curve - Thomas Klemm - 06-16-2015 12:38 PM
You can use the following program:
T001 LBL T
T002 CLΣ
T003 STOP
T004 REGY+REGT
T005 REGY-REGT
T006 Σ+
T007 R↓
T008 R↓
T009 GTO T003
Usage:
\(y_1\) ENTER \(x_1\) XEQ T
Σxy
2 ÷
RE: [WP 34s] Trapezoidal approximation of area under curve - Marcio - 06-16-2015 12:57 PM
Thank you Thomas.
I myself created a program with more than 2 times as many lines as yours, which is not only simpler but also much more elegant.
Very much appreciated.
Marcio
