(49G) Infinite Precision Integer to Infinite Precision Hexadecimal String & Back - Printable Version
+--- Forum: General Software Library (/forum-13.html)
+--- Thread: (49G) Infinite Precision Integer to Infinite Precision Hexadecimal String & Back (/thread-4065.html)
(49G) Infinite Precision Integer to Infinite Precision Hexadecimal String & Back - Gerald H - 06-03-2015 05:22 PM
The programme takes an integer from the stack & returns a hexadecimal string of the same value.
eg For
88^88
otherwise known as
13015928349429720551826483074173153645387250759600678279153114847224523409663172​15805106820959190833309704934346517741237438752456673499160125624414995891111204​155079786496
the programme returns
# 0h
Well that's how it's displayed, as internally it's
HXS 00090 00000000000000000000000000000000000000000000000000000000000000000012963E64070DC5​067631DBD7DFC91FF0C596AB955B4B773D6D0FE8343051A0A7DE54C9933E8510
& all the lowest hex values are zero. However if you apply ->H to the result you will see how the number is stored internally, so it is really there.
Given this result as input the programme returns the original integer.
  CK1&Dispatch
  # FF
    FPTR2 ^DupQIsZero?
    casedrop
    HXS 00001 0
    FPTR2 ^Z>ZH
    # 2A4E
    CHANGETYPE
  BINT11
    # 2614
    CHANGETYPE
    DO>STR
    Z0_
    SWAP
    DUPLEN$
    #1+_ONE_DO
    DUPINDEX@
    SUB$1#
    BINT48
    FPTR2 ^#>Z
    ROT
    ZINT 16
    FPTR2 ^RMULText
    FPTR2 ^RADDext
    SWAPLOOP
    DROP
