Picture and Input - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Picture and Input (/thread-4084.html) |
Picture and Input - Heino - 06-05-2015 03:19 PM How can I created a Picture with an Input-Funktion? EXPORT kor() BEGIN Local x; RECT_P(); //Linie und Pfeil in x-Richtung LINE_P(40,59,79,59,RGB(0,255,0)); LINE_P(40,60,80,60,RGB(0,255,0)); LINE_P(40,61,79,61,RGB(0,255,0)); LINE_P(80,60,73,57,RGB(0,255,0)); LINE_P(80,60,73,63,RGB(0,255,0)); Textout_P("X",85,55,2); //Linie und Pfeil in y-Ricjhtung LINE_P(39,60,39,21,RGB(255,0,0)); LINE_P(40,60,40,20,RGB(255,0,0)); LINE_P(41,60,41,21,RGB(255,0,0)); LINE_P(40,20,37,26,RGB(255,0,0)); LINE_P(40,20,43,26,RGB(255,0,0)); Textout_P("Y",37,5,2); //Linie und Pfeil in z-Richtung LINE_P(39,60,20,79,RGB(0,0,255)); LINE_P(40,60,20,80,RGB(0,0,255)); LINE_P(41,60,21,80,RGB(0,0,255)); LINE_P(20,80,22,73,RGB(0,0,255)); LINE_P(20,80,27,77,RGB(0,0,255)); Textout_P("Z",10,85,2); FREEZE; END; [/b] RE: Picture and Input - DrD - 06-05-2015 07:36 PM There are several ways. Here is one way using reserved variables M1 and X. (Your input is through the editmat(M1) function): Code:
RE: Picture and Input - Heino - 06-06-2015 10:00 AM Hello DrD, thanks for your answer. That is not what i mean. i mean this on (look Picture). RE: Picture and Input - DrD - 06-06-2015 12:39 PM I see what you're after, and I don't know how to do that. It may be possible to save the graphic object in a variable, and use that as a label for the input statement. I haven't tried that... RE: Picture and Input - salvomic - 06-06-2015 01:25 PM (06-06-2015 12:39 PM)DrD Wrote: I see what you're after, and I don't know how to do that. It may be possible to save the graphic object in a variable, and use that as a label for the input statement. I haven't tried that... sorry for OT, but in another post I wrote about labels in input, wondering how to get them without use a text field. I wasn't able to get such a label, however. Do you know how is it syntax, please? Thank you, Salvo RE: Picture and Input - DrD - 06-06-2015 05:05 PM The essence of it would be to use the GETPIX_P() to save the contents of your graphic rectangle (in a list or matrix), and then use PIXON_P() to replicate it on the graphic screen. You would PIXON the image just prior to the INPUT. A foreseeable problem is that I don't know what graphics screen the input command uses, but I think I inadvertently did just that very thing, when I was working with my Smith Chart program several months ago. In that case, it was an unintended effect. I didn't want to have the overlay graphic on the input screen! I don't remember the how's and why's, but if it happens again, I'll make note of it. I don't think the Prime is able to do that normally, it was several rev's ago, and may have been a bug that just happened to have that result. It would be a nice feature, though, especially considering the geographical value. |
