42S for $28USD - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: 42S for $28USD (/thread-4090.html) |
42S for $28USD - Dave Frederickson - 06-05-2015 11:35 PM I just snagged a 42S for just under $28USD on eBay. Was it a good deal? Stay tuned. RE: 42S for $28USD - vk6ti - 06-06-2015 01:09 AM Good luck, I had a similar 42S score when the previous custodian didn't have batteries to "turn it on ", sell as is. I was lucky that the calculator was all fine, but for that price it is worth the risk, and anticipation Ray RE: 42S for $28USD - Dave Britten - 06-06-2015 09:23 PM You might luck out like I did with my really cheap 32S with manual. It was listed as non-working, and arrived as advertised, but it turned out to be nothing more than a stuck/inverted key dome. A couple minutes with an x-acto knife to make a tiny incision releasing the pressure, and it was right as rain. The 1 key feels a tiny bit softer than the rest now, but it never sticks or misses. RE: 42S for $28USD - aurelio - 06-18-2015 07:04 PM (06-05-2015 11:35 PM)Dave Frederickson Wrote: I just snagged a 42S for just under $28USD on eBay. Was it a good deal? Stay tuned. Dave, Lucky man, how are you my friend? any newS about your lucky purchase? RE: 42S for $28USD - Dave Frederickson - 06-18-2015 07:50 PM (06-18-2015 07:04 PM)aurelio Wrote: Dave, Lucky man, how are you my friend? Hello Aurelio, I am doing well, and you? I've opened the case and removed and reinstalled the PCB. If I flex the calculator I can get the Memory Lost display. I suspect a bad solder connection somewhere. I'll need to put it under the microscope and do and inspection. The seller reported that he was able to run the self-test and received a URAM failure. If that's the case then I'll replace the RAM with a 32K chip. Anybody have a part number? Dave RE: 42S for $28USD - ElectroDuende - 06-18-2015 09:07 PM (06-18-2015 07:50 PM)Dave Frederickson Wrote: I've opened the case and removed and reinstalled the PCB. If I flex the calculator I can get the Memory Lost display. I suspect a bad solder connection somewhere. I'll need to put it under the microscope and do and inspection. The seller reported that he was able to run the self-test and received a URAM failure. If that's the case then I'll replace the RAM with a 32K chip. Anybody have a part number? I think that URAM refers to video ram (when it is tested screen shows "noise"), and as far as I know, that forms part of the main CPU, so changing main RAM won't solve the problem. Anyway, I hope it is just a bad soldering and you make it work. RE: 42S for $28USD - rprosperi - 06-19-2015 11:31 PM (06-18-2015 07:50 PM)Dave Frederickson Wrote: Anybody have a part number? Lots of 42S RAM info here RE: 42S for $28USD - aurelio - 06-20-2015 04:11 PM (06-18-2015 07:50 PM)Dave Frederickson Wrote:hello Dave what a big job you are doing (at least up to me)!!(06-18-2015 07:04 PM)aurelio Wrote: Dave, Lucky man, how are you my friend? I always met trouble opening the case of a pioneer the HP 48sx I opened became a spare parts source, with the 32sii I succed in repairing but I was all the time afraid to broken it, expecially drilling the case I feel well except for a few problems on both the hands (the carpal tunnel sydrome....... on the left one surgery at he beginning of this year) and the last present of my age, a new entry just this week, a problem with the right shoulder.. How much I would like to be back to the time when I was just twenty years old ...................I could also let for it my entire collection of HP calculators ...and more |
