Astronomy... - Printable Version
+--- Thread: Astronomy... (/thread-4195.html)
Astronomy... - salvomic - 06-20-2015 05:53 PM
hi everybody,
waiting for the evolution of the very interesting app by Marcel (I'm already using!), I'm developing also this program to get astronomical results for Sun, Moon and Planets...
Effemeridi (Astrolabio) is a program that I'm adapted from an old version I made many years ago for a TI pocket calculator.
The program has still some incorrect output (very few), so I'm glad to have your advice and hints to improve it, thank you.
The program calculates Sidereal Time, Longitude, Latitude (various coordinates), Rect Ascension and Declination, Azimuth and Height, phases of the Moon, Retrogradation of planets, Ascendent, after a book of S. Bouiges...
I'm working to add eclipses, and improving program also in "astrological" sense (I was asked for this) and Satellites of Jupiter and Saturn.
Also data for Pluto are still not so precise as those in the app of Marcel...
Some routines and data are still in Italian, sorry.
I need your help, please, test, and thank you in advance!
Salvo
The code (I'll post here the new versions for now):
data();
calcN();
calcTS();
sunCalc();
planetCalc();
planets();
sun();
moon();
Mercurius();
Venus();
Mars();
Jupiter();
Saturn();
Uranus();
Neptunus();
Pluto();
ascendent();
zodiaco();
trunc_angle();
atan2();
thisday:= 2000.0101;
lstd:=0; gmt:= 12;
long:= 0; lat:=  0;
m:= 1; dst:= 0; utc:=0;
sunlist:= MAKELIST(X,X,1,25);
planet_const:= MAKELIST(X,X,1,10);
ε:= →HMS(23.4392911);  // approx 23.45
EXPORT Effemeridi()
// from "Astrolabio ed Effemeridi", by Salvo Micciché, salvomic, 2015
// Credits: from a book, Calcule astronomique pour amateurs, by Serge Bouiges
// Thanks Didier Lachieze, Marcel, Eried
  LOCAL ch;
  HAngle:=1;
  data(); // input data and calc Sun
  CHOOSE(ch, "Effemeridi", "Sun", "Moon", "Planets", "Calc N", "Calc TS", "Ascendent", "Quit");
  CASE
  IF ch==1 THEN sun(); END;
  IF ch==2 THEN moon(); END;
  IF ch==3 THEN planets(); END;
  IF ch==4 THEN calcN(); END;
  IF ch==5 THEN calcTS(); END;
  IF ch==6 THEN ascendent(); END;
  IF ch==7 THEN HAngle:=0; RETURN; END;
  DEFAULT
  END; // case
data()
  LOCAL dd, mm, yy, hh, mn, ss, loct;
  yy:= IP(Date);
  mm:= IP(FP(Date)*100);
  dd:= FP(Date*100)*100;
  hh:= IP(HMS→(Time));
  mn:= IP(FP(HMS→(Time))*60);
  ss:= IP(FP(FP(FP(HMS→(Time))*60))*60);
  loct:= →HMS(hh+mn/60+ss/3600);
  INPUT({ {m,[0],{15,15,1}}, {D,[0],{50,15,1}}, {Y,[0],{80,15,1}},
  {lstd,[0],{65,30,2}},
  {dst,0,{40,15,3}}, {utc,[0],{80,15,3}},
  {long,[0],{20,25,4}},
  {lat,[0],{70,25,4}} },
  "Data: Use Shift+9 for H°M′S″",
  {"Month:","Day :","Year :","Local Time (24):", "DST", "GMT",
  "Long (-E):","Lat (+N)"},
  {"Enter month", "Enter day", "Enter year (1901-2099)",
  "Enter local time (decimal or H°M′S″)", "Daylight Save Time?", "UTC lag",
  "Longitude", "Latitude"},
  {1,1,1901,0, 0,0, 0, 0},{mm,dd,yy,loct, 0, 1, -14°43′41″, 36°55′15″});
  // Ragusa (-14°43′41″, 36°55′15″) -
  // Marina di Ragusa (-14°33′15″, 36°47′06″) - Scicli (-14°42'22″, 36°47' 22″)
  D:=EVAL(D); m:=EVAL(m); Y:=EVAL(Y);
  lstd:= lstd;
  // Greenwich Mean Time
  gmt:= lstd-utc-(1*dst); // UTC (DST, daylight save time)
  thisday:= Y+m/100+D/10000;
  sunCalc(); // calculate Sun data
planets()
  LOCAL ch, nameplanet;
  INPUT({{ch,{"Mercurius","Venus","Mars", "Jupiter", "Saturn", "Uranus", "Neptunus", "Pluto"}, {20,30,1}}},
  "Choose planet",
  "planet: ", "Choose the planet to calculate an press OK", 0,5 );
  CASE
  IF ch==1 THEN nameplanet:="Mercurius"; planetCalc(nameplanet); END;
  IF ch==2 THEN nameplanet:="Venus"; planetCalc(nameplanet); END;
  IF ch==3 THEN nameplanet:="Mars"; planetCalc(nameplanet); END;
  IF ch==4 THEN nameplanet:="Jupiter"; planetCalc(nameplanet); END;
  IF ch==5 THEN nameplanet:="Saturn"; planetCalc(nameplanet); END;
  IF ch==6 THEN nameplanet:="Uranus"; planetCalc(nameplanet); END;
  IF ch==7 THEN nameplanet:="Neptunus"; planetCalc(nameplanet); END;
  IF ch==8 THEN nameplanet:="Pluto"; planetCalc(nameplanet); END;
  DEFAULT
  END; // case
calcN()
  N:= DDAYS(1901.0101, thisday)+1+gmt/24; // N to GMT
  RETURN N;
calcTS()
  LOCAL TS, TSd, N0, TSL;
  calcN();
  N0:= DDAYS(1901.0101, thisday)+1+0; // N at 0 GMT (for TS)
  TS:= ((23750.3 + 236.555362*(N0+gmt/24)) / 3600) MOD 24; // Sideral Time (GMT) in seconds
  TS:= →HMS(TS); // in HMS
  TSL:= (((23750.3 + 236.555362*N+lstd/24) / 3600) MOD 24); // local ST
  TSL:= (TSL + gmt - 4*(HMS→(long))/60) MOD 24;
  TSL:= →HMS(TSL); // in HMS
  TSd:= →HMS((98.965 + 0.985647342*N0) MOD 360); // ST at 0 GMT in degrees
  RETURN {TS, TSL, TSd, gmt};
ascendent()
  LOCAL ASC, ts, segno;
  ts:= calcTS();
  ASC:= atan2(-cos(ts(2)), sin(ts(2))*cos(ε)+tan(lat)*sin(ε));
  IF ASC<0 THEN ASC:= ASC+360; END; IF ASC>360 THEN ASC:=ASC-360; END;
  segno:= zodiaco(ASC);
RETURN {→HMS(ASC), segno};
zodiaco(astro)
  LOCAL segno;
  CASE  // Segni e case
  IF astro>=0   AND astro <30  THEN segno:="Ariete"; END;
  IF astro>=30  AND astro <60  THEN segno:="Toro"; END;
  IF astro>=60  AND astro <90  THEN segno:="Gemelli"; END;
  IF astro>=90  AND astro <120 THEN segno:="Cancro"; END;
  IF astro>=120 AND astro <150 THEN segno:="Leone"; END;
  IF astro>=150 AND astro <180 THEN segno:="Vergine"; END;
  IF astro>=180 AND astro <210 THEN segno:="Bilancia"; END;
  IF astro>=210 AND astro <240 THEN segno:="Scorpione"; END;
  IF astro>=240 AND astro <270 THEN segno:="Sagittario"; END;
  IF astro>=270 AND astro <300 THEN segno:="Capricorno"; END;
  IF astro>=300 AND astro <330 THEN segno:="Acquario"; END;
  IF astro>=330 AND astro <360 THEN segno:="Pesci"; END;
  END; // case
  RETURN segno;
atan2(y,x)
// atan2 returns coordinates in correct angle for all four quadrants (DEG)
  CASE
    IF x==0 AND y==0 then return "undefined"; end;         // x=0, y=0
    IF x>0 then return atan(y/x); end;                     // x>0
    IF x<0 AND y>=0 then return atan(y/x)+180; end;         // x<0, y>=0
    IF x==0 AND y>0 then return 90; end;                 // x=0, y>0
    IF x<0 AND y<=0 then return atan(y/x)-180; end;         // x<0, y<0
    IF x==0 AND y<0 then return -90; end;                // x=0, y<0
  RETURN;
trunc_angle(ang)
// trunc decimal from a DEG form angle
→HMS((IP(HMS→(ang)*3600)/3600));
sunCalc()
  LOCAL ω, l, v, r, x, y, dz;
  LOCAL α, δ, dayY, H, ts, az, z, h;
  LOCAL SAD, DA, sorg, tram, culm, Hd, lt;
  LOCAL as, ac, zc;
  calcN();
  L:= →HMS((278.965+0.985647342*N)) MOD 360; // long media
  ω:= →HMS((281.235 + 0.0000469*N)) MOD 360; // long del perielio
  M:= (L - ω); // anomalia vera
  v:= M + 1.91934 * sin(M)+0.02*sin(2*M); // calcolo intermedio
  l:= v + ω; // Longitudine Sole
  lt:= l + 180; // Longitudine eliocentrica della Terra
  r:= ((0.999721)/(1+0.01675*cos(v))); // Distanza Sole-Terra (UA)
  x:= r * cos(l); y:= r * sin(l);
  dayY:= DDAYS(IP(thisday)+1/100+1/10000, thisday); // calc day number
  // δ:= →HMS((ε*sin((360*(284+dayY))/365)) MOD 360); // declinazione, formula di Cooper
  δ:= →HMS((asin(sin(ε)*sin(l))) );
  // α:= →HMS((acos(cos(l)/cos(δ))/15) MOD 24); // ascensione retta
  α:= (acos(cos(IFTE(l>180, l-180, l))/cos(δ))); // ascensione retta
  IF l>180 THEN α:= α +180; END;
  α:= →HMS(α/15) MOD 24; // α in hms
  ts:= calcTS();  // calcola tempo siderale
  H:= (ts(2) - α) MOD 24; // Angolo orario
  Hd:= →HMS(15*H); // Angolo orario in gradi
  zc:= sin(lat)*sin(δ)+cos(lat)*cos(δ)*cos(Hd); // calc z, alt
  dz:= →HMS(acos(zc)) ; // distanza zenitale
  // alt:= →HMS(90 - z); // Altezza
  h:= →HMS(ATAN(zc/sqrt(1-zc^2))); // Altezza
  // as:= cos(δ)*sin(Hd)/sin(dz); // calc az
  // ac:= (-cos(lat)*sin(δ)+sin(lat)*cos(δ)*cos(Hd))/sin(dz);
  // az:= →HMS(ATAN(as/ac) ); // Azimuth
  // IF (ac<0) THEN az:= (360 + az) MOD 360; END;
  az:= atan2((-cos(δ) * sin(Hd)), cos(lat) *sin(δ)-sin(lat)*cos(δ)*cos(Hd));
  IF az<0 THEN az:= az+360; END; IF az>360 THEN az:=az-360; END;
  IF (az<0) THEN az:= 360+az; END;
  E:= →HMS((460*sin(M)-592*sin(2*L))/60); // equazione del tempo in min (460s, 592s)
  DA:= asin(tan(lat)*tan(δ)); // Differenza ascensionale
  SAD:= (90 + DA); // Semiarco Diurno
  // SAD:= →HMS(acos(-tan(lat)*tan(δ))); // Semiarco Diurno
  culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) ; // Culminazione
  sorg:= (culm - SAD/15) MOD 24; // Alba (Dawn)
  tram:= (culm + SAD/15) MOD 24; // Tramonto (Sunset)
  sunlist:= {L,ω,l, M, α,δ, az, h, x,y,sorg, tram, culm, r, H, Hd, zc, dz, ts(1), DA, SAD, E, lt};
  RETURN sunlist;
sun()
  LOCAL as, ac, zc, segno;
  L:= sunlist(1); ω:= sunlist(2);
  l:= sunlist(3); M:= sunlist(4);
  α:= sunlist(5); δ:= sunlist(6);
  az:= sunlist(7); h:= sunlist(8);
  x:= sunlist(9); y:= sunlist(10);
  sorg:= sunlist(11); tram:= sunlist(12); culm:= sunlist(13);
  r:= sunlist(14); H:= sunlist(15); Hd:= sunlist(16);
  zc:= sunlist(17); dz:= sunlist(18);
  ts:= calcTS(); // no 19
  DA:= sunlist(20); SAD:= sunlist(21); E:= sunlist(22); lt:= sunlist(23);
  segno:= zodiaco(l);
  PRINT;
  PRINT("Effemeridi del Sole a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("");
  PRINT("L longitudine media " + trunc_angle(L));
  PRINT("ω long del perielio " + trunc_angle(ω));
  PRINT("M anomalia vera " + trunc_angle(M));
  PRINT("λ longitudine Sole " + trunc_angle(l) + " " + segno);
  PRINT("r Distanza (UA) " + r);
  PRINT("α Asc. r. "+ trunc_angle(α) + " δ Decl. "+ trunc_angle(δ));
  PRINT("Az Azimuth " + trunc_angle(az) + " h Alt. " + trunc_angle(h));
  PRINT(" ");
  PRINT("Ang. orario "+ H + " " + trunc_angle(Hd));
  PRINT("TS (UTC) " + trunc_angle(ts(1)));
  PRINT("TS locale " + trunc_angle(ts(2)));
  PRINT("Equazione del tempo (min) " + trunc_angle(E));
  PRINT("Dif asc." + DA + " SAD " + trunc_angle(SAD));
  PRINT("");
  PRINT("Culmina a: " + trunc_angle(culm) + " UTC");
  PRINT("Sorge a: " + trunc_angle(sorg) + " UTC");
  PRINT("Tramonta a: " + trunc_angle(tram) + " UTC");
  PRINT("Long elioc. Terra "+ trunc_angle(lt));
  // RETURN {L, ω, M, v, l, r, x, y};
  RETURN [[L, ω], [l, M], [α,δ], [az, h], [x,y], [sorg, tram], [culm, r], [H,ts(1)]];
moon()
  LOCAL ω,Ω, l, v, r, x, y, i;
  LOCAL Ls, Ms, LongM, LatM, P, d, s;
  LOCAL α,δ, ts, Hd, zc, dz, h, az;
  LOCAL as, ac, DA, SAD, DD, culm, sorg, tram;
  LOCAL b, dayY, xs, ys, ph, fase, eta;
  LOCAL dd, hh, mm, segno;
  i:= 5.13333333; // inclinazione 5°8' sull'eclittica
  calcN();
  // Sun
  Ls:= sunlist(1); // Longitudine media
  Ms:= sunlist(4); // Anomalia
  // end Sun
  L:= (33.231 + 13.17639653*N) MOD 360; // long. media
  Ω:= (239.882 - 0.052953922*N) MOD 360; // Long nodo ascendente
  M:= (18.294 + 13.06499245*N) MOD 360; // anomalia vera
  ω:= (L - M) MOD 360; // perigeo medio
  DD:= L - Ls; F:= L-Ω; // for the variations
  LongM:= L + 6.28875 * sin(M); // calculus (h/ and above) of Moon longitude
  LongM:= LongM + 0.2136 * sin(2*M); // equazione del centro
  LongM:= LongM + 0.6583 * sin(2*DD); // variazione
  LongM:= LongM - 0.1856 * sin(Ms); // equazione annuale
  LongM:= LongM + 1.2740 * sin(2*DD-M); // evezione
  LongM:= LongM - 0.1143 * sin(2*F); // riduzione all'eclittica
  LongM:= LongM + 0.0588 * sin(2*DD-2*M);
  LongM:= LongM + 0.0572 * sin(2*DD-M-Ms);
  LongM:= LongM + 0.0533 * sin(2*DD+M);
  LongM:= LongM + 0.0459 * sin(2*DD-Ms);
  LongM:= LongM + 0.0410 * sin(M-Ms);
  LongM:= LongM - 0.0305 * sin(M+Ms);
  LongM:= LongM - 0.0348 * sin(DD);
  LongM:= LongM MOD 360;
  LatM := 5.1280 * sin(F); // termine principale
  LatM := LatM + 0.2806 * sin(M+F);
  LatM := LatM + 0.2777 * sin(M-F); // equazione del centro
  LatM := LatM + 0.1732 * sin(2*DD-F); // grande ineguaglianza
  LatM := LatM + 0.0554 * sin(2*DD-M+F); // evezione
  LatM := LatM + 0.0462 * sin(2*DD-M-F); // evezione (2)
  LatM := LatM + 0.0326 * sin(2*DD+F);
  LatM := LatM MOD 360;
b:= LatM;
  δ:= →HMS((asin(cos(ε)*sin(b)+sin(ε)*cos(b)*sin(LongM))) ); // declinazione (coord locali)
  // α:= →HMS((acos(cos(b)*cos(LongM)/cos(δ))/15) MOD 24); // ascensione retta
  α:= (acos(cos(b)*cos(IFTE(LongM>180, LongM-180, LongM))/cos(δ))); // ascensione retta
  IF LongM>180 THEN α:= α +180; END;
  dz:= →HMS(acos(zc)) ; // distanza zenitale :: h:= →HMS(90 - dz); // Altezza
  h:= →HMS(ATAN(zc/sqrt(1-zc^2))); // Altezza (height)
  // IF (ac<0) THEN az:= ((360 + az) MOD 360); END;
  // SAD:= acos(-tan(lat)*tan(δ)); // Semiarco Diurno
  tram:= (culm + SAD/15) MOD 24; // Tramonto (Set)
  P:= →HMS((0.9508+0.0518*cos(M)) MOD 360); // parallasse
  // Raggio quadratico medio della Terra: 6373,044737
  d:= 1/sin(P); // distanza Terra-Luna in raggi terrestri
  s:= asin((3/11)*sin(P)); // semidiametro (raggi terrestri)
  ph:= abs(LongM - Ls); // Phase
  CASE
  // IF ph == 0 THEN fase:="New Moon"; END;
  IF ph>280 AND ph<350 THEN fase:="Decrescente"; END;
  IF ph>=260 AND ph<=280 THEN fase:="Last Quart"; END;
  IF ph>190 AND ph<260 THEN fase:="Gibbosa Cal."; END;
  IF ph>=170 AND ph<=190 THEN fase:="Full Moon"; END;
  IF ph>100 AND ph<170 THEN fase:="Gibbosa Cresc."; END;
  IF ph>=80 AND ph<=100 THEN fase:="1st Quart"; END;
  IF ph>10 AND ph<80 THEN fase:="Crescente"; END;
  DEFAULT fase:="New Moon";
  END; // case
  // età della Luna
  dd:= IP(HMS→(ph/15));
  hh:= IP(FP(HMS→(ph/15))*60);
  IF (hh>24) THEN dd:= dd+1; hh:= hh MOD 24; END;
  mm:= IP(FP(FP(FP(HMS→(ph/15))*60))*60);
  eta:= →HMS(dd+hh/60+mm/3600); // Age of the Moon
  segno:= zodiaco(LongM);
  PRINT;
  PRINT("Effemeridi della Luna a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("L Long media " + trunc_angle(L));
  PRINT("λ Longitudine " + trunc_angle(LongM) + " " + segno);
  PRINT("β Latitudine " + trunc_angle(LatM));
  PRINT("ω Perigeo medio " + trunc_angle(ω));
  PRINT("Ω Nodo ascendente " + trunc_angle(Ω));
  PRINT("α Ascensione retta (gradi) " + trunc_angle((α*15) MOD 360));
  PRINT("");
  PRINT("Ang. orario "+ trunc_angle(H) + " " + trunc_angle(Hd));
  PRINT("TS (locale) " + trunc_angle(ts(2)));
  PRINT("Diff. asc." + trunc_angle(DA) + " SAD " + trunc_angle(SAD));
  PRINT("P Parallasse " + trunc_angle(P));
  PRINT("d Distanza Terra - Luna "+ ROUND(d*6373.044737,3) + " km");
  PRINT("Semidiametro "+  trunc_angle(→HMS(s)) + " :: " + ROUND(s*6373.044737,3) + " km");
  PRINT(" ");
  PRINT("Fase " + trunc_angle(ph) + " " + fase + " " + ROUND(100*→HMS(ph)/360,2)+"%");
  PRINT("Età " + eta);
  RETURN [[L, M],[LongM, LatM],[ω,Ω],[α,δ], [az, h], [P,0],[d,s], [sorg, tram], [culm, ts(1)],[ph, eta] ];
  LOCAL ω,Ω, l, v, r, x, y, z;
  LOCAL Ls, Ms, b, xs, ys, b_ec;
  LOCAL x1, y1, z1, R, l_ec, H, Hd;
  LOCAL ec, in, a, δ, α, ts, az, h;
  LOCAL DA, SAD, tram, sorg, culm, dayY;
  LOCAL as, ac, zc, dz, θ, mov, segno;
  // calc of Sun (as basis)
  xs:= sunlist(9); ys:= sunlist(10);
  // end Sun
 EVAL(EXPR(nameplanet+"()")); // call planet-name function
  L:= planet_const(1); // Longitudine media
  ω:= planet_const(2); // perielio
  Ω:= planet_const(3); // nodo
  M:= planet_const(4); // anomalia
  v:= planet_const(5);
  ec:= planet_const(6); // eccentricità
  in:= planet_const(7); // inclinazione
  a:= planet_const(8);  // semiasse maggiore
  θ:= planet_const(9);  // θs to calc if retrogade
  b_ec:= asin(sin(in)*sin(v+ω-Ω)); // argomento di latitudine del perielio
  l_ec:= acos(cos(v+ω-Ω)/cos(b_ec));  // long from eclittic
  IF b_ec<0 THEN l_ec:= 360 - l_ec; END; // argomento secondario
  l_ec:= →HMS((l_ec + Ω)) MOD 360; // aggiunge Nodo e riporta a 2PI
  r:= a*(1-ec^2)/(1+ec*cos(v)); // 9.524899/(1+ 0.0559*cos(v)); raggio vettore
  x1:= r*cos(b_ec)*cos(l_ec); y1:= r*cos(b_ec)*sin(l_ec); z1:=r*sin(b_ec); // cartesian
  x:= x1+xs; y:= y1+ys; z:=z1; // cohordinates cartesian->spheric
  R:= sqrt(x^2+y^2+z^2);
  b:=asin(z/R); // latitudine  β
  // l:=→HMS(atan(y/x)); // cart->spheric longtitudine λ
  l:= atan2(y,x);
  IF l<0 THEN l:= l+360; END; IF l>360 THEN l:=l-360; END;
  δ:= →HMS((asin(cos(ε)*sin(b)+sin(ε)*cos(b)*sin(l))) ); // declinazione (coord locali)
  α:= (acos(cos(b)*cos(IFTE(l>180, l-180, l))/cos(δ))); // ascensione retta
  DA:= →HMS(asin(tan(lat)*tan(δ))); // Differenza ascensionale
  SAD:= →HMS(90 + DA); // Semiarco Diurno
  culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) MOD 24 ; // Culminazione
  IF abs(l-220.4)>θ THEN mov:="diretto"; ELSE mov:="retrogrado"; END;
  segno:= zodiaco(l);
  PRINT;
  PRINT("Effemeridi di " + nameplanet + " a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("ω Perielio " + trunc_angle(ω));
  PRINT("Ω Nodo " + trunc_angle(Ω));
  PRINT("M Anomalia vera " + trunc_angle(M));
  PRINT("l_ec Long. eclittica " + trunc_angle(l_ec));
  PRINT("b_ec Lat. eclittica " + trunc_angle(b_ec) + " v " + trunc_angle(v));
  PRINT("r Raggio vettore " + r);
  PRINT("Cartes. elioc.: x' " + ROUND(x1,3) + " y' " + ROUND(y1,3) + " z' " + ROUND(z1,3));
  PRINT("Cartes. geoc.: x " + ROUND(x,3) + " y " + ROUND(y,3) + " z " + ROUND(z,3));
  PRINT("Spher.: λ Longitudine " + trunc_angle(l) + " " + segno); // spheric
  PRINT("Spher.: β Latitudine " + trunc_angle(b));
  PRINT("Spher.: R Distanza " + ROUND(R,3));
  PRINT("");
  PRINT("Diff. ascensionale " + trunc_angle(DA));
  PRINT("SAD semiarco diurno " + trunc_angle(SAD) + " :: " + trunc_angle(→HMS(SAD/15)));
  PRINT("Movimento " + mov);
  RETURN [[L,ω,Ω ],[M,l_ec,b_ec], [v,r,0], [x1,y1,z1],[x,y,z],[l,b,R], [α,δ,H], [az,h,ts(1)],[sorg, tram, culm]];
Mercurius()
  // Costanti per Mercurio
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.205615; // eccentricità
  in:= 7.003; // inclinazione
  a:= 0.387098; // semiasse maggiore
  θ:= 35.6;  // θs to calc if retrogade
  calcN();
  // costanti planetarie
  L:= →HMS((229.851 + 4.09237703*N) MOD 360); // Longitudine media
  ω:= →HMS((75.913 + 0.00004253*N) MOD 360); // perielio
  Ω:= →HMS((47.157 + 0.00003244*N) MOD 360); // nodo
  M:= (L - ω); // Anomalia vera
  v:= M + 23.4372*sin(M)+2.9810*sin(2*M)+0.5396*sin(3*M)+0.1098*sin(4*M);
  planet_const:= {L, ω, Ω, M, v, ec, in, a, θ};
  RETURN planet_const;
Venus()
  // Costanti per Venere
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.006816; // eccentricità
  in:= 3.393636; // inclinazione
  a:= 0.72333; // semiasse maggiore
  θ:= 13.0;  // θs to calc if retrogade
  calcN();
  L:= →HMS((206.758 + 1.60216873*N) MOD 360); // Longitudine media
  ω:= →HMS((130.154 + 0.00003757*N) MOD 360); // perielio
  Ω:= →HMS((75.797 + 0.00002503*N) MOD 360); // nodo
  v:= M + 0.7811*sin(M);
Mars()
  // Costanti per Marte
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.093309; // eccentricità
  in:= 1.850303; // inclinazione
  a:= 1.523678; // semiasse maggiore
  θ:= 16.8;  // θs to calc if retrogade
  calcN();
  L:= →HMS((124.765 + 0.52407108*N) MOD 360); // Longitudine media
  ω:= →HMS((334.251 + 0.00005038*N) MOD 360); // perielio
  Ω:= →HMS((48.794 + 0.00002127*N) MOD 360); // nodo
  v:= M + 10.608*sin(M)+0.6216*sin(2*M)+0.0504*sin(3*M)+0.0047*sin(4*M);
Jupiter()
  // Costanti per Giove
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.048335; // eccentricità
  in:= 1.308736; // inclinazione
  a:= 5.202561; // semiasse maggiore
  θ:= 54.43;  // θs to calc if retrogade
  calcN();
  L:= →HMS((268.350 + 0.08312942*N) MOD 360); // Longitudine media
  ω:= →HMS((12.737 + 0.00004408*N) MOD 360); // perielio
  Ω:= →HMS((99.453 + 0.00002767*N) MOD 360); // nodo
  v:= M + 5372*sin(M)+0.1662*sin(2*M)+0.007*sin(3*M);
Saturn()
  // Costanti per Saturno
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.055892; // eccentricità
  in:= 2.492519; // inclinazione
  a:= 9.554747; // semiasse maggiore
  θ:= 65.53;  // θs to calc if retrogade
  calcN();
  L:= →HMS((278.774 + 0.03349788*N) MOD 360); // Longitudine media
  ω:= →HMS((91.117 + 0.00005362*N) MOD 360); // perielio
  Ω:= →HMS((112.79 + 0.00002391*N) MOD 360); // nodo
  v:= M + 6.4023*sin(M)+0.2235*sin(2*M)+0.011*sin(3*M);
Uranus()
  // Costanti per Urano
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.046344; // eccentricità
  in:= 0.772464; // inclinazione
  a:= 19.21814; // semiasse maggiore
  θ:= 73.92;  // θs to calc if retrogade
  calcN();
  L:= →HMS((248.487 + 0.01176902*N) MOD 360); // Longitudine media
  ω:= →HMS((171.563 + 0.00004064*N) MOD 360); // perielio
  Ω:= →HMS((73.482 + 0.00001365*N) MOD 360); // nodo
  v:= M + 5.3092*sin(M)+0.1537*sin(2*M)+0.0062*sin(3*M);
Neptunus()
  // Costanti per Nettuno
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.008997; // eccentricità
  in:= 1.779242; // inclinazione
  a:= 30.10957; // semiasse maggiore
  θ:= 77.63;  // θs to calc if retrogade
  calcN();
  L:= →HMS((86.652 + 0.00602015*N) MOD 360); // Longitudine media
  ω:= →HMS((46.742 + 0.000039*N) MOD 360); // perielio
  Ω:= →HMS((130.693 + 0.00003009*N) MOD 360); // nodo
  v:= M + 1.031*sin(M)+0.0058*sin(2*M);
Pluto()
  // Costanti per Plutone
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.250236; // eccentricità
  in:= 17.17047; // inclinazione
  a:= 39.438712; // semiasse maggiore
  θ:= 79.41;  // θs to calc if retrogade
  calcN();
  // Long, perielio, nodo, non precisi, considerati costanti
  // L:= →HMS((229.851 + 4.09237703*N) MOD 360); // Longitudine media
  M:= →HMS((230.67 + 0.00397943*N) MOD 360); // Anomalia vera (calcolata direttamente)
  Ω:= →HMS((109.06 + 0.00003823*N) MOD 360); // nodo
  ω:= →HMS((114.27 + Ω) MOD 360); // perielio
  L:= →HMS((M + ω) MOD 360); // L (non sicuro)
  v:= M + 28.45*sin(M)+4.38*sin(2*M)+0.97*sin(3*M)+0.24*sin(4*M);
RE: Astronomy... - Marcel - 06-20-2015 07:18 PM
Hi Salvomic
We don't use the same technique for calculating the planetary position. I use the VSOP technique (Variation séculaire des orbites planétaires). In this technique, we use polynomials and series of DATA to obtain the heliocentric position of a planet...
I complete today two new functions for the location of Pluto. This is the year of Pluto because in 25 days, the probe New Horizon will arrive at Pluto. For this reason, I will post my astronomy app's just before that moment.
Good lock in your project, this is fun and we can use both programs.
Marcel
RE: Astronomy... - salvomic - 06-20-2015 08:34 PM
(06-20-2015 07:18 PM)Marcel Wrote:  Hi Salvomic
Marcel
hi Marcel,
yes, I'm using a different approach, following Bouiges: using the constants for planets, Sun and Moon...
About Pluto, my approach is very few, for now, as I'm using the old data (they were written in 1973...) and then Pluto was not completely known about Longitude, for example, so my program for now use some values as constant, like perigeo or longitude and anomaly...
You are right: we could now give more attention to Pluto.
However we could perhaps to search if some functions are common to the two programs and to find a common point of view...
Beside Pluto, in your program, I'm looking forward to see also the Moon functions, phases and so on...
Salvo
RE: Astronomy... - Marcel - 06-20-2015 10:29 PM
I send you my app's with Pluto, so you will be able to compare with your program. If you have Mathematica or WolframAlpha, check for precision. It is very good.
Marcel
RE: Astronomy... - salvomic - 06-21-2015 06:38 AM
(06-20-2015 10:29 PM)Marcel Wrote:  Hi,
Marcel
thank Marcel,
I'm trying it!
for now with my program I get the same declination, but not the same RA, but my program has a problem to get right longitude of Pluto for now, your does it better...
I've both Mathematica and Wolfram, I'll check there also.
Salvo
EDIT: I reduced difference for Pluto between the to programs about (1' - 3'), for now: there was an error in a formula of mine...
RE: Astronomy... - salvomic - 06-22-2015 12:42 PM
some improvements (calculation of times, sidereal times, julian day, epsilon, data for Pluto...)
data();
calcN();
calcTS();
julianDay();
tempo();
sunCalc();
planetCalc();
planets();
sun();
moon();
Mercurius();
Venus();
Mars();
Jupiter();
Saturn();
Uranus();
Neptunus();
Pluto();
ascendent();
zodiaco();
trunc_angle();
atan2();
lstd:=0; gmt:= 12;
long:= 0; lat:=  0;
deltaT:= 68;
datetimelist:= MAKELIST(X,X,1,6);
ε:= →HMS(23.4392911);  // approx 23.45 (23°26'21")
EXPORT Effemeridi()
  LOCAL ch;
  HAngle:=1;
  CHOOSE(ch, "Effemeridi", "Sun", "Moon", "Planets", "Calc TS JD N", "Ascendent", "Quit");
  CASE
  IF ch==4 THEN tempo(); END;
  IF ch==5 THEN ascendent(); END;
  IF ch==6 THEN HAngle:=0; RETURN; END;
  DEFAULT
  END; // case
data()
  LOCAL t, jd;
  yy:= IP(Date);
  {lat,[0],{70,25,4}},
  {deltaT, [0], {20,25,5}} },
  {"Month:","Day :","Year :","Local Time (24):", "DST", "UTC",
  "Long (-E):","Lat (+N)", "delta T"},
  "Enter local time (decimal or H°M′S″)", "Daylight Save Time?", "UTC time zone",
  "Longitude", "Latitude", "Delta T (sec.)"},
  {1,1,1901,0, 0,0, 0, 0, 0},{mm,dd,yy,loct, 0, 1, -14°43′41″, 36°55′15″, 68});
 //  D:=EVAL(D); m:=EVAL(m); Y:=EVAL(Y);
  datetimelist:= {Y, m, D, IP(HMS→(lstd)), IP(FP(HMS→(lstd))*60), ROUND(FP(HMS→(lstd)*60)*60,3) };
jd:= julianDay();
t:=(jd(1)-2451545)/36525;
ε:=23.4392911111-0.013004166667*t-0.000001638889*t^2+0.000000503611*t^3;
ε:= →HMS(ε);
planets()
  "Choose planet",
  CASE
  DEFAULT
  END; // case
calcN()
  RETURN N;
calcTS()
  LOCAL TS, TSd, N0, TSL, TSapp;
  calcN();
  TS:=  ((23750.3 + 236.555362*N) / 3600) MOD 24; // Sideral Time (GMT) in seconds
  TSL:= (TS + gmt - 4*(HMS→(long))/60) MOD 24; // local ST
  TSapp:= (TS + gmt) MOD 24; // apparent ST (ST at Greenwitch at local our)
  TSapp:= →HMS(TSapp); // in HMS
  TSd:= →HMS(TS*15) MOD 360; // ST at 0 GMT in degrees
  RETURN {trunc_angle(TS), trunc_angle(TSL), trunc_angle(TSapp), trunc_angle(TSd), gmt};
julianDay()
  LOCAL yy, mm, dd,dde, hh, mn, ss;
  LOCAL aa,bb, jd, jde;
  yy:= Y; mm:= m;
  hh:= datetimelist(4);
  mn:= datetimelist(5);
  ss:= datetimelist(6);
  dd:= D + hh/24 + mn/(60*24) + ss/(60*60*24);
  dde:= D + hh/24 + mn/(60*24) + (ss+deltaT)/(60*60*24);
  IF (m=1 OR m=2) THEN yy:=Y-1; mm:=m+12;END;
  IF yy*100+mm+dd>=158225 THEN
    aa:=IP(ABS(yy/100));
    bb:=2-aa+IP(aa/4);
  ELSE bb:=0; END;
  jd:=IP(365.25*(yy+4716))+IP(30.6001*(mm+1))+dd+bb-1524.5;
  jde:=IP(365.25*(yy+4716))+IP(30.6001*(mm+1))+dde+bb-1524.5;
  RETURN {jd, jde};
tempo()
  LOCAL n, jd, TSid;
  n:= calcN();
  jd:= julianDay();
  TSid:= calcTS;
  PRINT;
  PRINT("Date " + m + " " + D + " " + Y);
  PRINT("Julian Day " + jd(1));
  PRINT("Julian Day Effem. " + jd(2));
  PRINT("N (from 1901jan1) " + n);
  PRINT("Tempo Siderale 0h " + trunc_angle(TSid(1)));
  PRINT("Tempo Siderale locale " + trunc_angle(TSid(2)));
  PRINT("Tempo Siderale apparente " + trunc_angle(TSid(3)));
  PRINT("Tempo Siderale gradi " + trunc_angle(TSid(4)));
  PRINT("Time " + lstd + " GMT " + gmt);
  RETURN({ROUND(jd(1),5), ROUND(jd(2),5), ROUND(n, 5), trunc_angle(TSid(1)), trunc_angle(TSid(2)),
    trunc_angle(TSid(3)), trunc_angle(TSid(4)), gmt });
ascendent()
  ts:= calcTS();
zodiaco(astro)
  LOCAL segno;
  END; // case
  RETURN segno;
atan2(y,x)
  CASE
  RETURN;
trunc_angle(ang)
sunCalc()
  LOCAL as, ac, zc, h0, H0, temp;
  h0:= -0°50′; // 'standard' altitude of Sun
  calcN();
  julianDay();
// temp:= sin(h0)-sin(lat)*sin(δ)/cos(lat)*cos(δ);
// IF temp<0 THEN temp:= temp +1; END; IF temp>1 THEN temp:=temp-1; END;
// H0:= acos(temp);
// MSGBOX("H0: " + H0);
//temp:= ((α*15 + long - ts(3)*15) / 360);
// culm:= (temp - Hd/360) *24;
// sorg:= (culm - H0/360) *24;
// tram:= (culm + H0/360) *24;
  RETURN sunlist;
sun()
  LOCAL as, ac, zc, segno, jd;
  ts:= calcTS(); //
  jd:= julianDay();
  segno:= zodiaco(l);
  PRINT;
  PRINT("at Long " + long + "Lat " + lat);
  PRINT("");
  PRINT(" ");
  PRINT("TS apparente " + trunc_angle(ts(3)));
  PRINT("Julian day " + jd(1));
  PRINT("");
  PRINT("ε epsilon " + ε);
  RETURN [[L, ω], [l, M], [α,δ], [az, h], [x,y], [sorg, tram], [culm, r], [H,ts(1)], [lt, ε]];
moon()
  calcN();
  // Sun
  // end Sun
b:= LatM;
  CASE
  END; // case
  // età della Luna
  PRINT;
  PRINT("");
  PRINT(" ");
  // end Sun
  l:= atan2(y,x);
  segno:= zodiaco(l);
  PRINT;
  PRINT("");
Mercurius()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Venus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Mars()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Jupiter()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Saturn()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Uranus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Neptunus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Pluto()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
RE: Astronomy... - Marcel - 06-22-2015 06:26 PM
Hi Salvomic
We can calculate Delta T with some analytical way but this is not always precise. In fact we know the value of Delta T after the year. For instance, we will know the value for the year 2015, in 2016! This is a correction or a difference between two times scales.
In my app's, many data are in variable associate with the App. You can see these var if you click on the "var" tab in the conn kit. At this point this is more complex than your technique because many calculations most been done with these data in a FOR statement. If you check for the book of Jean Meeus on the internet, you will learn how to use that data.
Marcel
RE: Astronomy... - salvomic - 06-22-2015 06:34 PM
(06-22-2015 06:26 PM)Marcel Wrote:  Hi Salvomic
Marcel
hi Marcel,
thank you for info.
I found the book of Meeus, yes, but just few minutes ago...
But I should rewrite all the program to conform 100% to it, and in this case there is already your app...
So, I'm trying to improve something adding formulas by Meeus to those by Bouiges. It isn't an easy job, hi...
Now, to improve Sun precision I should add at least 15 parameters, and solve the Keplero equation:
u - e sin(u) = M
in the var u, given e (eccentricity, by formula, ok) and M (anomaly), stopping it when the last iteration is no more great than previous for 1/10000, then calc v with u (v=acos(cos(u)-e/1-e*cos(u))) and so on...
Any hint to solve that equation?
I tried solve() but without luck...
thank you
Salvo
RE: Astronomy... - Marcel - 06-22-2015 06:48 PM
One of the chapter in the book describe a way to solve the Kepler equation (Chapter 29). You will find in this chapter a program to do it.
Marcel
RE: Astronomy... - salvomic - 06-22-2015 07:29 PM
(06-22-2015 06:48 PM)Marcel Wrote:  Hi,
Marcel
I'll read it!
Salvo
RE: Astronomy... - salvomic - 06-23-2015 03:16 PM
New version, greater precision (especially for the Moon) and rationalization...
data();
calcN();
calcTS();
julianDay();
julianDayAtZero();
tempo();
precession();
parametri();
sunCalc();
planetCalc();
planets();
sun();
moon();
Mercurius();
Venus();
Mars();
Jupiter();
Saturn();
Uranus();
Neptunus();
Pluto();
ascendent();
zodiaco();
trunc_angle();
simp_angle();
atan2();
lstd:=0; gmt:= 12;
long:= 0; lat:=  0;
deltaT:= 68; // 2015
ε:= →HMS(23.4392911);  // intial value, approx 23.45 (23°26'21")
EXPORT Effemeridi()
// Credits: Serge Bouiges, Calcule astronomique pour amateurs
// Jean Meeus, Astronomical Algorithms
// Thanks Didier Lachieze, Marcel Pelletier, Eried
  LOCAL ch;
  HAngle:=1;
  CHOOSE(ch, "Effemeridi", "Sun", "Moon", "Planets", "Calc TS JD N", "ε, Δψ, Δε...", "Ascendent", "Quit");
  CASE
  IF ch==5 THEN parametri(); END;
  DEFAULT
  END; // case
data()
  LOCAL t, jd;
  yy:= IP(Date);
  jd:= julianDay();
  U:= t/100;
  // ε:=23.4392911111-0.013004166667*t-0.000001638889*t^2+0.000000503611*t^3; (formula IAU J2000.0)
  ε:= 23°26′21.448″ - 1°18′00.93″*U-1.55*U^2+1999.25*U^3-51.38*U^4-249.67*U^5;
  ε:= ε-39.05*U^6+7.12*U^7+27.87*U^8+5.79*U^9+2.45*U^10; // Laskar, Meeus
  ε:= →HMS(ε);
planets()
  INPUT({{ch, nameplanet:={"Mercurius","Venus","Mars", "Jupiter",
  "Choose planet",
  planetCalc(nameplanet(ch));
calcN()
  RETURN N;
calcTS()
  LOCAL T, TS, TSd, N0, TSL, TSapp;
  LOCAL θ0, θ00, jd, jd0;
  calcN();
  jd:= julianDay();
  jd0:= julianDayAtZero();
  T:= (jd(1)-2451545.0)/36525;
  θ0:= 280.46061837+360.98564736629*(jd(1)-2451545.0)+0.000387933*T^2-T^3/38710000; // DEG at 0h
  θ0:= θ0 MOD 360;
  θ00:= 280.46061837+360.98564736629*(jd0(1)-2451545.0)+0.000387933*T^2-T^3/38710000; // DEG at 0h
  θ00:= θ00 MOD 360;
  RETURN {TS, TSL, TSapp, TSd, θ0, θ00, T};
julianDay()
  yy:= Y; mm:= m;
  bb:=2-aa+IP(aa/4);
  ELSE bb:=0; END;
  RETURN {jd, jde};
julianDayAtZero()
  yy:= Y; mm:= m;
  hh:= 0;
  mn:= 0;
  ss:= 0;
  dd:= D;
  dde:= D + (ss+deltaT)/(60*60*24);
  bb:=2-aa+IP(aa/4);
  ELSE bb:=0; END;
  RETURN {jd, jde};
tempo()
  LOCAL n, jd, TSid;
  n:= calcN();
  jd:= julianDay();
  TSid:= calcTS();
  PRINT;
  PRINT("T (from JD) " + TSid(7));
  PRINT("Tempo Siderale (DEG) " + trunc_angle(TSid(4)));
  PRINT("θ0 Mean ST 0h " + trunc_angle(TSid(5)/15));
  PRINT("θ0 Mean ST 0h (DEG) " + trunc_angle(TSid(5)));
  PRINT("θ00 MST 00h GMT " + trunc_angle(TSid(6)/15));
  PRINT("θ00 MST 00h GMT (DEG) " + trunc_angle(TSid(6)));
    trunc_angle(TSid(3)), trunc_angle(TSid(4)), trunc_angle(TSid(5)) });
deltaEpsilonPsi()
  // Nutazione Δψ (longitudine), Δε (obliquità)
  LOCAL L1, deltaPsi, deltaEpsilon, Ω, jd;
  jd:= julianDayAtZero();
  T:= (jd(2)-2451545)/36525; // use JDE
  Ω:= 125.04452-1934.136261*T-0.0020708*T^2+(T^3)/450000; // Nodo Luna (Moon)
  L:= (→HMS(280.4665)+36000.76983*T+→HMS(0.0003032*T^2)) MOD 360; // Long media Sole
  L1:= →HMS(218.3164591) + →HMS(481267.88134236)*T-0.0013268*T^2; //  Long media Luna
  L1:= L1+(T^3)/538841-(T^4)/65194000;
  L1:= L1 MOD 360;
  deltaPsi:= -0°0′17.20″*sin(Ω)-0°0′1.32″*sin(2*L)-0°0′0.23″*sin(2*L1)+0°0′0.21″*sin(2*Ω);
  deltaEpsilon:= 0°0′9.2″*cos(Ω)+0°0′0.57″*cos(2*L)+0°0′0.10″*cos(2*L1)-0°0′0.09″*cos(2*Ω);
  RETURN({deltaPsi, deltaEpsilon});
precession(alfa, delta)
  // precessione dati asce retta e declinazione
  LOCAL m,n,n1, deltaAlfa, deltaDelta, Tsec;
  Tsec:= IP((Y-2000)/100)+1; // T century from 2000.0
  m:= 0°0′3.07496″+0°0′0.00186″*Tsec;
  n:= 0°0′1.33621″+0°0′0.00057″*Tsec; // sec
  n1:= 0°0′20.0431″+0°0′0.0085″*Tsec; // ° ' "
  deltaAlfa:= m+n*sin(alfa)*tan(delta); // Δα
  deltaDelta:= n1*cos(alfa); // Δδ
  RETURN({deltaAlfa, deltaDelta});
parametri()
  LOCAL dep, prec, α, δ;
  dep:= deltaEpsilonPsi();
  prec:= precession(α, δ);
  // Nutazione Δψ (longitudine), Δε (obliquità), ε (inclinazione eclittica)...
  PRINT;
  PRINT("ε Inclinazione eclittica "+ ε);
  PRINT("Δψ Nutazione longitudine "+ dep(1));
  PRINT("Δε Nutazione longitudine "+ dep(2));
  PRINT(" ");
  PRINT("Δα Precessione AR "+ prec(1));
  PRINT("Δδ Precessione dec "+ prec(2));
  RETURN({ε, dep(1), dep(2), prec(1), prec(2)}); // ε, Δψ, Δε, Δα, Δδ
ascendent()
  ts:= calcTS();
zodiaco(astro)
  LOCAL segno;
  END; // case
  RETURN segno;
atan2(y,x)
  CASE
  RETURN;
trunc_angle(ang)
simp_angle(ang)
LOCAL angle;
angle:=360*FP(ang/360);
IF angle<0
THEN
angle:=angle+360
RETURN angle;
kepler(ec, M)
// needs eccentricity and true anomaly M
  LOCAL M1, j, u;
  HAngle:=0; // RAD
  M1:= HMS→(M)*PI/180; // anomalia RAD
  F:= SIGN(M1); M1:= ABS(M1)/(2*PI);
  M1:=(M1-IP(M1))*2*PI*F;
  IF M1<0 THEN M1:= M1+2*PI; END;
  F:= 1;
  IF M1>PI THEN F:= -1; END;
  IF M1>PI THEN M1:=2*PI-M; END;
  u:= PI/2; D:=PI/4;
  FOR j FROM 1 TO 33 DO // 33 iterations (Meeus, Roger Sinnot)
  M2:= u-ec*sin(u); u:= u+D*SIGN(M1-M2); D:= D/2;
  END; // for
  u:= u * F; // anomalia eccentrica
  HAngle:=1;
  u:= u*180/PI;
  RETURN u;
sunCalc()
  LOCAL ec, a, u, M1, M2, j, t;
  LOCAL m0, m1, m2, jd, c, lapp, Ω;
  calcN();
  jd:= julianDay();
  a:= 1.00000023; // semiasse maggiore
  t:= N/36525;
  // ec:= 0.01675062-0.0000418*t-0.000000137*t^2; // eccentricità (RAD)
  ec:= 0.016708617-0.000042037*T-0.0000001236*T^2; // eccentricità Meeus
  // ec:= ec*180/PI; // DEG
  // L:= →HMS(278.9654+0.985647342*N + 0.0003*t^2) MOD 360; // long media
  L:= (→HMS(280.4665)+36000.76983*T+→HMS(0.0003032*T^2)) MOD 360; // Long media Sole Meeus
  ω:= →HMS(281.238 + 0.000047067*N + 0.00045*t^2) MOD 360; // long del perielio
  // M:= (L - ω); // anomalia vera
  //IF M<0 THEN M:= (360+M); END; // potrebbe essere negativa
  Ω:= (→HMS(125.04)-→HMS(1934.136)*T) MOD 360; // Nutazione e aberrazione (nodo)
  M:= →HMS(357.52910)+→HMS(35999.05030)*T+→HMS(0.0001559)*T^2-→HMS(0.00000048)*T^3; // anom vera Meeus
  M:= M MOD 360;
  u:=atan2(sin(M),(cos(M)-ec)); // only for small eccentricity
  c:= (→HMS(1.914600)-→HMS(0.004817)*T-→HMS(0.000016)*T^2)*sin(M);  // equation of center
  c:= c+(→HMS(0.019993)-→HMS(0.000101)*T)*sin(2*M)+(→HMS(0.000290))*sin(3*M);
  // v:= M + 1.91934 * sin(M)+0.02*sin(2*M); // calcolo intermedio (Bouiges)
  // v:= acos((cos(u)-ec)/(1-ec*cos(u))); // kepler
  v:= M + c; // true anomaly, Meeus
  // l:= (v + ω) MOD 360; // Longitudine Sole
  l:= (L+c) MOD 360; // Ө Longitudine Sole, Meeus
  lapp:= l - →HMS(0.00569)-→HMS(0.00478)*sin(Ω); // Longitudine apparente (ref true equinox)
  lapp:= simp_angle(lapp);
  // r:= ((0.999721)/(1+0.01675*cos(v))); // Distanza Sole-Terra (UA)
  r:= (1.000001018*(1-ec^2))/(1+ec*cos(v)); // Distanza Sole-Terra (UA) Meeus
  // α:= (acos(cos(IFTE(l>180, l-180, l))/cos(δ))); // ascensione retta
  // IF l>180 THEN α:= α +180; END;
  α:= →HMS(atan2(cos(ε)*sin(l),cos(l))); // Ascensione retta, Meeus (b never > 1.2", l=Ө)
  az:= atan2((-cos(δ) * sin(Hd)), cos(lat) *sin(δ)-sin(lat)*cos(δ)*cos(Hd)); // Azimuth
 culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) ; // Culminazione, transito
// temp:= (sin(h0)-sin(lat)*sin(δ))/(cos(lat)*cos(δ));
//IF temp<-1 THEN temp:= temp +1; END; IF temp>1 THEN temp:=temp-1; END;
//H0:= acos(temp);
// m0:= ((α*15 + long - ts(6)) / 360);
//IF m0<0 THEN m0:= m0 +1; END; IF m0>1 THEN m0:=m0-1; END;
// culm:= m0*24;
//temp:= ts(3)*15+360.985647*m0;
// H1:= temp - long - α*15;
//        IF temp>360 THEN temp:= temp MOD 360; END;
//culm:= (m0 - H/360) * 24 ;
    SAD, E, lt, v, c, Ω, lapp, ec};
  RETURN sunlist;
sun()
  LOCAL as, ac, zc, segno, jd, v, c;
  LOCAL Ω, lapp, ec;
  Ω:= sunlist(26); lapp:=sunlist(27);
  v:= sunlist(24); c:= sunlist(25);
  ts:= calcTS(); //
  jd:= julianDay();
  ec:= sunlist(28);
  segno:= zodiaco(l);
  PRINT;
  PRINT("at Long " + long + " Lat " + lat);
  PRINT("");
  PRINT("M anomalia " + trunc_angle(M));
  PRINT("v anomalia vera " + v);
  PRINT("c equazione del centro " + c);
  PRINT(" ");
  PRINT("Ө Longitudine Sole " + trunc_angle(l) + " " + segno);
  PRINT("λ longitudine apparente " + trunc_angle(lapp));
  PRINT("Ω aberr, nutaz nodo "+ Ω);
  PRINT("r distanza (UA) " + r);
  PRINT(" ");
  PRINT(" ");
  PRINT("θ0 Mean ST 0h " + trunc_angle(ts(5)/15));
  PRINT("Dif asc." + trunc_angle(DA) + " SAD " + trunc_angle(SAD));
  PRINT("");
  PRINT(" ");
  PRINT("ec eccentricità "+ ec);
  RETURN [[L, ω], [l, lapp], [M,v], [Ω, c], [α,δ], [az, h], [x,y],
  [sorg, tram], [culm, r], [H,ts(1)], [lt, 0], [ε, ec]];
moon()
  LOCAL d1, h1, m1, segno, jd, rr;
  LOCAL lapp, dep, ill, ee, a1,a2,a3;
  calcN();
  jd:= julianDay();
  // Sun
  // end Sun
  //L:= (33.231 + 13.17639653*N) MOD 360; // long. media
  L:= simp_angle(218.3164591+481267.88134236*T-0.0013268*T^2+(T^3)/538841-(T^4)/65194000);
  //  Long media Luna Meeus
  // Ω:= (239.882 - 0.052953922*N) MOD 360; // Long nodo ascendente
  Ω:= simp_angle(Ω);
  // M:= (18.294 + 13.06499245*N) MOD 360; // anomalia vera
  M:= 134.9634114+477198.8676313*T+0.0089970*T^2+(T^3)/69699-(T^4)/14712000; // anomalia media
  M:= simp_angle(M);
  // DD:= L - Ls; F:= L-Ω; // for the variations
  DD:= 297.8502042+445267.1115168*T-0.0016300*T^2+(T^3)/545868-(T^4)/113065000; // mean elongation
  DD:= simp_angle(DD);
  F:= 93.2720993+483202.0175273*T-0.0034029*T^2-(T^3)/3526000+(T^4)/863310000; // dist from asc. node
  F:= simp_angle(F);
  ee:= 1-0.002516*T-0.0000074*T^2;  // multiply those w/ Ms *ee
  a1:= →HMS(119.75)+→HMS(131.849)*T; // action of Venus
  a2:= →HMS(53.09)+→HMS(479264.290)*T; // action of Jupiter
  a3:= →HMS(313.45)+→HMS(481266.484)*T;
  LongM:= L     + 6.288774 * sin(M); // calc Moon longitude
  LongM:= LongM + 1.274027 * sin(2*DD-M); // evezione
  LongM:= LongM + 0.658314 * sin(2*DD); // variazione
  LongM:= LongM + 0.213618 * sin(2*M); // equazione del centro
  LongM:= LongM - 0.185116 * sin(Ms) *ee; // equazione annuale
  LongM:= LongM - 0.114332 * sin(2*F); // riduzione all'eclittica
  LongM:= LongM + 0.058793 * sin(2*DD-2*M);
  LongM:= LongM + 0.057066 * sin(2*DD-M-Ms) *ee;
  LongM:= LongM + 0.053322 * sin(2*DD+M);
  LongM:= LongM + 0.045758 * sin(2*DD-Ms) *ee;
  LongM:= LongM - 0.040923 * sin(Ms-M) *ee;
  LongM:= LongM - 0.034720 * sin(DD);
  LongM:= LongM - 0.030383 * sin(M+Ms) *ee;
  LongM:= LongM + 0.015327 * sin(2*DD-2*F);
  LongM:= LongM - 0.012528 * sin(M+2*F);
  LongM:= LongM + 0.010980 * sin(M-2*F);
  LongM:= LongM + 0.010675 * sin(4*DD-M);
  LongM:= LongM + 0.010034 * sin(3*M);
  LongM:= LongM + 0.008548 * sin(4*DD-2*M);
  LongM:= LongM - 0.007888 * sin(2*DD+Ms-M) *ee;
  LongM:= LongM - 0.006766 * sin(2*DD+Ms) *ee;
  LongM:= LongM - 0.005163 * sin(DD-M);
  LongM:= LongM + 0.004987 * sin(DD+Ms) *ee;
  LongM:= LongM + 0.004036 * sin(2*DD-Ms+M);
  LongM:= LongM + 0.003994 * sin(2*DD+2*M);
  LongM:= LongM + 0.003861 * sin(4*DD);
  LongM:= LongM + 0.003665 * sin(2*DD-3*M);
  LongM:= LongM - 0.002689 * sin(Ms-2*M) *ee;
  LongM:= LongM - 0.002602 * sin(2*DD-M+2*F);
  LongM:= LongM + 0.002390 * sin(2*DD-Ms-2*M) *ee;
  LongM:= LongM - 0.002348 * sin(DD+M);
  LongM:= LongM + 0.002236 * sin(2*DD-2*Ms) *ee^2;
  LongM:= LongM - 0.002120 * sin(Ms+2*M) *ee;
  LongM:= LongM - 0.002069 * sin(2*Ms) *ee^2;
  LongM:= LongM + 0.002048 * sin(2*DD-2*Ms-M) *ee^2;
  LongM:= LongM - 0.001773 * sin(2*DD+M-2*F);
  LongM:= LongM - 0.001595 * sin(2*DD+2*F);
  LongM:= LongM + 0.001215 * sin(4*DD-Ms-M) *ee;
  LongM:= LongM - 0.001110 * sin(2*M+2*F);
  LongM:= LongM - 0.000892 * sin(3*DD-M);
  LongM:= LongM - 0.000810 * sin(2*DD+Ms+M) *ee;
  LongM:= LongM + 0.000759 * sin(4*DD-Ms-2*M) *ee;
  LongM:= LongM - 0.000713 * sin(2*Ms-M) * ee^2;
  LongM:= LongM - 0.000700 * sin(2*DD+2*Ms-M) *ee^2;
  LongM:= LongM + 0.000691 * sin(2*DD+Ms-2*M) *ee;
  LongM:= LongM + 0.000596 * sin(2*DD-Ms-2*F) *ee;
  LongM:= LongM + 0.000549 * sin(4*DD+M);
  LongM:= LongM + 0.000537 * sin(4*M);
  LongM:= LongM + 0.000520 * sin(4*DD-Ms) *ee;
  LongM:= LongM - 0.000487 * sin(DD-2*M);
  LongM:= LongM - 0.000399 * sin(2*DD+Ms-2*F) *ee;
  LongM:= LongM - 0.000381 * sin(2*M-2*F);
  LongM:= LongM + 0.000351 * sin(DD+Ms+M) *ee;
  LongM:= LongM - 0.000340 * sin(3*DD-2*M);
  LongM:= LongM + 0.000330 * sin(4*DD-3*M);
  LongM:= LongM + 0.000327 * sin(2*DD-Ms+2*M) *ee;
  LongM:= LongM - 0.000323 * sin(2*Ms+M) *ee^2;
  LongM:= LongM + 0.000299 * sin(DD+Ms-M) *ee;
  LongM:= LongM + 0.000294 * sin(2*DD+3*M);
  LongM:= LongM + (3958*sin(a1) + 1962*sin(L-F)+318*sin(a2))/1000000;
  LongM:= simp_angle(LongM);
  lapp:= LongM + dep(1); // longitudine apparente (+ nutazione long, Δψ)
  LatM :=        5.128122 * sin(F); // termine principale
  LatM := LatM + 0.280026 * sin(M+F);
  LatM := LatM + 0.277693 * sin(M-F); // equazione del centro
  LatM := LatM + 0.173237 * sin(2*DD-F); // grande ineguaglianza
  LatM := LatM + 0.055413 * sin(2*DD-M+F); // evezione
  LatM := LatM + 0.046271 * sin(2*DD-M-F); // evezione (2)
  LatM := LatM + 0.032573 * sin(2*DD+F);
  LatM := LatM + 0.017198 * sin(2*M+F);
  LatM := LatM + 0.009266 * sin(2*D+M-F);
  LatM := LatM + 0.008822 * sin(2*M-F);
  LatM := LatM + 0.008216 * sin(2*DD-Ms-F) *ee;
  LatM := LatM + 0.004324 * sin(2*DD-2*M-F);
  LatM := LatM + 0.004200 * sin(2*DD+M-F);
  LatM := LatM - 0.003359 * sin(2*DD+Ms-F) *ee;
  LatM := LatM + 0.002463 * sin(2*DD-Ms-M+F) *ee;
  LatM := LatM + 0.002211 * sin(2*DD-Ms+F) *ee;
  LatM := LatM + 0.002065 * sin(2*DD-Ms-M-F) *ee;
  LatM := LatM - 0.001870 * sin(Ms-M-F) *ee;
  LatM := LatM + 0.001828 * sin(4*DD-M-F);
  LatM := LatM - 0.001794 * sin(Ms-F) *ee;
  LatM := LatM - 0.001749 * sin(3*F);
  LatM := LatM - 0.001565 * sin(Ms-M+F) *ee;
  LatM := LatM - 0.001491 * sin(DD+F);
  LatM := LatM - 0.001475 * sin(Ms+M+F) *ee;
  LatM := LatM - 0.001410 * sin(Ms+M-F) *ee;
  LatM := LatM - 0.001344 * sin(Ms-F) *ee;
  LatM := LatM - 0.001335 * sin(DD-F);
  LatM := LatM + 0.001107 * sin(3*M+F);
  LatM := LatM + 0.001021 * sin(4*DD-F);
  LatM := LatM + 0.000833 * sin(4*DD-M+F);
  LatM := LatM + 0.000777 * sin(M-3*F);
  LatM := LatM + 0.000671 * sin(4*DD-2*M+F);
  LatM := LatM + 0.000607 * sin(2*DD-3*F);
  LatM := LatM + 0.000596 * sin(2*DD-F);
  LatM := LatM + 0.000491 * sin(2*DD-M+F);
  LatM := LatM - 0.000451 * sin(2*DD-M-F);
  LatM := LatM + 0.000439 * sin(2*DD+F);
  LatM := LatM + 0.000422 * sin(2*M-F);
  LatM := LatM + 0.000421 * sin(2*DD+M-F);
  LatM := LatM - 0.000366 * sin(2*M-F);
  LatM := LatM - 0.000351 * sin(2*DD+Ms-F) *ee;
  LatM := LatM + 0.000331 * sin(4*DD+F);
  LatM := LatM + 0.000315 * sin(2*DD-Ms+M+F) *ee;
  LatM := LatM + 0.000302 * sin(2*DD-2*Ms-F) *ee^2;
  LatM := LatM - 0.000283 * sin(M+3*F);
  LatM := LatM - 0.000229 * sin(2*DD+Ms+M-F) *ee;
  LatM := LatM + 0.000223 * sin(DD+Ms-F) *ee;
  LatM := LatM + 0.000223 * sin(DD+Ms+F) *ee;
  LatM := LatM - 0.000220 * sin(Ms-2*M-F) *ee;
  LatM := LatM - 0.000220 * sin(2*DD+Ms-M-F) *ee;
  LatM := LatM - 0.000185 * sin(DD+M+F);
  LatM := LatM + 0.000181 * sin(2*DD-Ms-2*M-F) *ee;
  LatM := LatM - 0.000177 * sin(Ms+2*M+F);
  LatM := LatM + 0.000176 * sin(4*DD-2*M-F);
  LatM := LatM + 0.000166 * sin(4*DD-Ms-M+F) *ee;
  LatM := LatM - 0.000164 * sin(DD+M-F);
  LatM := LatM + 0.000132 * sin(4*DD+M-F);
  LatM := LatM - 0.000119 * sin(DD-M-F);
  LatM := LatM + 0.000115 * sin(4*DD-Ms-F) *ee;
  LatM := LatM + 0.000107 * sin(2*DD-2*Ms+F) *ee^2;
  LatM := LatM + (0-2235*sin(L)+382*sin(a3)+175*sin(a1-F)
    +175*sin(a1+F)+127*sin(L-M)-115*sin(L+M)) / 1000000;
  // correzioni per la distanza dalla Terra (Δ)
  rr:=0;
  rr:= rr -20.905355 * cos(M); // coseni
  rr:= rr - 3.699111 * cos(2*DD-M); // evezione
  rr:= rr - 2.955968 * cos(2*DD); // variazione
  rr:= rr - 0.569925 * cos(2*M); // equazione del centro
  rr:= rr + 0.048888 * cos(Ms) *ee; // equazione annuale
  rr:= rr - 0.003149 * cos(2*F); // riduzione all'eclittica
  rr:= rr + 0.246158 * cos(2*DD-2*M);
  rr:= rr - 0.152138 * cos(2*DD-M-Ms) *ee;
  rr:= rr - 0.170733 * cos(2*DD+M);
  rr:= rr - 0.204586 * cos(2*DD-Ms) *ee;
  rr:= rr - 0.129620 * cos(Ms-M);
  rr:= rr + 0.108743 * cos(DD);
  rr:= rr + 0.104755 * cos(M+Ms) *ee;
  rr:= rr + 0.010321 * cos(2*DD-2*F);
  rr:= rr - 0.000000 * cos(M+2*F); // null
  rr:= rr + 0.079661 * cos(M-2*F);
  rr:= rr - 0.034782 * cos(4*DD-M);
  rr:= rr - 0.023210 * cos(3*M);
  rr:= rr - 0.021636 * cos(4*DD-2*M);
  rr:= rr + 0.024208 * cos(2*DD+Ms-M) *ee;
  rr:= rr + 0.030824 * cos(2*DD+Ms) *ee;
  rr:= rr - 0.008379 * cos(DD-M);
  rr:= rr - 0.016675 * cos(DD+Ms) *ee;
  rr:= rr - 0.012831 * cos(2*DD-Ms+M);
  rr:= rr - 0.010445 * cos(2*DD+2*M);
  rr:= rr - 0.011650 * cos(4*DD);
  rr:= rr + 0.014403 * cos(2*DD-3*M);
  rr:= rr - 0.007003 * cos(Ms-2*M) *ee;
  rr:= rr - 0.000000 * cos(2*DD-M+2*F); // null
  rr:= rr + 0.010056 * cos(2*DD-Ms-2*M) * ee;
  rr:= rr + 0.006322 * cos(DD+M);
  rr:= rr - 0.009884 * cos(2*DD-2*Ms) * ee;
  rr:= rr + 0.005751 * cos(Ms+2*M) *ee;
  rr:= rr - 0.000000 * cos(2*Ms) *ee^2; // null
  rr:= rr - 0.004950 * cos(2*DD-2*Ms-M) *ee^2;
  rr:= rr + 0.004130 * cos(2*DD+M-2*F);
  rr:= rr - 0.000000 * cos(2*DD+2*F); // null
  rr:= rr - 0.003958 * cos(4*DD-Ms-M) *ee;
  rr:= rr - 0.000000 * cos(2*M+2*F); // null
  rr:= rr + 0.003258 * cos(3*DD-M);
  rr:= rr + 0.002616 * cos(2*DD+Ms+M) *ee;
  rr:= rr - 0.001897 * cos(4*DD-Ms-2*M) *ee;
  rr:= rr - 0.002117 * cos(2*Ms-M) * ee^2;
  rr:= rr + 0.002354 * cos(2*DD+2*Ms-M) *ee^2;
  rr:= rr + 0.000000 * cos(2*DD+Ms-2*M) *ee; // null
  rr:= rr + 0.000000 * cos(2*DD-Ms-2*F) *ee; // null
  rr:= rr - 0.001423 * cos(4*DD+M);
  rr:= rr - 0.001117 * cos(4*M);
  rr:= rr - 0.001571 * cos(4*DD-Ms) *ee;
  rr:= rr - 0.001739 * cos(DD-2*M);
  rr:= rr - 0.000000 * cos(2*DD+Ms-2*F) *ee; // null
  rr:= rr - 0.004421 * cos(2*M-2*F);
  rr:= rr + 0.000000 * cos(DD+Ms+M) *ee; // null
  rr:= rr - 0.000000 * cos(3*DD-2*M); // null
  rr:= rr + 0.000000 * cos(4*DD-3*M); // null
  rr:= rr + 0.000000 * cos(2*DD-Ms+2*M) *ee; // null
  rr:= rr + 0.001165 * cos(2*Ms+M) *ee^2;
  rr:= rr + 0.000000 * cos(DD+Ms-M) *ee; // null
  rr:= rr + 0.000000 * cos(2*DD+3*M); // null
  rr:= rr + 0.008752 * cos(2*DD-M-2*F); // no sin
  b:= LatM; // Latitudine
  // dayY:= DDAYS(IP(thisday)+1/100+1/10000, thisday); // calc day number
  //  α:= (acos(cos(b)*cos(IFTE(LongM>180, LongM-180, LongM))/cos(δ))); // ascensione retta
  //IF LongM>180 THEN α:= α +180; END;
  α:= atan2(sin(LongM)*cos(ε)-tan(b)*sin(ε), cos(LongM));
  d:= 385000.56 + rr*1000; // Δ distanza Terra-Luna in km (=1/sin(P)),rr in 10^-3
  //P:= →HMS((0.9508+0.0518*cos(M)) MOD 360); // parallasse
  P:= asin(6378.14/d); // Parallasse
  CASE
  END; // case
  // età della Luna
  d1:= IP(HMS→(ph/15));
  h1:= IP(FP(HMS→(ph/15))*60);
  IF (h1>24) THEN d1:= d1+1; h1:= h1 MOD 24; END;
  m1:= IP(FP(FP(FP(HMS→(ph/15))*60))*60);
  eta:= →HMS(d1+h1/60+m1/3600); // Age of the Moon
  ill:= (1+cos(ph))/2; // illuminated fraction
  PRINT;
  PRINT("Ө Longitudine " + trunc_angle(LongM) + " " + segno);
  PRINT("λ Longitudine apparente "+ trunc_angle(lapp));
  PRINT("Δψ Nutazione long "+ dep(1));
  PRINT("Δε Nutazione obl. " + dep(2));
  PRINT("ε inclinazione ecl. " + ε);
  PRINT(" ");
  PRINT("");
  PRINT("TS (apparente) " + trunc_angle(ts(3)));
  PRINT("Δ Distanza Terra-Luna "+ ROUND(d,4) + " km");
  PRINT("Semidiametro "+  trunc_angle(→HMS(s)) + " :: " + ROUND(s*6378.14,3) + " km");
  PRINT(" ");
  PRINT("Parte illuminata " + ill);
  RETURN [[L, M],[LongM, LatM],[lapp,P], [ω,Ω],[α,δ], [az, h], [d,s], [sorg, tram], [culm, ts(1)],[ph, eta] ];
  // end Sun
  IF b> 360 THEN b:= b MOD 360; END;
  l:= atan2(y,x);
  segno:= zodiaco(l);
  PRINT;
  PRINT("");
Mercurius()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Venus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Mars()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Jupiter()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Saturn()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Uranus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Neptunus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Pluto()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
RE: Astronomy... - salvomic - 06-25-2015 05:35 PM
Marcel (and Manuel and others),
please, help me to find this problem now: I'm using for Sun and Moon the Meeus formulae mostly... If I calc Sun I get longitude almost equal to your program, if I calculate Moon I get the same results only if I use your app "at 0h time" (like {2015, 6, 25.0}) and not for the "justnow" time...
I'm trying using formulas like in your program, but including parameters (for sin and so on) into program, not in a variable...
Every numbers seems to be ok, but...
At the real local hour my program returns for Moon now some degrees of difference in longitude (with the first version was almost ok) if your app is used with "justnow" parameter; the same or so, if your is calculated at 0h...
So, the program could be in Julian day (but it seems to be ok) or in a global variable (I'm trying to put if off the program, as far as I can)...
Salvo
data();
calcN();
calcTS();
meanSideralTime();
apparentSideralTime();
julianDay();
julianEphemerisDay();
julianDayAtZero();
makeDateList();
makeDateListShort();
deltaEpsilonPsi();
epsilon();
transformEclipticalToEquatorial();
transformEquatorialToHorizontal();
transformEclipticalToHorizontal();
tempo();
precession();
parametri();
transit();
sunCalc();
planetCalc();
planets();
sun();
sunAh();
moon();
Mercurius();
Venus();
Mars();
Jupiter();
Saturn();
Uranus();
Neptunus();
Pluto();
ascendent();
zodiaco();
trunc_angle();
simp_angle();
atan2();
interpolation();
lstd:=0; gmt:= 12;
long:= 0; lat:=  0;
dateshortlist:= MAKELIST(X,X,1,3);
dateshortlistgmt:= MAKELIST(X,X,1,3);
// ε:= epsilon();  // approx 23.45 (23°26'21")
EXPORT Effemeridi()
  LOCAL ch, ε;
  HAngle:=1;
  ε:=epsilon();
  CASE
  IF ch==1 THEN sunCalc(); sun(); END;
  DEFAULT sunCalc(); sun();
  END; // case
data()
  LOCAL t, JD, JDE, ε, dep, eps;
  yy:= IP(Date);
  dateshortlist:= {Y, m, D+HMS→(lstd)/24};
  dateshortlistgmt:= {Y, m, D+HMS→(gmt)/24};
  JD:= julianDay(dateshortlist);
  JDE:= julianEphemerisDay(dateshortlist);
  T:=(JD-2451545)/36525;
  U:= T/100;
  ε:=epsilon(); // (formula IAU J2000.0)
  sunCalc();
epsilon()
LOCAL ε, ε0, dep, eps, JD, JDE, U;
  U:= T/100;
  ε0:= 23°26′21.448″ - 1°18′00.93″*U-1.55*U^2+1999.25*U^3-51.38*U^4-249.67*U^5;
  ε0:= ε0-39.05*U^6+7.12*U^7+27.87*U^8+5.79*U^9+2.45*U^10; // Laskar, Meeus
  ε0:= →HMS(ε0);
  eps:= dep(2);
  ε:= ε0+eps; // true obliquity ε
  RETURN ε;
deltaEpsilonPsi()
  LOCAL Lmoon, Lsun, deltaPsi, deltaEpsilon, Ωmoon, JD, JDE;
  LOCAL DD;
  JD:= julianDayAtZero(Y,m,D);
  T:= (JDE-2451545)/36525; // use JDE
  DD:=297.85036+445267.111480*T-0.0019142*T^2+(T^3)/189474;  // elongazione
  DD:=FP(DD/360)*360;
  Ωmoon:= 125.04452-1934.136261*T-0.0020708*T^2+(T^3)/450000; // Nodo Luna (Moon)
  Lsun:= simp_angle(280.46645+36000.76983*T+0.0003032*T^2); // Long media Sole
  Lmoon:= simp_angle(218.3164591+481267.88134236*T-0.0013268*T^2+T^3/538841-T^4/65194000);
  //  Long media Luna
  deltaPsi:= (-0°0′17.20″)*sin(Ωmoon)-(0°0′1.32″)*sin(2*Lsun)+(-0°0′0.23″)*sin(2*Lmoon)+(0°0′0.21″)*sin(2*Ωmoon);
  deltaEpsilon:= (0°0′9.2″)*cos(Ωmoon)+(0°0′0.57″)*cos(2*Lsun)+(0°0′0.10″)*cos(2*Lmoon)-(0°0′0.09″)*cos(2*Ωmoon);
planets()
  "Choose planet",
transformEclipticalToEquatorial(lambda, beta)
  // trasnform λ and β (long, lat) into α and δ (Asc retta, decl)
  LOCAL ε,Epsilon,Lambda, Beta, alpha, delta;
  Lambda:=HMS→(lambda);
  Beta:=HMS→(beta);
  Epsilon:= epsilon();
  ε:= epsilon();
  alpha:=atan2(sin(Lambda)*cos(Epsilon)-tan(Beta)*sin(Epsilon),cos(Lambda));
  IF alpha>=360 THEN alpha:=alpha-360 END;
  IF alpha<0 THEN alpha:=alpha+360 END;
  delta:=asin(sin(Beta)*cos(Epsilon)+cos(Beta)*sin(Epsilon)*sin(Lambda));
  alpha:=→HMS(alpha/15);
  delta:=→HMS(delta);
  RETURN ({alpha,delta});
transformEquatorialToHorizontal(Lha, Phi, Delta)
  LOCAL azimuth,altitude,lha,phi,delta;
  lha:=HMS→(Lha);
  phi:=HMS→(Phi);   // latitude
  delta:=HMS→(Delta);
  azimuth:=atan2(sin(lha),cos(lha)*sin(phi)-tan(delta)*cos(phi));
  altitude:=asin(sin(phi)*sin(delta)+cos(phi)*cos(delta)*cos(lha));
  azimuth:=→HMS(azimuth);
  altitude:=→HMS(altitude);
  RETURN({azimuth,altitude});
transformEclipticalToHorizontal(Lambda, Beta, Lha)
  LOCAL ε;
  // transform λ and β (long, lat) into azimuth and height
  LOCAL lambda, beta, epsilon,phi, lha;
  LOCAL alpha,delta,azimuth,altitude;
  lambda:=HMS→(Lambda); // longitudine astro
  beta:=HMS→(Beta); // latitudine astro
  epsilon:= epsilon();
  ε:= epsilon();
  lha:=HMS→(Lha);  // angolo orario
  phi:=HMS→(lat); // lat geo
  alpha:=atan2(SIN(lambda)*COS(epsilon)-TAN(beta)*SIN(epsilon),COS(lambda));
  delta:=asin(sin(beta)*cos(epsilon)+cos(beta)*sin(epsilon)*sin(lambda));
  azimuth:=atan2(SIN(lha),COS(lha)*SIN(phi)-TAN(delta)*COS(phi));
  altitude:=ASIN(SIN(phi)*SIN(delta)+COS(phi)*COS(delta)*COS(lha));
  RETURN ({azimuth,altitude});
calcN()
  RETURN N;
calcTS()
  LOCAL T, TS, TSd, N0, TSL, TSapp, ε;
  LOCAL θ0, θ0GMT, JD, JDE, JD0, dep, psi, eps;
  ε:= epsilon;
  calcN();
  JD0:= julianDayAtZero(Y,m,D);
  psi:=dep(1);
  eps:=dep(2);
  T:= (JD-2451545.0)/36525;
  θ0:= meanSideralTime(dateshortlist); // MST DEG at 0h
  θ0GMT:= meanSideralTime({Y,m,D}); // MST DEG at 0h at Greenwitch
  // TS:=  ((23750.3 + 236.555362*N) / 3600) MOD 24; // Sideral Time (GMT) in seconds
  // TS:= →HMS(TS); // in HMS
  TS:= θ0GMT;
  // TSL:= (TS + gmt - 4*(HMS→(long))/60) MOD 24; // local ST
  // TSL:= →HMS(TSL); // in HMS
  TSapp:= apparentSideralTime(dateshortlist); // apparent ST (ST at Greenwitch at local our)
TSL:= apparentSideralTime(dateshortlist) - 1*dst;
  RETURN {TS, TSL, TSapp, θ0, T};
meanSideralTime(lista)
// lista like dateshortlist
  LOCAL T,MST, JD, ε;
  ε:= epsilon;
  JD:= julianDay(lista);
  T:=(julianDay(lista)-2451545.0)/36525;
  MST:=280.46061837+360.98564736629*(JD-2451545.0)+0.000387933*T^2-(T^3)/38710000;
  MST:=FP(MST/360)*360; // θ0
  IF MST<0 THEN MST:=MST+360 END;
  MST:=→HMS(MST/15);
  RETURN MST;
apparentSideralTime(lista)
  LOCAL MST,correction, deltaPsi, AST, dep, ε;
  ε:= epsilon;
  MST:= meanSideralTime(lista);
  deltaPsi:= dep(1);
  correction:=(HMS→(deltaPsi)*3600*COS(HMS→(ε)))/15;
  AST:=→HMS(HMS→(MST)+(correction/3600));
  RETURN AST;
julianDay(lista)
  LOCAL y,m,d,a,b, JD;
  y:=lista(1);
  m:=lista(2);
  d:=lista(3);
  y:=y-1;
  m:=m+12
  IF y*100+m+d>=158225 THEN
  a:=IP(ABS(y/100));
  b:=2-a+IP(a/4);
  ELSE
  b:=0
  JD:=IP(365.25*(y+4716))+IP(30.6001*(m+1))+d+b-1524.5;
  RETURN JD;
julianEphemerisDay(lista)
  LOCAL JDE;
  JDE:=julianDay(makeDateListShort(makeDateList(lista)+{0,0,0,0,0,deltaT}));
  RETURN JDE;
  // JD at 0h GMT
  LOCAL y,mm,d,a,b, JD;
  y:=Y;
  mm:=m;
  d:=dateshortlist(3);
  IF (mm=1 OR mm=2) THEN
  y:=y-1;
  mm:=mm+12
  IF y*100+mm+d>=158225 THEN
  a:=IP(ABS(y/100));
  b:=2-a+IP(a/4);
  ELSE
  b:=0
  JD:=IP(365.25*(y+4716))+IP(30.6001*(mm+1))+d+b-1524.5;
  RETURN JD;
makeDateList(lista)
// lista {Y m D.d} (dateshortlist)
LOCAL y,o,m,d,h,s,t;
y:=lista(1);
o:=lista(2);
d:=IP(lista(3));
t:=FP(lista(3));
h:=IP(t*24);
t:=FP(t*24);
m:=IP(t*60);
t:=FP(t*60);
s:=IP(t*60);
lista:={y,o,d,h,m,s};
RETURN lista;
makeDateListShort(lista)
// lista {Y m D h mn, s}
LOCAL y,m,d, listacorta;
y:=lista(1);
m:=lista(2);
d:=lista(3)+lista(4)/24+lista(5)/1440+lista(6)/86400;
listacorta:={y,m,d};
RETURN listacorta;
tempo()
  LOCAL n, JD, JDE, TSid, dep, psi, eps;
  LOCAL ε;
  ε:= epsilon();
  n:= calcN();
  TSid:= calcTS();
  psi:=dep(1);
  eps:=dep(2);
  PRINT;
  PRINT("Julian Day " + JD);
  PRINT("Julian Day Effem. " + JDE);
  PRINT("T (from JD) " + TSid(5));
  PRINT(" ");
  PRINT("Tempo Siderale 0h " + →HMS(TSid(1)));
  PRINT("Tempo Siderale locale " + →HMS(TSid(2)));
  PRINT("Tempo Siderale apparente " + →HMS(TSid(3)));
  PRINT("θ0 Mean ST GMT " + →HMS(TSid(4)));
  PRINT("Tempo Siderale (DEG) " + trunc_angle(TSid(1)*15));
  PRINT("θ0 Mean ST GMT (DEG) " + trunc_angle(TSid(4)*15));
  PRINT(" ");
  PRINT("Δψ Nutazione (longit.) "+ psi);
  PRINT("Δε Nutazione (obl.) "+ eps);
  PRINT("ε Obliquità Ecl. "+ ε);
  PRINT(" ");
  RETURN({ROUND(JD,5), ROUND(JDE,5), trunc_angle(TSid(1)), trunc_angle(TSid(2)),
transit(alfa, delta, h, h0)
// α, δ (AR, dec), height, h0 = standard height of body
  LOCAL temp, H0, tsideral, Hor, m0, m1, m2;
  LOCAL α, δ, θ0,ts, culm, sorg, tram, deltaM;
  α:= alfa*15; // DEG
  δ:= delta;
  θ0:= apparentSideralTime(makeDateListShort({Y,m,D,0,0,0})) *15; // TS in DEG
  ts:= calcTS();
  // θ0:= ts(2)*15; // TS=θ00 GMT
  IF temp<-1 OR temp>1 THEN culm:=0; END; // above horizon?
  H0:= acos(temp);
  IF H0<-180 THEN H0:=H0+180; END; IF H0>180 THEN H0:= H0-180; END; // it should be from -180 to 180
  Hor:=15*HMS→(ts(2)-α);  // Hour angle, local ST vs apparent ST
  Hor:=simp_angle(→HMS(Hor));
  // Hor:= simp_angle(tsideral - long - α);
  m0:= HMS→(α + long - θ0) / 360;
  tsideral:= simp_angle(θ0 + 360.985647*m0); // TS transit DEG
  deltaM:= -HMS→(H/360);
  culm:= (m0 + deltaM)*24;  // transit
  m1:= m0-H0/360;
  IF m1<0 THEN m1:= m1 +1; END; IF m1>1 THEN m1:=m1-1; END;
  tsideral:= simp_angle(θ0 + 360.985647*m1); // TS rising
  deltaM:= HMS→((h-h0)/(360*cos(δ)*cos(lat)*sin(Hor)));
  sorg:= ((m1 + deltaM)*24) MOD 24; // rising
  m2:= m0+H0/360;
  IF m2<0 THEN m2:= m2 +1; END; IF m2>1 THEN m2:=m2-1; END;
  tsideral:= simp_angle(θ0 + 360.985647*m2); // TS setting
  tram:= ((m2 + deltaM) * 24) MOD 24; // setting
RETURN ({culm, sorg, tram});
parametri()
  LOCAL dep, prec, α, δ, ε;
  ε:= epsilon();
  PRINT;
  PRINT("ε Obliquità eclittica "+ ε);
  PRINT(" ");
ascendent()
  LOCAL ASC, ts, segno, ε;
  ε:= epsilon;
  ts:= calcTS();
  ASC:= simp_angle(ASC);
RETURN {trunc_angle(→HMS(ASC)), trunc_angle(→HMS(ASC) MOD 30), segno};
zodiaco(astro)
  LOCAL segno;
  END; // case
  RETURN segno;
atan2(y,x)
  CASE
  RETURN;
trunc_angle(ang)
simp_angle(ang)
LOCAL angle;
IF angle<0
THEN
angle:=angle+360
RETURN angle;
kepler(ec, M)
  LOCAL M1, j, u;
  HAngle:=0; // RAD
  F:= 1;
  u:= PI/2; D:=PI/4;
  END; // for
  HAngle:=1;
  u:= u*180/PI;
  RETURN u;
interpolation(lista,n)
LOCAL a,b,c,R,dif1,dif2;
dif1:=ΔLIST(lista);
dif2:=ΔLIST(dif1);
a:=dif1(1);
b:=dif1(2);
c:=dif2(1);
R:=lista(2)+(n/2)*(a+b+n*c);
RETURN R;
sunCalc()
  LOCAL ω, l, v, r, x, y, dz, ε;
  LOCAL ec, a, u, M1, M2, j, t, tau;
  LOCAL JD, JDE, c, lapp, Ω, θ0, transito;
  LOCAL dep, deltapsi, longitude;
  ε:= epsilon;
  N:= calcN();
  deltapsi:= dep(1);
  t:= N/36525;
  tau:= (JDE-2451545.0)/365250; // millenni  - JDE
  // L:= →HMS(278.9654+0.985647342*N + 0.0003*t^2) MOD 360; // long media Bouiges
  // L:= simp_angle(280.46645+36000.76983*T+0.0003032*T^2); // Long media Meeus
  L:= simp_angle(280.4664567+360007.6982779*tau+0.03032028*tau^2+(tau^3)/49931-(tau^4)/15299-(tau^5)/1988000);
  Ω:= simp_angle(125.04-1934.136*T); // Nutazione e aberrazione (nodo)
  M:= simp_angle(357.52910+35999.05030*T+0.0001559*T^2-0.00000048*T^3); // anom vera Meeus
  c:= (1.914600-0.004817*T-0.000016*T^2)*sin(M);  // equation of center
  c:= c+(0.019993-0.000101*T)*sin(2*M)+(0.000290)*sin(3*M);
  l:= simp_angle(L+c); // Ө Longitudine Sole, Meeus
  lapp:= simp_angle(l - 0.00569-0.00478*sin(Ω)); // Longitudine apparente (ref true equinox)
 // H:= (ts(2) - α) MOD 24; // Angolo orario
 // Hd:= →HMS(15*H); // Angolo orario in gradi
  // longitude:=-HMS→(long); // - if long -E
  Hd:=15*HMS→(ts(2)-α);  // local ST vs apparent ST
  IF Hd<0 THEN Hd:=Hd+360 END;
  IF Hd>=360 THEN Hd:=Hd-360 END;
  Hd:=→HMS(Hd);
  H:= Hd/15; // in HMS
  temp:= sunAh(dateshortlist);
  az:= temp(1);
  h:=  temp(2);
  // E:= →HMS((460*sin(M)-592*sin(2*L))/60); // equazione del tempo in min (460s, 592s)
  E:= 4*( L - 0.0057183 - α*15 + deltapsi*cos(ε) );  // α in DEG
   // culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) ; // Culminazione, transito (Bouiges)
   // sorg:= (culm - SAD/15) MOD 24; // Alba (Dawn)
   // tram:= (culm + SAD/15) MOD 24; // Tramonto (Sunset)
  // transit routine
  transito:= transit(α, δ, h, h0);
  culm:= transito(1);
  sorg:= transito(2);
  tram:= transito(3);
  // end transit
  RETURN sunlist;
sun()
  LOCAL α, δ, dayY, ts, az, z, h;
  LOCAL as, ac, zc, segno, JD, JDE, v, c;
  LOCAL Ω, lapp, ec;
  ε:= epsilon;
  ts:= calcTS(); //
  ec:= sunlist(28);
  segno:= zodiaco(l);
  PRINT;
  PRINT("");
  PRINT("M anomalia media " + trunc_angle(M));
  PRINT("v anomalia vera " + trunc_angle(v));
  PRINT(" ");
  PRINT("Ө Longitudine Sole " + trunc_angle(l) + " (" +trunc_angle(l MOD 30) + " " + segno + ")");
  PRINT(" ");
  PRINT("α Asc.r. (DEG) " + trunc_angle(α*15));
  PRINT(" ");
  PRINT("TS apparente " + ts(3));
  PRINT("θ0 Mean ST GMT " + ts(4));
  PRINT("Julian day " + JD);
  PRINT("");
  PRINT("Transita a: " + trunc_angle(culm) + " UTC (" + trunc_angle((culm+utc+dst) MOD 24) + " loc)");
  PRINT("Sorge a: " + trunc_angle(sorg) + " UTC (" + trunc_angle((sorg+utc+dst) MOD 24) + " loc)");
  PRINT("Tramonta a: " + trunc_angle(tram) + " UTC (" + trunc_angle((tram+utc+dst) MOD 24) + " loc)");
  PRINT(" ");
  PRINT("ε obliquità ecl. " + ε);
sunAh(lista)
  LOCAL lha,alpha,delta,phi, ah, α;
  LOCAL temp,longitude, Azimuth, Altitude, ts;
  alpha:=15*HMS→(sunlist(5));
  α:= sunlist(5); // α in HMS
  delta:=sunlist(6);
  phi:=lat;
  ts:= calcTS();
  // longitude:= HMS→(long); // - if long -E
  // lha:=(15*HMS→(apparentSideralTime(lista))-longitude-alpha);
  lha:= 15*HMS→(ts(2)-α);  // local ST vs apparent ST;
  IF lha<0 THEN lha:=lha+360 END;
  IF lha>=360 THEN lha:=lha-360 END;
  lha:=→HMS(lha);
  temp:= transformEquatorialToHorizontal(lha, phi, delta);
  Azimuth:= HMS→(temp(1))+180;
  IF Azimuth>360 THEN Azimuth:=Azimuth-360 END;
  Azimuth:= →HMS(Azimuth);
  Altitude:= temp(2);
  ah:= {Azimuth,Altitude};
  RETURN ah;
moon()
  LOCAL ω,Ω, L1, M1, l, lsum, bsum, rsum;
  LOCAL v, r, x, y, dep, ε;
  LOCAL b, P, d, s, temp;
  LOCAL i, as, ac, DA, SAD, DD;
  LOCAL culm, sorg, tram, h0, transito;
  LOCAL xs, ys, ph, fase, eta;
  LOCAL d1, h1, m1, segno, JD, JDE, rr;
  LOCAL lapp, ill, ee, a1,a2,a3, longitude;
  ε:= epsilon();
  N:= calcN();
  T:= (JDE-2451545.0)/36525; // use JDE
  // Sun
  L:= simp_angle(280.4665+36000.76983*T+0.0003032*T^2); // Long media Sole Meeus
  M:= simp_angle(357.5291092+35999.0502909*T-0.0001536*T^2+T^3/24490000); // mean anomaly Sun
  // end Sun
  // L1:= (33.231 + 13.17639653*N) MOD 360; // long. media
  L1:= simp_angle(218.3164591+481267.88134236*T-0.0013268*T^2+T^3/538841-T^4/65194000);
  Ω:= simp_angle(125.04452-1934.136261*T-0.0020708*T^2+(T^3)/450000); // Nodo Luna (Moon)
  // M1:= (18.294 + 13.06499245*N) MOD 360; // anomalia vera
  M1:= simp_angle(134.9634114+477198.8676313*T+0.0089970*T^2+T^3/69699-T^4/14712000); // anomalia media
  ω:= (L1 - M1) MOD 360; // perigeo medio
  // DD:= L1 - L; F:= L1-Ω; // for the variations
  DD:= simp_angle(297.8502042+445267.1115168*T-0.0016300*T^2+T^3/545868-T^4/113065000); // mean elongation
  F:= simp_angle(93.2720993+483202.0175273*T-0.0034029*T^2-T^3/3526000+T^4/863310000); // dist from asc. node
  // ee:= 1-0.002516*T-0.0000074*T^2;  // multiply those w/ M *ee
  a1:= simp_angle(119.75+131.849*T); // action of Venus
  a2:= simp_angle(53.09+479264.290*T); // action of Jupiter
  a3:= simp_angle(313.45+481266.484*T);
  lsum:=0;  // da sommare a L1
  lsum:= lsum + 6288774 * sin(M1); // calc Moon longitude
  lsum:= lsum + 1274027 * sin(2*DD-M1); // evezione
  lsum:= lsum +  658314 * sin(2*DD); // variazione
  lsum:= lsum +  213618 * sin(2*M1); // equazione del centro
  lsum:= lsum -  185116 * sin(M) *ee; // equazione annuale
  lsum:= lsum -  114332 * sin(2*F); // riduzione all'eclittica
  lsum:= lsum +   58793 * sin(2*DD-2*M1);
  lsum:= lsum +   57066 * sin(2*DD-M1-M) *ee;
  lsum:= lsum +   53322 * sin(2*DD+M1);
  lsum:= lsum +   45758 * sin(2*DD-M) *ee;
  lsum:= lsum -   40923 * sin(M-M1) *ee;
  lsum:= lsum -   34720 * sin(DD);
  lsum:= lsum -   30383 * sin(M1+M) *ee;
  lsum:= lsum +   15327 * sin(2*DD-2*F);
  lsum:= lsum -   12528 * sin(M1+2*F);
  lsum:= lsum +   10980 * sin(M1-2*F);
  lsum:= lsum +   10675 * sin(4*DD-M1);
  lsum:= lsum +   10034 * sin(3*M1);
  lsum:= lsum +    8548 * sin(4*DD-2*M1);
  lsum:= lsum -    7888 * sin(2*DD+M-M1) *ee;
  lsum:= lsum -    6766 * sin(2*DD+M) *ee;
  lsum:= lsum -    5163 * sin(DD-M1);
  lsum:= lsum +    4987 * sin(DD+M) *ee;
  lsum:= lsum +    4036 * sin(2*DD-M+M1) *ee;
  lsum:= lsum +    3994 * sin(2*DD+2*M1);
  lsum:= lsum +    3861 * sin(4*DD);
  lsum:= lsum +    3665 * sin(2*DD-3*M1);
  lsum:= lsum -    2689 * sin(M-2*M1) *ee;
  lsum:= lsum -    2602 * sin(2*DD-M1+2*F);
  lsum:= lsum +    2390 * sin(2*DD-M-2*M1) *ee;
  lsum:= lsum -    2348 * sin(DD+M1);
  lsum:= lsum +    2236 * sin(2*DD-2*M) *ee^2;
  lsum:= lsum -    2120 * sin(M+2*M1) *ee;
  lsum:= lsum -    2069 * sin(2*M) *ee^2;
  lsum:= lsum +    2048 * sin(2*DD-2*M-M1) *ee^2;
  lsum:= lsum -    1773 * sin(2*DD+M1-2*F);
  lsum:= lsum -    1595 * sin(2*DD+2*F);
  lsum:= lsum +    1215 * sin(4*DD-M-M1) *ee;
  lsum:= lsum -    1110 * sin(2*M1+2*F);
  lsum:= lsum -     892 * sin(3*DD-M1);
  lsum:= lsum -     810 * sin(2*DD+M+M1) *ee;
  lsum:= lsum +     759 * sin(4*DD-M-2*M1) *ee;
  lsum:= lsum -     713 * sin(2*M-M1) * ee^2;
  lsum:= lsum -     700 * sin(2*DD+2*M-M1) *ee^2;
  lsum:= lsum +     691 * sin(2*DD+M-2*M1) *ee;
  lsum:= lsum +     596 * sin(2*DD-M-2*F) *ee;
  lsum:= lsum +     549 * sin(4*DD+M1);
  lsum:= lsum +     537 * sin(4*M1);
  lsum:= lsum +     520 * sin(4*DD-M) *ee;
  lsum:= lsum -     487 * sin(DD-2*M1);
  lsum:= lsum -     399 * sin(2*DD+M-2*F) *ee;
  lsum:= lsum -     381 * sin(2*M1-2*F);
  lsum:= lsum +     351 * sin(DD+M+M1) *ee;
  lsum:= lsum -     340 * sin(3*DD-2*M1);
  lsum:= lsum +     330 * sin(4*DD-3*M1);
  lsum:= lsum +     327 * sin(2*DD-M+2*M1) *ee;
  lsum:= lsum -     323 * sin(2*M+M1) *ee^2;
  lsum:= lsum +     299 * sin(DD+M-M1) *ee;
  lsum:= lsum +     294 * sin(2*DD+3*M1);
  lsum:= lsum + 3958*sin(a1)+1962*sin(L1-F)+318*sin(a2);
  l:= (simp_angle(L1 + lsum/1000000)); // λ divided by 1 milion
  lapp:= →HMS(l + dep(1)); // longitudine apparente (+ nutazione long, Δψ)
  // fattori per latitudine
  bsum:=        5128122 * sin(F); // termine principale latitudine
  bsum:= bsum +  280026 * sin(M1+F);
  bsum:= bsum +  277693 * sin(M1-F); // equazione del centro
  bsum:= bsum +  173237 * sin(2*DD-F); // grande ineguaglianza
  bsum:= bsum +   55413 * sin(2*DD-M1+F); // evezione
  bsum:= bsum +   46271 * sin(2*DD-M1-F); // evezione (2)
  bsum:= bsum +   32573 * sin(2*DD+F);
  bsum:= bsum +   17198 * sin(2*M1+F);
  bsum:= bsum +    9266 * sin(2*D+M1-F);
  bsum:= bsum +    8822 * sin(2*M1-F);
  bsum:= bsum +    8216 * sin(2*DD-M-F) *ee;
  bsum:= bsum +    4324 * sin(2*DD-2*M1-F);
  bsum:= bsum +    4200 * sin(2*DD+M1+F);
  bsum:= bsum -    3359 * sin(2*DD+M-F) *ee;
  bsum:= bsum +    2463 * sin(2*DD-M-M1+F) *ee;
  bsum:= bsum +    2211 * sin(2*DD-M+F) *ee;
  bsum:= bsum +    2065 * sin(2*DD-M-M1-F) *ee;
  bsum:= bsum -    1870 * sin(M-M1-F) *ee;
  bsum:= bsum +    1828 * sin(4*DD-M1-F);
  bsum:= bsum -    1794 * sin(M+F) *ee;
  bsum:= bsum -    1749 * sin(3*F);
  bsum:= bsum -    1565 * sin(M-M1+F) *ee;
  bsum:= bsum -    1491 * sin(DD+F);
  bsum:= bsum -    1475 * sin(M+M1+F) *ee;
  bsum:= bsum -    1410 * sin(M+M1-F) *ee;
  bsum:= bsum -    1344 * sin(M-F) *ee;
  bsum:= bsum -    1335 * sin(DD-F);
  bsum:= bsum +    1107 * sin(3*M1+F);
  bsum:= bsum +    1021 * sin(4*DD-F);
  bsum:= bsum +     833 * sin(4*DD-M1+F);
  bsum:= bsum +     777 * sin(M1-3*F);
  bsum:= bsum +     671 * sin(4*DD-2*M1+F);
  bsum:= bsum +     607 * sin(2*DD-3*F);
  bsum:= bsum +     596 * sin(2*DD+2*M1-F);
  bsum:= bsum +     491 * sin(2*DD-M+M1-F) *ee;
  bsum:= bsum -     451 * sin(2*DD-2*M1+F);
  bsum:= bsum +     439 * sin(3*M1-F);
  bsum:= bsum +     422 * sin(2*DD+2*M1+F);
  bsum:= bsum +     421 * sin(2*DD-3*M1-F);
  bsum:= bsum -     366 * sin(2*DD+M-M1+F) *ee;
  bsum:= bsum -     351 * sin(2*DD+M+F) *ee;
  bsum:= bsum +     331 * sin(4*DD+F);
  bsum:= bsum +     315 * sin(2*DD-M+M1+F) *ee;
  bsum:= bsum +     302 * sin(2*DD-2*M-F) *ee^2;
  bsum:= bsum -     283 * sin(M1+3*F);
  bsum:= bsum -     229 * sin(2*DD+M+M1-F) *ee;
  bsum:= bsum +     223 * sin(DD+M-F) *ee;
  bsum:= bsum +     223 * sin(DD+M+F) *ee;
  bsum:= bsum -     220 * sin(M-2*M1-F) *ee;
  bsum:= bsum -     220 * sin(2*DD+M-M1-F) *ee;
  bsum:= bsum -     185 * sin(DD+M1+F);
  bsum:= bsum +     181 * sin(2*DD-M-2*M1-F) *ee;
  bsum:= bsum -     177 * sin(M+2*M1+F) *ee;
  bsum:= bsum +     176 * sin(4*DD-2*M1-F);
  bsum:= bsum +     166 * sin(4*DD-M-M1-F) *ee;
  bsum:= bsum -     164 * sin(DD+M1-F);
  bsum:= bsum +     132 * sin(4*DD+M1-F);
  bsum:= bsum -     119 * sin(DD-M1-F);
  bsum:= bsum +     115 * sin(4*DD-M-F) *ee;
  bsum:= bsum +     107 * sin(2*DD-2*M+F) *ee^2;
  bsum:= bsum-2235*sin(L1)+382*sin(a3)+175*sin(a1-F)+175*sin(a1+F)+127*sin(L1-M1)-115*sin(L1+M1);
  b := →HMS(bsum/1000000); // β div by 1 milion
  rsum:=0;
  rsum:= rsum -20905355 * cos(M1); // coseni
  rsum:= rsum - 3699111 * cos(2*DD-M1); // evezione
  rsum:= rsum - 2955968 * cos(2*DD); // variazione
  rsum:= rsum -  569925 * cos(2*M1); // equazione del centro
  rsum:= rsum +   48888 * cos(M) *ee; // equazione annuale
  rsum:= rsum -    3149 * cos(2*F); // riduzione all'eclittica
  rsum:= rsum +  246158 * cos(2*DD-2*M1);
  rsum:= rsum -  152138 * cos(2*DD-M1-M) *ee;
  rsum:= rsum -  170733 * cos(2*DD+M1);
  rsum:= rsum -  204586 * cos(2*DD-M) *ee;
  rsum:= rsum -  129620 * cos(M-M1) *ee;
  rsum:= rsum +  108743 * cos(DD);
  rsum:= rsum +  104755 * cos(M1+M) *ee;
  rsum:= rsum +   10321 * cos(2*DD-2*F);
  rsum:= rsum +   79661 * cos(M1-2*F);
  rsum:= rsum -   34782 * cos(4*DD-M1);
  rsum:= rsum -   23210 * cos(3*M1);
  rsum:= rsum -   21636 * cos(4*DD-2*M1);
  rsum:= rsum +   24208 * cos(2*DD+M-M1) *ee;
  rsum:= rsum +   30824 * cos(2*DD+M) *ee;
  rsum:= rsum -    8379 * cos(DD-M1);
  rsum:= rsum -   16675 * cos(DD+M) *ee;
  rsum:= rsum -   12831 * cos(2*DD-M+M1) *ee;
  rsum:= rsum -   10445 * cos(2*DD+2*M1);
  rsum:= rsum -   11650 * cos(4*DD);
  rsum:= rsum +   14403 * cos(2*DD-3*M1);
  rsum:= rsum -    7003 * cos(M-2*M1) *ee;
  rsum:= rsum +   10056 * cos(2*DD-M-2*M1) * ee;
  rsum:= rsum +    6322 * cos(DD+M1);
  rsum:= rsum -    9884 * cos(2*DD-2*M) * ee^2;
  rsum:= rsum +    5751 * cos(M+2*M1) *ee;
  rsum:= rsum -    4950 * cos(2*DD-2*M-M1) *ee^2;
  rsum:= rsum +    4130 * cos(2*DD+M1-2*F);
  rsum:= rsum -    3958 * cos(4*DD-M-M1) *ee;
  rsum:= rsum +    3258 * cos(3*DD-M1);
  rsum:= rsum +    2616 * cos(2*DD+M+M1) *ee;
  rsum:= rsum -    1897 * cos(4*DD-M-2*M1) *ee;
  rsum:= rsum -    2117 * cos(2*M-M1) * ee^2;
  rsum:= rsum +    2354 * cos(2*DD+2*M-M1) *ee^2;
  rsum:= rsum -    1423 * cos(4*DD+M1);
  rsum:= rsum -    1117 * cos(4*M1);
  rsum:= rsum -    1571 * cos(4*DD-M) *ee;
  rsum:= rsum -    1739 * cos(DD-2*M1);
  rsum:= rsum -    4421 * cos(2*M1-2*F);
  rsum:= rsum +    1165 * cos(2*M+M1) *ee^2;
  rsum:= rsum +    8752 * cos(2*DD-M1-2*F);
  rsum:= rsum/1000;  // div by 1000
  temp:= transformEclipticalToEquatorial(l,b);  // transform into AR, decl
  α:= temp(1);
  δ:= temp(2);
  ts:= calcTS();  // calcola tempo siderale
  //H:= (ts(2) - α) MOD 24; // Angolo orario
  //    // H:= asin(-tan(lat)*tan(δ));
  //Hd:= →HMS(15*H); // Angolo orario in gradi
  Hd:=15*HMS→(apparentSideralTime(dateshortlist))-longitude-α;
  Hd:=→HMS(Hd);
  H:= Hd/15;
  temp:= transformEquatorialToHorizontal(Hd, lat, δ);
  //temp:= azimuthFromLBPhi(l, b, Hd);
  az:= temp(1);
  h:= temp(2);
  d:= (385000.56 + rsum); // Δ distanza Terra-Luna in km (=1/sin(P)),rr in 10^-3
  DA:= asin(tan(lat)*tan(δ)); // Differenza ascensionale
  SAD:= (90 + DA); // Semiarco Diurno
    // culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) ; // Culminazione (Bouiges)
    // tram:= (culm + SAD/15) MOD 24; // Tramonto (Set)
  // transit routine
  h0:= 0.7275*P -0°34′; // 'standard' altitude of Moon (depend on parallax)
  // h0:= 0°7′30″; // medium value: 0.125°
  culm:= transito(1);
  sorg:= transito(2);
  tram:= transito(3);
  // end transit
  ph:= abs(l - L); // Phase  Moon-Sun
  CASE
  END; // case
  // età della Luna
  segno:= zodiaco(l);
  PRINT;
  PRINT("L Long media " + trunc_angle(L1));
  PRINT("M anomalia vera " + trunc_angle(M1));
  PRINT("Ө Longitudine " + trunc_angle(l) + " (" + trunc_angle(l MOD 30) + " " + segno + ")");
  PRINT("β Latitudine " + trunc_angle(b));
  PRINT(" ");
  PRINT("α Asc. r. "+ trunc_angle(α) + " δ Decl. "+ trunc_angle(δ));
  PRINT("Az Azimuth " + trunc_angle(az) + " h Alt. " + trunc_angle(h));
  PRINT("");
  PRINT("TS (UTC) " + trunc_angle(ts(1)));
  PRINT("θ0 Mean ST GMT " + trunc_angle(ts(5)));
  PRINT(" ");
  PRINT(" ");
  RETURN [[L1, M1],[l, b],[lapp,P], [ω,Ω],[α,δ], [az, h],
    [ROUND(HMS→(d),6),s], [sorg, tram], [culm, ts(3)],[ph, eta] ];
planetCalc(nameplanet)
  LOCAL as, ac, zc, dz, θ, mov, segno, ε;
  Ls:= sunlist(1); // Longitudine media
  Ms:= sunlist(4); // Anomalia
  // end Sun
  l:= atan2(y,x);
  // δ:= →HMS((ε*sin((360*(284+dayY))/365)) MOD 360); // declinazione, formula di Cooper
  α:= →HMS(α/15) MOD 24; // α in hms
  zc:= sin(lat)*sin(δ)+cos(lat)*cos(δ)*cos(Hd); // calc z, alt
  dz:= →HMS(acos(zc)) ; // distanza zenitale :: h:= →HMS(90 - dz); // Altezza
  h:= →HMS(ATAN(zc/sqrt(1-zc^2))); // Altezza (height)
  as:= cos(δ)*sin(Hd)/sin(dz); // calc az
  ac:= (-cos(lat)*sin(δ)+sin(lat)*cos(δ)*cos(Hd))/sin(dz);
  // az:= →HMS(ATAN(as/ac) ); // Azimuth
  IF az<0 THEN az:= az+360; END; IF az>360 THEN az:=az-360; END;
  // SAD:= acos(-tan(lat)*tan(δ)); // Semiarco Diurno
  segno:= zodiaco(l);
  PRINT;
  PRINT("Spher.: λ Longitudine " + trunc_angle(l) + " (" +trunc_angle(l MOD 30) + " " + segno + ")");
  PRINT("");
Mercurius()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Venus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Mars()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Jupiter()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Saturn()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Uranus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Neptunus()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
Pluto()
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  calcN();
RE: Astronomy... - salvomic - 06-27-2015 05:51 PM
new version, better handling of Sun and Moon RA, dec and Az,h...
Now should work almost well also the routine for transit, rising and setting of Sun, Moon, planets.
When the program will be complete, I'll put the actual version in the Software Library of the Forum.
Salvo
data();
calcN();
calcTS();
meanSideralTime();
julianDay();
julianDayAtZero();
makeDateList();
deltaEpsilonPsi();
epsilon();
tempo();
precession();
parametri();
transit();
sunCalc();
planetCalc();
planets();
sun();
sunAh();
moon();
Mercurius();
Venus();
Mars();
Jupiter();
Saturn();
Uranus();
Neptunus();
Pluto();
ascendent();
zodiaco();
trunc_angle();
simp_angle();
atan2();
interpolation();
thisday:= 2000.0101;
lstd:=0; gmt:= 12;
long:= 0; lat:=  0;
m:= 1; dst:= 0; utc:=0;
sunlist:= MAKELIST(X,X,1,25);
planet_const:= MAKELIST(X,X,1,10);
EXPORT Effemeridi()
// from "Astrolabio ed Effemeridi", by Salvo Micciché, salvomic, 2015
  LOCAL ch, ε;
  HAngle:=1;
  data(); // input data and calc Sun
  ε:=epsilon();
  CASE
  IF ch==2 THEN moon(); END;
  IF ch==3 THEN planets(); END;
  IF ch==6 THEN ascendent(); END;
  IF ch==7 THEN HAngle:=0; RETURN; END;
  END; // case
data()
  LOCAL dd, mm, yy, hh, mn, ss, loct;
  yy:= IP(Date);
  mm:= IP(FP(Date)*100);
  dd:= FP(Date*100)*100;
  hh:= IP(HMS→(Time));
  mn:= IP(FP(HMS→(Time))*60);
  ss:= IP(FP(FP(FP(HMS→(Time))*60))*60);
  loct:= →HMS(hh+mn/60+ss/3600);
  INPUT({ {m,[0],{15,15,1}}, {D,[0],{50,15,1}}, {Y,[0],{80,15,1}},
  {lstd,[0],{65,30,2}},
  {dst,0,{40,15,3}}, {utc,[0],{80,15,3}},
  {long,[0],{20,25,4}},
  "Data: Use Shift+9 for H°M′S″",
  {"Enter month", "Enter day", "Enter year (1901-2099)",
  // Ragusa (-14°43′41″, 36°55′15″) -
  // Marina di Ragusa (-14°33′15″, 36°47′06″) - Scicli (-14°42'22″, 36°47' 22″)
  gmt:= lstd-utc-(1*dst); // UTC (DST, daylight save time)
  thisday:= Y+m/100+D/10000;
  // Greenwich Mean Time
  U:= T/100;
  sunCalc();
epsilon()
  U:= T/100;
  ε0:= →HMS(ε0);
  eps:= dep(2);
  RETURN ε;
deltaEpsilonPsi()
  LOCAL DD;
  DD:=FP(DD/360)*360;
  //  Long media Luna
planets()
  LOCAL ch, nameplanet;
  "Saturn", "Uranus", "Neptunus", "Pluto"}, {20,30,1}}},
  "Choose planet",
  "planet: ", "Choose the planet to calculate an press OK", 0,5 );
  Beta:=HMS→(beta);
  ε:= epsilon();
  delta:=→HMS(delta);
  lha:=HMS→(Lha);
  delta:=HMS→(Delta);
  LOCAL ε;
  ε:= epsilon();
calcN()
  N:= DDAYS(1901.0101, thisday)+1+gmt/24; // N to GMT
  RETURN N;
calcTS()
  ε:= epsilon;
  calcN();
  psi:=dep(1);
  eps:=dep(2);
  TS:= θ0GMT;
  LOCAL T,MST, JD, ε;
  ε:= epsilon;
  MST:=→HMS(MST/15);
  RETURN MST;
  ε:= epsilon;
  deltaPsi:= dep(1);
  RETURN AST;
julianDay(lista)
  y:=lista(1);
  m:=lista(2);
  d:=lista(3);
  y:=y-1;
  m:=m+12
  a:=IP(ABS(y/100));
  b:=2-a+IP(a/4);
  ELSE
  b:=0
  RETURN JD;
  LOCAL JDE;
  RETURN JDE;
  // JD at 0h GMT
  y:=Y;
  mm:=m;
  y:=y-1;
  mm:=mm+12
  a:=IP(ABS(y/100));
  b:=2-a+IP(a/4);
  ELSE
  b:=0
  RETURN JD;
makeDateList(lista)
y:=lista(1);
o:=lista(2);
d:=IP(lista(3));
t:=FP(lista(3));
h:=IP(t*24);
t:=FP(t*24);
m:=IP(t*60);
t:=FP(t*60);
s:=IP(t*60);
RETURN lista;
y:=lista(1);
m:=lista(2);
RETURN listacorta;
tempo()
  LOCAL ε;
  ε:= epsilon();
  n:= calcN();
  TSid:= calcTS();
  psi:=dep(1);
  eps:=dep(2);
  PRINT;
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
transit(alfa, delta, h0)
  LOCAL temp, H0, tsideral, Hor, m0, m1, m2, h;
  α:= alfa; // AR
  δ:= delta;
  temp:= calcTS();
  // θ0:= apparentSideralTime(makeDateListShort({Y,m,D,0,0,0})) *15; // TS in DEG
  θ0 := temp(1) * 15;
  H0:= acos(temp);
  //IF H0<-180 THEN H0:=H0+180; END; IF H0>180 THEN H0:= H0-180; END; // it should be from -180 to 180
  m0:= HMS→(α*15 + long - θ0) / 360;
  Hor:= HMS→(tsideral - long -α*15);  // Hour angle, local ST vs apparent ST
  deltaM:= -HMS→(Hor/360);
  m1:= m0-H0/360;
  Hor:= HMS→(tsideral - long - α*15);
  h:=asin(sin(lat)*sin(δ)+cos(lat)*cos(δ)*cos(Hor));
  sorg:= ((m1 + deltaM)*24); // rising
  m2:= m0+H0/360;
  deltaM:= (HMS→(h)-HMS→(h0))/(360*cos(δ)*cos(lat)*sin(Hor));
  tram:= ((m2 + deltaM) * 24); // setting
parametri()
  α:= sunlist(5); δ:= sunlist(6);
  ε:= epsilon();
  PRINT;
  PRINT(" ");
ascendent()
  ε:= epsilon;
  ts:= calcTS();
  ASC:= atan2(-cos(ts(2)), sin(ts(2))*cos(ε)+tan(lat)*sin(ε));
  segno:= zodiaco(ASC);
zodiaco(astro)
  LOCAL segno;
  CASE  // Segni e case
  IF astro>=0   AND astro <30  THEN segno:="Ariete"; END;
  IF astro>=30  AND astro <60  THEN segno:="Toro"; END;
  IF astro>=60  AND astro <90  THEN segno:="Gemelli"; END;
  IF astro>=90  AND astro <120 THEN segno:="Cancro"; END;
  IF astro>=120 AND astro <150 THEN segno:="Leone"; END;
  IF astro>=150 AND astro <180 THEN segno:="Vergine"; END;
  IF astro>=180 AND astro <210 THEN segno:="Bilancia"; END;
  IF astro>=210 AND astro <240 THEN segno:="Scorpione"; END;
  IF astro>=240 AND astro <270 THEN segno:="Sagittario"; END;
  IF astro>=270 AND astro <300 THEN segno:="Capricorno"; END;
  IF astro>=300 AND astro <330 THEN segno:="Acquario"; END;
  IF astro>=330 AND astro <360 THEN segno:="Pesci"; END;
  END; // case
  RETURN segno;
atan2(y,x)
// atan2 returns coordinates in correct angle for all four quadrants (DEG)
  CASE
    IF x==0 AND y==0 then return "undefined"; end;         // x=0, y=0
    IF x>0 then return atan(y/x); end;                     // x>0
    IF x<0 AND y>=0 then return atan(y/x)+180; end;         // x<0, y>=0
    IF x==0 AND y>0 then return 90; end;                 // x=0, y>0
    IF x<0 AND y<=0 then return atan(y/x)-180; end;         // x<0, y<0
    IF x==0 AND y<0 then return -90; end;                // x=0, y<0
  RETURN;
trunc_angle(ang)
// trunc decimal from a DEG form angle
→HMS((IP(HMS→(ang)*3600)/3600));
simp_angle(ang)
LOCAL angle;
IF angle<0
THEN
angle:=angle+360
RETURN angle;
kepler(ec, M)
  LOCAL M1, j, u;
  HAngle:=0; // RAD
  F:= 1;
  u:= PI/2; D:=PI/4;
  END; // for
  HAngle:=1;
  u:= u*180/PI;
  RETURN u;
dif1:=ΔLIST(lista);
dif2:=ΔLIST(dif1);
a:=dif1(1);
b:=dif1(2);
c:=dif2(1);
RETURN R;
sunCalc()
  LOCAL α, δ, dayY, H, ts, az, z, h;
  LOCAL SAD, DA, sorg, tram, culm, Hd, lt;
  ε:= epsilon;
  N:= calcN();
  deltapsi:= dep(1);
  t:= N/36525;
  lt:= l + 180; // Longitudine eliocentrica della Terra
  x:= r * cos(l); y:= r * sin(l);
  δ:= →HMS((asin(sin(ε)*sin(l))) );
  Hd:=simp_angle(→HMS(Hd));
  az:= temp(1);  // Azimuth
  h:=  temp(2);  // height
  //   SAD:= →HMS(acos(-tan(lat)*tan(δ))); // Semiarco Diurno
  // transit routine
  transito:= transit(α, δ, h0);
  culm:= transito(1);
  sorg:= transito(2);
  tram:= transito(3);
  // end transit
  sunlist:= {L,ω,l, M, α,δ, az, h, x,y,
             sorg, tram, culm, r, H, Hd, zc, dz, ts(1), DA,
  RETURN sunlist;
sun()
  LOCAL Ω, lapp, ec;
  ε:= epsilon;
  L:= sunlist(1); ω:= sunlist(2);
  l:= sunlist(3); M:= sunlist(4);
  az:= sunlist(7); h:= sunlist(8);
  x:= sunlist(9); y:= sunlist(10);
  sorg:= sunlist(11); tram:= sunlist(12); culm:= sunlist(13);
  r:= sunlist(14); H:= sunlist(15); Hd:= sunlist(16);
  zc:= sunlist(17); dz:= sunlist(18);
  ts:= calcTS(); //
  DA:= sunlist(20); SAD:= sunlist(21); E:= sunlist(22); lt:= sunlist(23);
  ec:= sunlist(28);
  segno:= zodiaco(l);
  PRINT;
  PRINT("Effemeridi del Sole a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("");
  PRINT("L longitudine media " + trunc_angle(L));
  PRINT("ω long del perielio " + trunc_angle(ω));
  PRINT(" ");
  PRINT(" ");
  PRINT(" ");
  PRINT("Ang. orario "+ trunc_angle(H) + " " + trunc_angle(Hd));
  PRINT("TS locale " + trunc_angle(ts(2)));
  PRINT("Equazione del tempo (min) " + trunc_angle(E));
  PRINT("");
  PRINT(" ");
  PRINT("Long elioc. Terra "+ trunc_angle(lt));
  // RETURN {L, ω, M, v, l, r, x, y};
sunAh(lista)
  delta:=sunlist(6);
  phi:=lat;
  ts:= calcTS();
  // IF lha<0 THEN lha:=lha+360 END;
  // IF lha>=360 THEN lha:=lha-360 END;
  lha:=simp_angle(→HMS(lha));
  Altitude:= temp(2);
  RETURN ah;
moon()
  LOCAL α,δ, ts, Hd, zc, dz, h, az;
  i:= 5.13333333; // inclinazione 5°8' sull'eclittica
  ε:= epsilon();
  N:= calcN();
  // Sun
  // end Sun
  rsum:=0;
  α:= temp(1);
  δ:= temp(2);
  az:= HMS→(temp(1))+180; // azimuth
  IF az>360 THEN az:=az-360 END;
  az:= →HMS(az);
  // Raggio quadratico medio della Terra: 6373,044737
  s:= asin((3/11)*sin(P)); // semidiametro (raggi terrestri)
  // transit routine
  h0:= 0.7275*P - HMS→(0°34′); // 'standard' altitude of Moon (depend on parallax)
  culm:= transito(1);
  sorg:= transito(2);
  tram:= transito(3);
  // end transit
  CASE
  // IF ph == 0 THEN fase:="New Moon"; END;
  IF ph>280 AND ph<350 THEN fase:="Decrescente"; END;
  IF ph>=260 AND ph<=280 THEN fase:="Last Quart"; END;
  IF ph>190 AND ph<260 THEN fase:="Gibbosa Cal."; END;
  IF ph>=170 AND ph<=190 THEN fase:="Full Moon"; END;
  IF ph>100 AND ph<170 THEN fase:="Gibbosa Cresc."; END;
  IF ph>=80 AND ph<=100 THEN fase:="1st Quart"; END;
  IF ph>10 AND ph<80 THEN fase:="Crescente"; END;
  DEFAULT fase:="New Moon";
  END; // case
  // età della Luna
  segno:= zodiaco(l);
  ill:= 1-(1+cos(ph))/2; // illuminated fraction
  PRINT;
  PRINT("Effemeridi della Luna a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("ω Perigeo medio " + trunc_angle(ω));
  PRINT("Ω Nodo ascendente " + trunc_angle(Ω));
  PRINT(" ");
  PRINT("α Ascensione retta (gradi) " + trunc_angle((α*15) MOD 360));
  PRINT("");
  PRINT("Diff. asc." + trunc_angle(DA) + " SAD " + trunc_angle(SAD));
  PRINT("P Parallasse " + trunc_angle(P));
  PRINT(" ");
  PRINT(" ");
  PRINT("Fase " + trunc_angle(ph) + " " + fase + " " + ROUND(100*→HMS(ph)/360,2)+"%");
  PRINT("Età " + eta);
  LOCAL ω,Ω, l, v, r, x, y, z;
  LOCAL Ls, Ms, b, xs, ys, b_ec;
  LOCAL x1, y1, z1, R, l_ec, H, Hd;
  LOCAL ec, in, a, δ, α, ts, az, h;
  LOCAL DA, SAD, tram, sorg, culm, dayY;
  LOCAL transito, h0, JD, temp;
  // calc of Sun (as basis)
  xs:= sunlist(9); ys:= sunlist(10);
  // end Sun
 EVAL(EXPR(nameplanet+"()")); // call planet-name function
  L:= planet_const(1); // Longitudine media
  ω:= planet_const(2); // perielio
  Ω:= planet_const(3); // nodo
  M:= planet_const(4); // anomalia
  v:= planet_const(5);
  ec:= planet_const(6); // eccentricità
  in:= planet_const(7); // inclinazione
  a:= planet_const(8);  // semiasse maggiore
  θ:= planet_const(9);  // θs to calc if retrogade
  b_ec:= asin(sin(in)*sin(v+ω-Ω)); // argomento di latitudine del perielio
  l_ec:= acos(cos(v+ω-Ω)/cos(b_ec));  // long from eclittic
  IF b_ec<0 THEN l_ec:= 360 - l_ec; END; // argomento secondario
  l_ec:= →HMS((l_ec + Ω)) MOD 360; // aggiunge Nodo e riporta a 2PI
  r:= a*(1-ec^2)/(1+ec*cos(v)); // 9.524899/(1+ 0.0559*cos(v)); raggio vettore
  x1:= r*cos(b_ec)*cos(l_ec); y1:= r*cos(b_ec)*sin(l_ec); z1:=r*sin(b_ec); // cartesian
  x:= x1+xs; y:= y1+ys; z:=z1; // cohordinates cartesian->spheric
  R:= sqrt(x^2+y^2+z^2);
  b:=asin(z/R); // latitudine  β
  // l:=→HMS(atan(y/x)); // cart->spheric longtitudine λ
  l:= atan2(y,x);
  IF l<0 THEN l:= l+360; END; IF l>360 THEN l:=l-360; END;
  // δ:= →HMS((asin(cos(ε)*sin(b)+sin(ε)*cos(b)*sin(l))) ); // declinazione (coord locali)
  // α:= (acos(cos(b)*cos(IFTE(l>180, l-180, l))/cos(δ))); // ascensione retta
  //α:= →HMS(α/15) MOD 24; // α in hms
  α:= temp(1);
  δ:= temp(2);
  DA:= →HMS(asin(tan(lat)*tan(δ))); // Differenza ascensionale
  SAD:= →HMS(90 + DA); // Semiarco Diurno
  // culm:= (IFTE(α<ts(1),24+α,α) - ts(1)) MOD 24 ; // Culminazione
  // transit routine
  h0:= -0°34′; // 'standard' altitude of a planet
  culm:= transito(1);
  sorg:= transito(2);
  tram:= transito(3);
  // end transit
  IF abs(l-220.4)>θ THEN mov:="diretto"; ELSE mov:="retrogrado"; END;
  segno:= zodiaco(l);
  PRINT;
  PRINT("Effemeridi di " + nameplanet + " a " + m+" "+D+" "+Y+" "+ lstd);
  PRINT("L Long media " + trunc_angle(L));
  PRINT("ω Perielio " + trunc_angle(ω));
  PRINT("Ω Nodo " + trunc_angle(Ω));
  PRINT("M Anomalia vera " + trunc_angle(M));
  PRINT("l_ec Long. eclittica " + trunc_angle(l_ec));
  PRINT("b_ec Lat. eclittica " + trunc_angle(b_ec) + " v " + trunc_angle(v));
  PRINT("r Raggio vettore " + r);
  PRINT("Cartes. elioc.: x' " + ROUND(x1,3) + " y' " + ROUND(y1,3) + " z' " + ROUND(z1,3));
  PRINT("Cartes. geoc.: x " + ROUND(x,3) + " y " + ROUND(y,3) + " z " + ROUND(z,3));
  PRINT("Spher.: β Latitudine " + trunc_angle(b));
  PRINT("Spher.: R Distanza " + ROUND(R,3));
  PRINT("");
  PRINT("Diff. ascensionale " + trunc_angle(DA));
  PRINT("SAD semiarco diurno " + trunc_angle(SAD) + " :: " + trunc_angle(→HMS(SAD/15)));
  PRINT(" ");
  PRINT("Movimento " + mov);
  RETURN [[L,ω,Ω ],[M,l_ec,b_ec], [v,r,0], [x1,y1,z1],[x,y,z],[l,b,R], [α,δ,H], [az,h,ts(1)],[sorg, tram, culm]];
Mercurius()
  // Costanti per Mercurio
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.205615; // eccentricità
  in:= 7.003; // inclinazione
  a:= 0.387098; // semiasse maggiore
  θ:= 35.6;  // θs to calc if retrogade
  calcN();
  // costanti planetarie
  L:= →HMS((229.851 + 4.09237703*N) MOD 360); // Longitudine media
  ω:= →HMS((75.913 + 0.00004253*N) MOD 360); // perielio
  Ω:= →HMS((47.157 + 0.00003244*N) MOD 360); // nodo
  M:= (L - ω); // Anomalia vera
  v:= M + 23.4372*sin(M)+2.9810*sin(2*M)+0.5396*sin(3*M)+0.1098*sin(4*M);
  planet_const:= {L, ω, Ω, M, v, ec, in, a, θ};
  RETURN planet_const;
Venus()
  // Costanti per Venere
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.006816; // eccentricità
  in:= 3.393636; // inclinazione
  a:= 0.72333; // semiasse maggiore
  θ:= 13.0;  // θs to calc if retrogade
  calcN();
  L:= →HMS((206.758 + 1.60216873*N) MOD 360); // Longitudine media
  ω:= →HMS((130.154 + 0.00003757*N) MOD 360); // perielio
  Ω:= →HMS((75.797 + 0.00002503*N) MOD 360); // nodo
  v:= M + 0.7811*sin(M);
Mars()
  // Costanti per Marte
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.093309; // eccentricità
  in:= 1.850303; // inclinazione
  a:= 1.523678; // semiasse maggiore
  θ:= 16.8;  // θs to calc if retrogade
  calcN();
  L:= →HMS((124.765 + 0.52407108*N) MOD 360); // Longitudine media
  ω:= →HMS((334.251 + 0.00005038*N) MOD 360); // perielio
  Ω:= →HMS((48.794 + 0.00002127*N) MOD 360); // nodo
  v:= M + 10.608*sin(M)+0.6216*sin(2*M)+0.0504*sin(3*M)+0.0047*sin(4*M);
Jupiter()
  // Costanti per Giove
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.048335; // eccentricità
  in:= 1.308736; // inclinazione
  a:= 5.202561; // semiasse maggiore
  θ:= 54.43;  // θs to calc if retrogade
  calcN();
  L:= →HMS((268.350 + 0.08312942*N) MOD 360); // Longitudine media
  ω:= →HMS((12.737 + 0.00004408*N) MOD 360); // perielio
  Ω:= →HMS((99.453 + 0.00002767*N) MOD 360); // nodo
  v:= M + 5372*sin(M)+0.1662*sin(2*M)+0.007*sin(3*M);
Saturn()
  // Costanti per Saturno
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.055892; // eccentricità
  in:= 2.492519; // inclinazione
  a:= 9.554747; // semiasse maggiore
  θ:= 65.53;  // θs to calc if retrogade
  calcN();
  L:= →HMS((278.774 + 0.03349788*N) MOD 360); // Longitudine media
  ω:= →HMS((91.117 + 0.00005362*N) MOD 360); // perielio
  Ω:= →HMS((112.79 + 0.00002391*N) MOD 360); // nodo
  v:= M + 6.4023*sin(M)+0.2235*sin(2*M)+0.011*sin(3*M);
Uranus()
  // Costanti per Urano
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.046344; // eccentricità
  in:= 0.772464; // inclinazione
  a:= 19.21814; // semiasse maggiore
  θ:= 73.92;  // θs to calc if retrogade
  calcN();
  L:= →HMS((248.487 + 0.01176902*N) MOD 360); // Longitudine media
  ω:= →HMS((171.563 + 0.00004064*N) MOD 360); // perielio
  Ω:= →HMS((73.482 + 0.00001365*N) MOD 360); // nodo
  v:= M + 5.3092*sin(M)+0.1537*sin(2*M)+0.0062*sin(3*M);
Neptunus()
  // Costanti per Nettuno
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.008997; // eccentricità
  in:= 1.779242; // inclinazione
  a:= 30.10957; // semiasse maggiore
  θ:= 77.63;  // θs to calc if retrogade
  calcN();
  L:= →HMS((86.652 + 0.00602015*N) MOD 360); // Longitudine media
  ω:= →HMS((46.742 + 0.000039*N) MOD 360); // perielio
  Ω:= →HMS((130.693 + 0.00003009*N) MOD 360); // nodo
  v:= M + 1.031*sin(M)+0.0058*sin(2*M);
Pluto()
  // Costanti per Plutone
  LOCAL ω,Ω, L, M, v;
  LOCAL ec, in, a, θ;
  ec:= 0.250236; // eccentricità
  in:= 17.17047; // inclinazione
  a:= 39.438712; // semiasse maggiore
  θ:= 79.41;  // θs to calc if retrogade
  calcN();
  // Long, perielio, nodo, non precisi, considerati costanti
  // L:= →HMS((229.851 + 4.09237703*N) MOD 360); // Longitudine media
  M:= →HMS((230.67 + 0.00397943*N) MOD 360); // Anomalia vera (calcolata direttamente)
  Ω:= →HMS((109.06 + 0.00003823*N) MOD 360); // nodo
  ω:= →HMS((114.27 + Ω) MOD 360); // perielio
  L:= →HMS((M + ω) MOD 360); // L (non sicuro)
  v:= M + 28.45*sin(M)+4.38*sin(2*M)+0.97*sin(3*M)+0.24*sin(4*M);
