Solver variable question - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Solver variable question (/thread-4251.html) |
Solver variable question - TechAlex - 06-28-2015 08:20 PM Hello all, I am trying to write a program, actually I got it working, but I want to create variables of two or more letters. How can I accomplish that? The "FV" local variable down below if I use it, let's say, FV=...., the Solver creates two variables, now the equation is wrong. I want to create a variable of three characters for "M", like "PMT" EXPORT TVM_Test() BEGIN LOCAL FV; STARTAPP("Solve"); "F=P*(1+((R/100)/N))^(N*T)+M*((1+((R/100)/N))^(N*T)-1)/((R/100)/N)"▶E1; PRINT(); PRINT("NOTE: This Equation Will Solve for Any Unknown Variable."); PRINT(" "); PRINT("P = Present Value"); PRINT("F = Future Value"); PRINT("R = Interest Rate"); PRINT("T = Numbers of Years"); PRINT("N = Compounds per Year."); PRINT("M= Amount of payment or deposit."); PRINT(" "); PRINT("Press ENTER ↲ to Continue..."); // Display Solver CHECK(1); STARTVIEW(2,1); END; Thank you. RE: Solver variable question - roadrunner - 06-28-2015 09:07 PM Do you mean like this? Code:
RE: Solver variable question - TechAlex - 06-29-2015 12:14 AM (06-28-2015 09:07 PM)roadrunner Wrote: Do you mean like this? I dont think this will work. What I want is to find out how to declares variables of two or more characters, for example, "PMT" instead of just "M", or "FV" instead of "F", or "%R" instead of just "R", etc., so the Solver can use them., so the data entry screen can be more meaningful. See attach image. Thank you for replying . RE: Solver variable question - roadrunner - 06-29-2015 03:15 AM [/quote] I dont think this will work. [/quote] You're right, I type it in wrong before. It wouldn't let me use PMT and FV, I believe because those are already variables built in to the finance app. It did let me use lower case variables, pmt and fv. Like in the attachment: [attachment=2234] The HP Prime is a fantastic calculator, but has a very steep learning curve. Right now I am at the bottom of that curve. Road RE: Solver variable question - TechAlex - 06-29-2015 03:29 AM I dont think this will work. [/quote] You're right, I type it in wrong before. It wouldn't let me use PMT and FV, I believe because those are already variables built in to the finance app. It did let me use lower case variables, pmt and fv. Like in the attachment: The HP Prime is a fantastic calculator, but has a very steep learning curve. Right now I am at the bottom of that curve. Road [/quote] Thank you, Road. It works like a charm. I agree with you, the Prime has not match. I got hardware version A, I contacted HP, they replaced it with hardware version C. PM me if you would like to know the details. |
