The header of a program in app's - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: The header of a program in app's (/thread-4263.html) |
The header of a program in app's - Marcel - 06-29-2015 09:31 PM Hi If I save a app's in a with a new name, in the program catalog I will see a program with this name. Exemple app'name save: A new name in program catalog: A new name (App) If I EDIT, I see EXPORT A_new_name() BEGIN END; My question My program have many functions so If I delete these lines of code, the program continue to work fine. These lines of code are there essentiel? Marcel RE: The header of a program in app's - cyrille de brébisson - 06-30-2015 04:20 AM Hello, They are absolutely not important AT ALL!!!! Cyrille RE: The header of a program in app's - Marcel - 06-30-2015 10:42 AM Hi, Thank you, I will delete all these lines from my astronomy app's. Marcel RE: The header of a program in app's - Tim Wessman - 06-30-2015 02:08 PM Yup, it is just to give you a "getting started" place if you need it. RE: The header of a program in app's - Marcel - 06-30-2015 07:02 PM Hi Thank you for your response! Marcel |
