Missing INFORM command on the Prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Missing INFORM command on the Prime (/thread-429.html) |
Missing INFORM command on the Prime - Karl-Ludwig Butte - 01-14-2014 07:37 AM Dear all, while writing my first program on the Prime, I was searching for an equivelant to the HP-50G's INFORM command. I only found the INPUT coammnd but this can only prompt for one variable. There should be some possibility to generate something like the INFORM command 'cause the CAS setup function contains 2 pages of mixed input like e.g. input fields, chooseboxes and boolean variables. So how can I program an input screen perhaps with more than one page like the CAS setup function? Any hint will be very much appreciated - thank you very much in advance. Best regards Karl RE: Missing INFORM command on the Prime - eried - 01-14-2014 07:41 AM You can prompt multiple vars with INPUT. Check the help in the device. PS: Inappropriate posts number. I should receive another 20% warning level Mr. Admin? |
