Comments, only comments - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Comments, only comments (/thread-4313.html) |
Comments, only comments - salvomic - 07-06-2015 07:24 PM In these days I search mostly one thing, in the Prime: /* block comments */ I need them to test my program, I can't stand to prefix every lines with // :-) Salvo RE: Comments, only comments - Marcel - 07-06-2015 07:31 PM HI! This is exactly what I do.. // // // // This is very long... Marcel RE: Comments, only comments - salvomic - 07-06-2015 07:35 PM (07-06-2015 07:31 PM)Marcel Wrote: HI! yes, in fact, very very long... I would prefer this: Code:
so we could confront blocks of program quickly... Salvo RE: Comments, only comments - BruceH - 07-06-2015 10:03 PM Code:
The lines still have to be syntactically correct though, alas. RE: Comments, only comments - StephenG1CMZ - 07-06-2015 10:19 PM Myself I prefer much comments to be nestable, so I can write Code: /* right now I don't want to do this Until block comments are implemented you could try using subroutines: Code: export maybeDo RE: Comments, only comments - StephenG1CMZ - 07-06-2015 10:41 PM (07-06-2015 10:03 PM)BruceH Wrote: If I remember correctly the equivalent syntax on the ti-83 only required the syntax to be correct in the If true case...it was not checked in the If false case. How about the Prime? |
