partfrac - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: partfrac (/thread-4326.html) |
partfrac - edynperu - 07-09-2015 04:20 AM from the 8151 firmware update to the partfunc function does not return the correct results. How I can fix this? How I can downgrade my calculator? ![]() RE: partfrac - parisse - 07-09-2015 05:19 AM I never run partfrac with approx input, it explains that I did not track the unsimplified terms. Please run it in exact mode until I can fix it. RE: partfrac - Tim Wessman - 07-09-2015 05:25 AM A workaround for the moment is to put your original input inside an exact( ) call. An easy way to do this is pressing the a b/c key inside the CAS screen. It will convert your numbers into exact fractional representations. Thank you for the report. RE: partfrac - edynperu - 07-09-2015 12:43 PM ![]() this is a good solution but it is not the best, I hope you can solve. thanks |
