subst command in RPN mode (bug ?) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: subst command in RPN mode (bug ?) (/thread-4518.html) |
subst command in RPN mode (bug ?) - Philippe - 08-12-2015 05:15 PM Hello, I would like to report the following behavior : In home view and in textbook entry, subst('2*Q', 'Q=2') gives 4 as expected. However, in RPN entry : '2*Q' Enter 'Q=2' Enter subst(2) Enter Returns "subst(2*Q, (Q==2)) Error: Bad argument type" Do I miss something? Do you confirms it's a bug ? Thanks Philippe RE: subst command in RPN mode (bug ?) - Tim Wessman - 08-12-2015 05:29 PM Guessing it has something to do with how the arguments are being fed into the CAS. Probably something interacting with auto-evalation on the CAS side. In the list. Thanks. Note that the | (where) operator works fine here though without issue. RE: subst command in RPN mode (bug ?) - Fortin - 08-12-2015 07:20 PM This behavior changed from =(Q,2) to Q==2 pretty recently. I forget the specific release number though. This was also the release that changed the = behavior in Adv Graphing to == ... 7820 maybe? ...don't know if that helps... RE: subst command in RPN mode (bug ?) - Didier Lachieze - 08-12-2015 07:56 PM (08-12-2015 05:15 PM)Philippe Wrote: In home view and in textbook entry, subst('2*Q', 'Q=2') gives 4 as expected.The single quotes are lost when you press enter, on the stack you don't have '2*Q' but just 2*Q. So you need to add another set of single quotes or double quotes around the parameters to make it work , for example : "'2*Q'" Enter "'(Q=2)'" Enter subst(2) RE: subst command in RPN mode (bug ?) - Marcelo Vanti - 08-12-2015 08:55 PM (08-12-2015 07:56 PM)Didier Lachieze Wrote: "'2*Q'" Enter it works here, indeed, if I use q (lowercase letter) rather than Q: "2*q" "q=2" CAS.subst(2) ==> 4 RE: subst command in RPN mode (bug ?) - Didier Lachieze - 08-12-2015 10:15 PM (08-12-2015 08:55 PM)Marcelo Vanti Wrote:It works as long as q is not defined. But if you create q, for ex by storing 0 to q then the subst command will return 0 as 2*q will be evaluated to 0 before the substitution can be done. To pass 2*q to the CAS for the substitution you need the single quotes inside the double quotes, or two levels of single quotes.(08-12-2015 07:56 PM)Didier Lachieze Wrote: "'2*Q'" Enter RE: subst command in RPN mode (bug ?) - Didier Lachieze - 08-12-2015 10:24 PM (08-12-2015 08:55 PM)Marcelo Vanti Wrote:It works as long as q is not defined. But if you create q, for ex by storing 0 to q then the subst command will return 0 as 2*q will be evaluated to 0 before the substitution can be done. To pass 2*q to the CAS for the substitution you need the single quotes inside the double quotes, or two levels of single quotes.(08-12-2015 07:56 PM)Didier Lachieze Wrote: "'2*Q'" Enter RE: subst command in RPN mode (bug ?) - Marcelo Vanti - 08-13-2015 12:36 PM (08-12-2015 10:24 PM)Didier Lachieze Wrote: It works as long as q is not defined. But if you create q, for ex by storing 0 to q then the subst command will return 0 as 2*q will be evaluated to 0 before the substitution can be done. To pass 2*q to the CAS for the substitution you need the single quotes inside the double quotes, or two levels of single quotes. You're right. I did not know the possibility of working with single quotes within double quotes, for replacement. Thanks for the tip. RE: subst command in RPN mode (bug ?) - Philippe - 08-14-2015 12:46 PM Hello, To summarize, let : Form1: subst(2*q , q=2) Form2: subst(' 2*q ' , ' q=2 ') Form3: subst(" 2*q " , " q=2 ") Form4: subst(" ' 2*q' " , " ' q=2 ' ") BAT = Bad Argument Type error SYN = Syntax error n.a = not applicable Then, we have : 1) In textbook entry, if q is not defined | Home | CAS --------------------------------------------- Form1 | SYN | 4 Form2 | SYN | 4 Form3 | 4 | BAT Form4 | 4 | BAT --------------------------------------------- 2) In textbook entry, if q is defined (0 in this case) | Home | CAS --------------------------------------------- Form1 | BAT | Warning, then 0 Form2 | 4 | 4 Form3 | 0 (no warning) | BAT Form4 | 4 | BAT --------------------------------------------- 3) In RPN mode (forms are of course adapted), if q is not defined | Home | --------------------------------------------- Form1 | n.a | Form2 | SYN | can't push '2*q' on stack Form3 | 4 | Form4 | 4 | --------------------------------------------- 4) In RPN mode, if q is defined (0 in this case) | Home | --------------------------------------------- Form1 | n.a | Form2 | 0 | Form3 | 0 | Form4 | 4 | --------------------------------------------- - In RPN, we cannot push expression that contains undefined variable: 'q' Enter produce a syntax error. We already know that this is a big regression compared to hp50...hp28. No more comment. - The Form2 seems (at least to me !) the most suited to have a homogeneous and clean syntax between Home view and CAS, RPN and algebraic notations. - The warning "Warning, replacing 0 by 2, a substitution variable should perhaps be purged." is useful - May be the electronic help should be updated (in order to explain simple/double quotes) Cheers, Philippe |
