gaussian quadrature - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: gaussian quadrature (/thread-4564.html) |
gaussian quadrature - Antonio - 08-23-2015 07:01 PM Hello, First of all sorry for my bad English . I'm making a program to calculate integrals by gaussian quadrature and I have the following problem , I've done two different ways. Program 1 , due to the unique character of this calculator , sometimes it works, sometimes not , so i try to make the program 2 Program 2 , do not put the correct result in a0 . Program 1 Code: #pragma mode( separator(.,;) integer(h64) ) Programa 2 Code: #pragma mode( separator(.,;) integer(h64) ) Let's see if someone can lend me a hand, thanks . RE: gaussian quadrature - Didier Lachieze - 08-24-2015 03:18 PM (08-23-2015 07:01 PM)Antonio Wrote: Program 1 , due to the unique character of this calculator , sometimes it works, sometimes not , so i try to make the program 2Can you explain what happens when it doesn’t work? On my side it seems to works fine. (08-23-2015 07:01 PM)Antonio Wrote: Program 2 , do not put the correct result in a0 .I’ve done some tests with your program 2 and if I’m correct it seems that there is an issue when the CAS function legendre() is called from a CAS program:
RE: gaussian quadrature - Antonio - 08-25-2015 09:23 AM Hello Didier, Thanks for the reply. Regarding the program 1 , what I mean is that sometimes it runs and calculates the roots and coefficients and sometimes fails to execute M2:=CAS.zeros(legendre(nr)); or F1:=CAS.diff(legendre(nr)); does not give any error message unless it does not. Regarding the program 2, I tried to change x by X , as you suggested, I had to add one more line to assign the value to the X ,as it does not properly a0:=subst(diff(legendre(nr)),X=M2(i)); they work as X:=M2(i); a0:=subst(diff(legendre(nr)),X=0); Another problem is that not running the loop, and I 've been manually deactivated by assigning values to the variable i, work when i = 2 or i = 3 , but not when i = 1, the error is in M1(i,1):=2/((1-M2(i)^2)*(a0^2)); and I dont see the failure more I look. RE: gaussian quadrature - Didier Lachieze - 08-25-2015 11:42 AM (08-25-2015 09:23 AM)Antonio Wrote: Regarding the program 1 , what I mean is that sometimes it runs and calculates the roots and coefficients and sometimes fails to executeOn my side every time I've tried the program 1 it has worked correctly so I can't reproduce your issue. (08-25-2015 09:23 AM)Antonio Wrote: Another problem is that not running the loop, and I 've been manually deactivated by assigning values to the variable i, work when i = 2 or i = 3 , but not when i = 1, the error is inI think this is because M1 is predefined as a matrix of reals and you're trying to assign to it an exact number when a0 is -3/2. Try with adding a dot to the first 2 to get an approximate number (or create your own matrix variable, different from the predefined ones M0-M9): M1(i,1):=2./((1-M2(i)^2)*(a0^2)); RE: gaussian quadrature - Antonio - 08-25-2015 12:26 PM Already solved As you said I put the point to take the number as Real rather than exact and have solved two problems , which did not work when i = 1 and the problem of the loop. Although I do not see the relationship between the loop and the latter problem that the variable a0 can be real or exact. The corrections program that works is Code: #pragma mode( separator(.,;) integer(h64) ) In relation to program 1 , I have not noticed any particular pattern in failure . It happens also in other programs which use CAS.funtion( ) sometimes makes the call to CAS successfully and some not. Every time I like least this calculator , since to do something that comes out of the most basic , even as simple as this program is a headache.. In any case thank you very much for your help Didier |
