Toolbox CAS-command in cas-program - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Toolbox CAS-command in cas-program (/thread-4620.html) |
Toolbox CAS-command in cas-program - Arno K - 09-01-2015 09:49 PM Today I began another little program which should be a CAS one. So I started the program-list, entered its name: PrimW, checked CAS. Then I chose the command Euler from the Toolbox-Menu which completed that line to eu = CAS.euler(n), some more lines and a little test run showed: CAS.euler(n) is not evaluated in a CAS-program, instead it is given back unchanged (as a string?), return eu brought Euler(108). Deleting "CAS." came up with the desired result 36. In my opinion this is a serious bug as at least a cas program should ignore the CAS in front of Euler() or the command should be inserted without it. Arno So for you to see: Code:
and a picture of the result: [attachment=2486] Arno |
