HP-65 Simulator for iPad - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: HP-65 Simulator for iPad (/thread-4638.html) |
HP-65 Simulator for iPad - Willy R. Kunz - 09-03-2015 04:54 PM What is a collection of Classic HP Calculator simulators without the HP-65? So, finally, RPN-65 Pro has made it to the iTunes Store. The iPad app comes complete with five original HP Pacs already built in.
RE: HP-65 Simulator for iPad - Namir - 09-04-2015 03:39 AM F A N T A S T I C!!!! I will get a copy when I return home on two days! You are the best programmer!! Namir RE: HP-65 Simulator for iPad - bshoring - 09-04-2015 10:48 PM I've downloaded it and it is great. Like all the Cuvée apps, this one is true to the original and a true work of art. Nice that you can use it in vintage or enhanced mode with lots of additional features. Thanks, Willy, for making this! RE: HP-65 Simulator for iPad - Namir - 09-05-2015 05:03 PM The first thing I did when I got back from the beach is to download the RPN-65 emulator. I was thinking on the way home about the best way to install the standard HP 65 Pacs mentioned in Kuntz's web site. Well, I fell off my chair when I discovered that Willly has included these Pac with the installation!!! I was beyond happy!! Thanks Willy! You are the man! This emulator, like it's RPN-67 sibling, is MAJOR COOL!!! Namir RE: HP-65 Simulator for iPad - Willy R. Kunz - 09-05-2015 09:25 PM (09-05-2015 05:03 PM)Namir Wrote: The first thing I did when I got back from the beach is to download the RPN-65 emulator. I was thinking on the way home about the best way to install the standard HP 65 Pacs mentioned in Kuntz's web site. Well, I fell off my chair when I discovered that Willly has included these Pac with the installation!!! I was beyond happy!! Thank Willy! You are the man! This emulator, like it's RPN-67 sibling, is MAJOR COOL!!! Thanks for the kudos, Namir. I'm currently preparing a few other pacs for download. By the way, RPN-65 turned out to be one of the toughest simulations so far. The HP-65 has a number of unexpected "features", like ignoring the first RTN statement if a program was not started by a user-defined key. I know of at least one commercial HP program making use of this fact. RE: HP-65 Simulator for iPad - Namir - 09-05-2015 11:31 PM If I read your instructions correctly for the RPN-65, you can install multiple programs at the same time, right? Or do you have to create, for each program, a new program in the emulator, drag a downloaded file from a Pac (using iTunes) and then write it to the iPad?? This is how I installed RPN-67 pacs on the iPad. Namir RE: HP-65 Simulator for iPad - Willy R. Kunz - 09-06-2015 07:54 AM (09-05-2015 11:31 PM)Namir Wrote: If I read your instructions correctly for the RPN-65, you can install multiple programs at the same time, right? Or do you have to create, for each program, a new program in the emulator, drag a downloaded file from a Pac (using iTunes) and then write it to the iPad?? This is how I installed RPN-67 pacs on the iPad. You can load either individual cards or replace the entire SQL database. Storing DB files on your computer allows you to manage as many card collections as you like. Program cards used to have names like HP67ProgCard.rpn67. Cards for RPN-65 have more meaningful names, like STD04B.rpn65. This means you can drag several card files to the iTunes Documents section without naming conflicts. When importing, the alphabetically first card is offered for import. When done, you simply delete the file in iTunes and you'll be offered the next one. Sounds more complicated than it is. And yes, the import action always overwrites the currently selected card, so you better have a number of empty cards ready. Like in the real world... ;-) RE: HP-65 Simulator for iPad - Namir - 09-06-2015 09:30 AM Thank you for explaining the new way to load cards for the RPN-65 and especially the need to have multiple blank cards ready. Your emulator makes me want to write HP-65 programs and not simply use ones in the HP pacs. Namir RE: HP-65 Simulator for iPad - Gene - 09-06-2015 12:06 PM Hey Namir! Don't forget the HP65 programs from the PPC Journal found here: http://www.rskey.org/gene which includes one of my favorite HP 65 programs: Business Functions as well as these: HP-65 TVM - I% Known | HP-65 TVM - I% Unknown HP-65 Game of Craps! | HP-65 Lunar Lander! | HP-65 Tic-Tac-Toe! HP-65 Bagels! | HP-65 High-Low! | HP-65 Eleven-thirty Game! HP-65 Ping Pong Game! | HP-65 Viking Lander! | HP-65 Chuck-a-luck! RE: HP-65 Simulator for iPad - Namir - 09-06-2015 01:15 PM I would like to ask Willy to queue emulators for the HP-55 and HP-25C in his next set of emulators for the iPad. I know, I know! It's like we say in Arabic "It's expensive, but the request is cheap!" Namir RE: HP-65 Simulator for iPad - Namir - 09-06-2015 05:14 PM Regarding my request for an HP-25C emulator, maybe an HP-33C emulator would be better since it supports subroutines. You can of course add GSB and RTN as [g]-shifts for the [STO] and [RCL] keys of the HP-25C, respectively. One choice is to make the GSB line-numbered oriented (like an HP33C) or add LBL (as [g]-shift and [STO]) with support for labels 0 to 9. I hope I m not taking too much liberty in asking you for these emulators. It should go with out any question that they are for pay. Namir RE: HP-65 Simulator for iPad - Willy R. Kunz - 09-06-2015 08:40 PM (09-06-2015 12:06 PM)Gene Wrote: Hey Namir! Hi Gene, I just pasted Business Functions into RPN-65 Pro. A remarkably powerful program indeed! Example 3 wouldn't run correctly at first, until I found out the instructions are wrong. Instead of "2. Key 250, ENTER, 80, RTN, R/S" they should read "2. Key 250, ENTER, 80, RTN, D". RE: HP-65 Simulator for iPad - bshoring - 09-06-2015 09:15 PM (09-06-2015 05:14 PM)Namir Wrote: Regarding my request for an HP-25C emulator, maybe an HP-33C emulator would be better since it supports subroutines. You can of course add GSB and RTN as [g]-shifts for the [STO] and [RCL] keys of the HP-25C, respectively. One choice is to make the GSB line-numbered oriented (like an HP33C) or add LBL (as [g]-shift and [STO]) with support for labels 0 to 9. Namir, I would agree that an emulator of the HP-33C would be a better choice than the HP-25. We already have a decent iOS emulator for the 25 (GO-25), which allows saving and importing programs, but currently nobody offers any iOS emulators for the Spice Series. Any of the programmable Spices would be desirable. The top of my wish list is one for the HP-38C Financial programmable, especially if it offers a way to save and load programs. A few years back emulators were offered for a very short time for the Spice series, but they didn't have the ability to save/load programs nor were they photorealistic. Incidentally, now, with the HP-65 emulator, the complete Classic series has iOS emulators. Cuvee emulates 4 of them and the two others (55 & 80) are available from Amelo Consulting. RE: HP-65 Simulator for iPad - Thomas Klemm - 09-06-2015 10:26 PM (09-06-2015 09:15 PM)bshoring Wrote: A few years back emulators were offered for a very short time for the Spice series, but they didn't have the ability to save/load programs nor were they photorealistic. But they provide a debugger which is nice if you want to know what is going on under the hood: just double-click the display to start it. Cheers Thomas RE: HP-65 Simulator for iPad - Michael de Estrada - 09-07-2015 02:31 AM Just bought it. Thanks. RE: HP-65 Simulator for iPad - Willy R. Kunz - 09-07-2015 03:36 PM (09-07-2015 02:31 AM)Michael de Estrada Wrote: Just bought it. Thanks. My turn to say thank you. Just found a small issue in RPN-65 Pro: D.MS results should be rounded to seconds, i.e. D.MMSS0000, at least in vintage mode. Will be implemented in an update. RE: HP-65 Simulator for iPad - Matt Agajanian - 09-11-2015 12:18 AM (09-04-2015 03:39 AM)Namir Wrote: F A N T A S T I C!!!! I will get a copy when I return home on two days! You are the best programmer!! Having downloaded it and trying it out a few hours ago, I second that vote! RE: HP-65 Simulator for iPad - d b - 09-11-2015 02:31 PM I'm very happy with my CuVee Vintage 45. It fits well on my old iphone4's small screen. |
