newRPL: [UPDATED April 27-2017] Firmware for testing available for download - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: newRPL: [UPDATED April 27-2017] Firmware for testing available for download (/thread-4645.html) |
RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Vtile - 12-30-2016 06:59 PM Nice.. How would one make a program in newRPL that would use +-key as in original 50g with the lists. I know you swapped the ADD and + commands functionality with the newRPL. I just like so much the way it works with original as lists are "data collector type" so compiling a list is so easy with the plus key (unshifted)... Something like: << -> X Y << X TYPE 5 == Y TYPE 5 == OR IF THEN ADD ELSE + END >> >> ?? Then just +..P ANSKEY ?? I'm still just following and not participating, I admit. ![]() RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - compsystems - 12-30-2016 07:12 PM I prefer that [+] [-] operators work in parallel in a list. To have the "old" function a solution, could be [/ ->] (hold right shift) & [+] or [-] NEW-RPL should not be 100% compatible with the old-RPL, (this means staying in the past) RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Vtile - 12-30-2016 08:15 PM (12-30-2016 07:12 PM)compsystems Wrote: I prefer that [+] [-] operators work in parallel in a list. I didn't mean that it should stay the same. My question were more just a follow up on the new ASNKEY and how it works. Also I'm not fully sure how the programming goes so it would also answer that partly.. This or that I should reload the emu or even better flash my spare 50g unit to newRPL and try it out. ![]() Here is the last post from Claudio: (12-30-2016 05:24 PM)Claudio L. Wrote: List of new features and changes: RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 12-31-2016 03:38 AM (12-30-2016 08:15 PM)Vtile Wrote: My question were more just a follow up on the new ASNKEY and how it works. Also I'm not fully sure how the programming goes so it would also answer that partly.. This or that I should reload the emu or even better flash my spare 50g unit to newRPL and try it out. Your idea is on the right track. However, the TYPE command is still not implemented. As a workaround (for the time being), you could assign ADD to a long press on the + key: { ADD } "+..L" 0 ASNKEY If you use ADD more than the addition, then assign + to a long press and ADD to the normal key with: { ADD } "+" 0 ASNKEY { + } "+..L" 0 ASNKEY But of course, with this solution you'd have to long press every time you need to add a couple of numbers (since 1 2 ADD --> { 1 2 } and not 3 as in the 50g). RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-19-2017 07:22 AM Is there any way to redefine the VAR menu so it doesn't do STO on left-shift? I have lost so many long programs by accident that way! Someone wrote me a short SysRPL program a while back to replace it with VISITB instead, which I truly love. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Nigel (UK) - 01-19-2017 08:32 AM (01-19-2017 07:22 AM)The Shadow Wrote: Is there any way to redefine the VAR menu so it doesn't do STO on left-shift? I have lost so many long programs by accident that way! Someone wrote me a short SysRPL program a while back to replace it with VISITB instead, which I truly love. Following on from this, an UNDO feature for STO would be nice - maybe the previous contents of the variable could go to LAST_STO, or something like that? Nigel (UK) RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-20-2017 03:57 AM (01-19-2017 07:22 AM)The Shadow Wrote: Is there any way to redefine the VAR menu so it doesn't do STO on left-shift? I have lost so many long programs by accident that way! Someone wrote me a short SysRPL program a while back to replace it with VISITB instead, which I truly love. Doing STO on left shift is a long tradition that works quite well in practice. newRPL gives you the next best thing: LOCKVAR and UNLOCKVAR commands. These 2 commands make variables read-only so they cannot be deleted accidentally. It's especially good for programs you don't want to accidentally overwrite, not only from the VAR menu, but perhaps a rogue program could write a variable with the same name as your program. It doesn't work on directories, though, only individual variables. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-20-2017 04:04 AM (01-20-2017 03:57 AM)Claudio L. Wrote: Doing STO on left shift is a long tradition that works quite well in practice. newRPL gives you the next best thing: LOCKVAR and UNLOCKVAR commands. Quote: It doesn't work on directories, though, only individual variables. Thanks for the reply. Do those commands accept lists as input? I suppose I can eventually create my own version of VAR using TMENU. Being able to VISIT a program with a simple left-shift is so nice. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-20-2017 04:04 AM (01-19-2017 08:32 AM)Nigel (UK) Wrote: Following on from this, an UNDO feature for STO would be nice - maybe the previous contents of the variable could go to LAST_STO, or something like that? It could be done, however, it directly affects performance of running code. The stack UNDO/REDO feature only takes a snapshot when the user starts a program from the UI, but never while a program is running so it doesn't cause any slowdown. Making STO keep a copy of each thing it stores doubles (or more) the time it takes to store a variable, every single time you use STO, it can be disastrous for performance. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-20-2017 04:10 AM (01-20-2017 04:04 AM)The Shadow Wrote: Thanks for the reply. Do those commands accept lists as input? Yes, they do. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-20-2017 04:36 AM (01-20-2017 04:10 AM)Claudio L. Wrote:(01-20-2017 04:04 AM)The Shadow Wrote: Thanks for the reply. Do those commands accept lists as input? Ah good. And here's a thought - is there any way for a program to detect if a variable is locked? (Other than trying to STO into it!) RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-20-2017 07:43 PM (01-20-2017 04:36 AM)The Shadow Wrote:(01-20-2017 04:10 AM)Claudio L. Wrote: Yes, they do. Not at the moment. It's not as common use case as you might think. Normally, if you need to know that is because you have something to store there, therefore you can trap the STO errors inside an IFERR, and perhaps rename the variable if it fails (no different from the case when you want to know if a variable of that name already exists, you do RCL and trap the error). RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-21-2017 05:02 AM (01-20-2017 07:43 PM)Claudio L. Wrote:(01-20-2017 04:36 AM)The Shadow Wrote: Ah good. And here's a thought - is there any way for a program to detect if a variable is locked? (Other than trying to STO into it!) I get that, but I was thinking along the lines of, "Did I lock the files in this directory yet or not?" I suppose I could just RCL one and try to STO it back in. Or just lock them all again, won't hurt anything. On another topic, it's trivially easy to write programs to decompile everything in a directory to strings and to recompile them for updates. But not so easy in RPL to do it for all directories at once. Would you consider commands to do this? I have to imagine it would be easier in C. And on yet another, I make heavy use of symbolic vectors and matrices, and I've noticed some oddities. Only on the Windows version thus far, though, as my new 50g hasn't arrived yet. Is it up to date with the calculator version? RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-22-2017 01:38 AM (01-21-2017 05:02 AM)The Shadow Wrote: I get that, but I was thinking along the lines of, "Did I lock the files in this directory yet or not?" I suppose I could just RCL one and try to STO it back in. Or just lock them all again, won't hurt anything.I see, eventually there will be a filer (var browser?) where you will be able to see if a variable is read-only or not. (01-21-2017 05:02 AM)The Shadow Wrote: On another topic, it's trivially easy to write programs to decompile everything in a directory to strings and to recompile them for updates. But not so easy in RPL to do it for all directories at once. Would you consider commands to do this? I have to imagine it would be easier in C.Updates will no longer require to recompile anything. Starting with the first official release of 0.8Alpha a month ago, things will stay where they are. (01-21-2017 05:02 AM)The Shadow Wrote: And on yet another, I make heavy use of symbolic vectors and matrices, and I've noticed some oddities. Only on the Windows version thus far, though, as my new 50g hasn't arrived yet. Is it up to date with the calculator version? The demo is identical to the calculator, any bugs will happen on the 50g too, so please describe what you call oddities. Bear in mind many of the commands will show up in autocomplete but will issue an "Invalid opcode" error because they are not implemented. Anything else might be a bug, either in symbolics or in the matrix lib. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-22-2017 04:01 AM (01-22-2017 01:38 AM)Claudio L. Wrote: Updates will no longer require to recompile anything. Starting with the first official release of 0.8Alpha a month ago, things will stay where they are. Ah, good to know. Quote:The demo is identical to the calculator, any bugs will happen on the 50g too, so please describe what you call oddities. Bear in mind many of the commands will show up in autocomplete but will issue an "Invalid opcode" error because they are not implemented. Anything else might be a bug, either in symbolics or in the matrix lib. Okay. (I've got my calculator now, btw, and newRPL installed without incident.) I started with the vector [1 2 3], and then divided by '3'. I expected to get: [ '1/3' '2/3' '3/3' ] What I got instead was: '[ 1 2 3 ]/3' So then I tried [ '1' '2' '3' ] and divided by '3'. This time I got an error, "/ Error: Not allowed in symbolics". Finally I tried [ '1' '2' '3' ] and divided by 3. (Well, "3" not "3.") This time I got the decimal versions of the three fractions in the vector. ie, [0.333... 0.666... 0.999...] That last one in particular seems odd - why not just 1? I would expect the symbolics inside the vector to work just like symbolics on the stack or in a list, but they don't. (Incidentally, is there a command to change an integer into the symbolic version of that integer? ->Q changes 2 to '2/1' rather than '2'. Not sure if that's intended behavior - RPL changes real "2." to integer "2".) A somewhat larger issue: Currently, if you do EVAL or EVAL1 on '2/1' or '2', you get 2. I wonder if that's a good idea? ->NUM should do that, certainly, but I don't see why EVAL should. I'd expect it to be '2' in both cases. (By the way, let me thank you from the bottom of my heart for letting EVAL and EVAL1 evaluate the elements of matrices and lists, respectively. The number of times I have typed AXL <<EVAL>> MAP AXL on the regular 50g is ridiculous.) RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-22-2017 04:50 AM Okay, playing around tonight I've found some serious bugs: If you put an integer in quotes, ie '2', and then do ->NUM, you get an invisible object on the stack. You get an error "Not allowed in symbolics" if you try to make it interact with other numbers, so I'm not sure what it is. It's definitely there, though, as it increments DEPTH. DROP doesn't return an error if there's nothing on the stack. EDIT: To be more precise, if you enter DROP as a command it works properly; but if you press backspace in order to DROP it doesn't. EDIT: Checking these on the Windows version confirms these bugs. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Nigel (UK) - 01-22-2017 12:56 PM (01-20-2017 04:04 AM)Claudio L. Wrote:(01-19-2017 08:32 AM)Nigel (UK) Wrote: Following on from this, an UNDO feature for STO would be nice - maybe the previous contents of the variable could go to LAST_STO, or something like that? I wasn't thinking of having this feature active in programs; it is mistakes that I make from the keyboard that concern me! Thinking about it, it would be easy enough for a user to define a new STO command that places the old value in LAST_STO before storing the new value; can the user then bind this to the action of a left-shifted variable key? Nigel (UK) RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - The Shadow - 01-22-2017 02:59 PM Something strange is going on with the DISABLE button in the Keys menu. When I first installed newRPL, it showed up as INVALID and gave errors when you put anything on the stack while it was visible. I figured my download was corrupted and reinstalled. It worked this time, for a while. But now it's doing it again: >> Error: Empty data stack (internal) Then when you try to put anything on the stack, you get the same error. Though this time, the button isn't showing up at all, rather than saying INVALID. A couple times I've seen a list spontaneously pop up that appears to be the button's TMENU specification. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-22-2017 08:30 PM (01-22-2017 04:01 AM)The Shadow Wrote:(01-22-2017 01:38 AM)Claudio L. Wrote: Updates will no longer require to recompile anything. Starting with the first official release of 0.8Alpha a month ago, things will stay where they are. It seems you caught a glitch in my definition of the '/' operation for vectors. Since division doesn't exist in matrix/vector world, it was implemented as "multiply by the inverse", so if you divide a matrix by another one it inverts the right argument then attempts to multiply. I obviously need to work on some special cases: [ 1 2 3 ] 3 / --> First it does 3 INV --> 0.333333333.... then multiplies that, hence you get the 0.9999999999.... instead of one. For the case matrix / number this doesn't work well and needs to be fixed. It would work much better for scalars when you use the actual '/' operator element-by-element. [ '1' '2' '3' ] 3 / --> Similarly, 3 INV returns an approximated value, then when multiplied by other numbers it spreads the approximation virally, and you end up with all approximated numeric answers (this is by design). Same fix as previous issue. [ 1 2 3 ] '1/3' * --> Not allowed in symbolics. Because the interaction between them wasn't quite ready yet, you can't have vectors and lists inside a symbolic: '{ 1 2 }' will fail the same way. I think it's trying to create a symbolic '[ 1 2 3 ]*(1/3)' which is not permitted. I will have to work on that so it does the element-by-element multiplication, then of course I have to enable it. It was giving me problems with lists, so I disabled it. The idea is to allow multiple inputs and multiple outputs: { 2 4 6 } 'X' STO 'X^2/2' ->NUM should produce { 4 8 18 } as a result. This isn't working well yet. (01-22-2017 04:01 AM)The Shadow Wrote: (Incidentally, is there a command to change an integer into the symbolic version of that integer? ->Q changes 2 to '2/1' rather than '2'. Not sure if that's intended behavior - RPL changes real "2." to integer "2".)I need to fix ->Q, denominator of 1 is supposed to be removed. (01-22-2017 04:01 AM)The Shadow Wrote: A somewhat larger issue: Currently, if you do EVAL or EVAL1 on '2/1' or '2', you get 2. I wonder if that's a good idea? ->NUM should do that, certainly, but I don't see why EVAL should. I'd expect it to be '2' in both cases.There's no way to 'convert' an object into symbolic, other than operate on it with a symbolic object. All symbolics are passed through an autosimplify step that removes the symbolic ticks if the result is an exact number. If you have '1/3' EVAL it won't remove the quotes and the result will remain '1/3' because it wouldn't have an exact result. It shouldn't cause any problems, if you find a use case where you need to keep an integer number symbolic let me know, I might have to add such a command. (01-22-2017 04:01 AM)The Shadow Wrote: (By the way, let me thank you from the bottom of my heart for letting EVAL and EVAL1 evaluate the elements of matrices and lists, respectively. The number of times I have typed AXL <<EVAL>> MAP AXL on the regular 50g is ridiculous.) It seemed natural to extend the element-by-element operation of EVAL1. Notice that EVAL on lists explodes the list, so you still have to do << EVAL >> MAP, but EVAL1 does it element-by-element. This was done for compatibility, but I'm open to a change. RE: newRPL: [UPDATED December-29-16] Firmware for testing available for download - Claudio L. - 01-22-2017 08:37 PM (01-22-2017 02:59 PM)The Shadow Wrote: Something strange is going on with the DISABLE button in the Keys menu. I'll try to reproduce it, but it's working well here. I wonder if it is due to some data corruption due to you playing with "unfinished" code. Try a full memory wipe and see if it works, perhaps some of your symbolics experiments is the one to blame. If you can find a sequence that could reproduce the problem from a fresh clean memory (don't worry, you can do that on the PC) it would make it much easier for me to hunt the bug. |
