Direct writing to Spreadsheet - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Direct writing to Spreadsheet (/thread-4728.html) |
Direct writing to Spreadsheet - Powersoft - 09-16-2015 11:16 AM hello, Is it posible to write results direct to the Spreadsheet? If yes where can I find Some example(s) I working on a planet calculator, so I calculate Some Numbers and wont put them in a spreadsheet as a big overview. Cheers, RE: Direct writing to Spreadsheet - Thomas_Sch - 09-16-2015 12:26 PM Are you looking for something like Code: Spreadsheet.Cell(1,4):=value If you have more than one spreadsheet app, you have to adjust the spreadsheet name accordingly, for e.g. Code: spread1.Cell(2,3):=yourvalue Cheers, thomas RE: Direct writing to Spreadsheet - Tim Wessman - 09-16-2015 02:35 PM Note that if you aren't trying to access by a numeric algorithm, you can also do Spreadsheet.A1, Spreadsheet.B2 and just use the direct cell reference. The "Cell" command allows you to use a number form for accessing the cell reference. RE: Direct writing to Spreadsheet - cyrille de brébisson - 09-17-2015 06:38 AM Hello, You can also do: A1:='A2+A3' to assign a formula to a cell. You can also access the cell meta data/attributes using A1(n) or Cell(r, c, n) Look at the help for Cell References and Cell for more information: CELL ATTRIBUTES (n) -1: all attributes. If the cell has nothing defined, returns -1, else return a list of 11 objects. 0: value (read only, you can not set the cell value) 1: formula 2: name 3: number format: Standard 0, Fixed 1, Scientific 2, Engineering 3, Floating 4, Rounded 5, unspecified –1 4: number of decimal places: 1 to 11, or unspecified = –1 5: font: -1: 0 to 6, unspecified = –1 6: background color: cell fill color (color, or 32786 if unspecified) 7: foreground color: contents color (color, or 32786 if unspecified) 8: horizontal alignment: Left = 0, Center = 1, Right = 2 , unspecified = –1 9: vertical alignment: Top = 0, Center = 1, Bottom = 2, unspecified = –1 10: show strings in quotes: Yes = 0, No = 1, unspecified = –1 11: textbook mode (as opposed to algebraic mode): Yes = 0, No = 1, unspecified = –1 Cyrille RE: Direct writing to Spreadsheet - Thomas_Sch - 09-19-2015 04:00 PM Any comments from user powersoft? Are your questions answered? RE: Direct writing to Spreadsheet - Powersoft - 09-19-2015 07:09 PM Thanks all for this wonderful help. I have tried it, and wat I won't to do could now be done. Is it posible to rename a spreadsheet? Cheers, Jan RE: Direct writing to Spreadsheet - Thomas_Sch - 09-19-2015 10:43 PM (09-19-2015 07:09 PM)Powersoft Wrote: Is it posible to rename a spreadsheet?real Prime or virtual Prime: Pressing "Apps", you can use the "Save" button to create a new App. In the Connectivity Kit, right click on an app, there ist a option "Rename" if it is a copy of a build in App. Cheers Thomas |
