(50G) Fast Continued Fractions - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: General Software Library (/forum-13.html) +--- Thread: (50G) Fast Continued Fractions (/thread-4738.html) |
(50G) Fast Continued Fractions - Joe Horn - 09-17-2015 04:37 PM 'R2CF' (Ratio to Continued Fraction): Convert Ratios of Two Integers to/from Continued Fractions. An HP 50g System RPL program by Joe Horn. Running 'R2CF' on a regular fraction (that is, an algebraic object that is a ratio of two integer-type objects) converts it to a continued fraction in list notation (a list of integers). 'R2CF' also converts continued fractions back to regular fractions. It's very fast. Examples (in exact mode of course): Input: '355/113' Output: { 3 7 16 } because \(\frac{355}{113} = 3 + \cfrac{1}{7 + \cfrac{1}{16} }\) which is written as { 3 7 16 } in continued fraction shorthand, with only the partial quotients in the list, not the numerators which are always 1. The above example executes in 0.02 seconds. Input: { 3 7 16 } Output: '355/113' The above example executes in 0.025 seconds. The size of the input integers and lists is limited only by available memory. Note: Most texts separate the partial quotients of a continued fraction's shorthand notation with commas, and some texts place a semicolon after the first one to indicate that it's the integer part of the original fraction. Therefore you will usually see 355/113 expressed as either {3, 7, 16} or {3; 7, 16}. This HP 50g program assumes that the first number in the list is always the integer part, so it'll be zero for fractions between 0 and 1. Therefore all punctuation may be omitted without ambiguity. 'R2CF' (Ratio to Continued Fraction) Code: %%HP: T(3); BYTES: 188.0 #9465h Note to hackers: If the above code looks familiar, it might be because you saw it before in the LongFloat library. I'm not copying Gjermund's code; to the contrary, I sent it (many years ago!) to him, suggesting that he replace his continued fraction routines (SF→CF and CF→SF) with my code because it was faster. He graciously did so. |
