WP34s: emulator feature request - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not quite HP Calculators - but related (/forum-8.html) +--- Thread: WP34s: emulator feature request (/thread-4741.html) |
RE: WP34s: emulator feature request - Paul Dale - 11-09-2015 10:02 AM This sounds like a stack lift issue. Pressing enter disables stack lift and the paste function doesn't re-enable it. Fix committed. It doesn't look like the 31S is getting these changes at the moment. Have I ever mentioned how painful stack lift is to support? - Pauli (11-09-2015 09:05 AM)fhub Wrote: Marcus, there's still a small problem: RE: WP34s: emulator feature request - fhub - 11-09-2015 10:54 AM (11-09-2015 10:02 AM)Paul Dale Wrote: This sounds like a stack lift issue. Pressing enter disables stack lift and the paste function doesn't re-enable it. Fix committed.Yep, the new build 3837 solves this probem. Thanks to Pauli and Marcus for the quick fix, Franz RE: WP34s: emulator feature request - Marcus von Cube - 11-09-2015 10:55 AM (11-09-2015 10:02 AM)Paul Dale Wrote: This sounds like a stack lift issue. Pressing enter disables stack lift and the paste function doesn't re-enable it. Fix committed. ... and rebuilt. Walter, we are on 3837 already. RE: WP34s: emulator feature request - Paul Dale - 11-09-2015 11:25 AM (11-09-2015 06:52 AM)Dieter Wrote: If I knew how to use it I also would try the console version. ;-) I not sure you really want to.... The key mapping is near the top of console.c, the top three rows map naturally to a US qwerty keyboard, the numbers are themselves and the extra keys are more sporadic. There are extra commands:
The text display includes a lot of status information and internal state at the top of the screen. This includes the stack and other lettered registers and a lot of other things too. The calculator display is crudely rendered as well. All in all, good for debugging but not all that easy to use for anyone except me - Pauli RE: WP34s: emulator feature request - walter b - 11-09-2015 11:53 AM Ok, retried with build 3837: Selected one Excel cell, copied to clipboard, opened WP 34S, right-clicked on [WP], clicked on <Paste number(s)> ... nothing happened. What did I miss? d:-? RE: WP34s: emulator feature request - fhub - 11-09-2015 11:58 AM (11-09-2015 11:53 AM)walter b Wrote: ..opened WP 34S, right-clicked on [WP], clicked on <Paste number(s)> ... nothing happened.You're right, it does not work from this right-click menu, it only works when you do it in the top menu bar. Franz RE: WP34s: emulator feature request - walter b - 11-09-2015 12:04 PM Thanks for pointing this out. Usually, I hide this titlebar. Anyway, it's not logical working just one of both possible ways. d:-/ RE: WP34s: emulator feature request - ggauny@live.fr - 11-09-2015 12:53 PM Hi, How find build 3837 ? On SourceForge I don't see 3837 ? RE: WP34s: emulator feature request - fhub - 11-09-2015 12:58 PM (11-09-2015 12:53 PM)ggauny@live.fr Wrote: How find build 3837 ? On SourceForge I don't see 3837 ?You'll always find the latest builds here: http://sourceforge.net/p/wp34s/code/ Franz RE: WP34s: emulator feature request - Marcus von Cube - 11-09-2015 01:00 PM (11-09-2015 12:04 PM)walter b Wrote: Anyway, it's not logical working just one of both possible ways. I agree. Try again, please! RE: WP34s: emulator feature request - walter b - 11-09-2015 01:21 PM Looks significantly better now. Thanks! Seems we can use it now. d:-) RE: WP34s: emulator feature request - walter b - 11-09-2015 01:25 PM ... and look in the square brackets - there you find [r3839] as the most recent build now. d:-) RE: WP34s: emulator feature request - Marcus von Cube - 11-09-2015 01:48 PM (11-09-2015 01:25 PM)walter b Wrote: ... and look in the square brackets - there you find [r3839] as the most recent build now. Should be fixed now. RE: WP34s: emulator feature request - walter b - 11-09-2015 03:36 PM Yes, it is. d:-) RE: WP34s: emulator feature request - Dieter - 11-09-2015 08:06 PM (11-09-2015 01:00 PM)Marcus von Cube Wrote: I agree. Try again, please! Great – it works! Thank you very much! Two observations:
Dieter RE: WP34s: emulator feature request - pascal_meheut - 11-09-2015 08:15 PM The Qt emulators have been rebuilt too. RE: WP34s: emulator feature request - walter b - 11-09-2015 08:32 PM (11-09-2015 08:15 PM)pascal_meheut Wrote: The Qt emulators have been rebuilt too. (11-08-2015 12:50 PM)Paul Dale Wrote: ... the Qt emulators ... Are they really emulators? They don't emulate anything, rather they are more like ports. ?? d:-? RE: WP34s: emulator feature request - pascal_meheut - 11-09-2015 09:18 PM We emulate the hardware: screen, keyboard... RE: WP34s: emulator feature request - Marcus von Cube - 11-09-2015 09:50 PM (11-09-2015 08:06 PM)Dieter Wrote: Two observations: This is standard behavior of the underlying decNumber library. RE: WP34s: emulator feature request - matthiaspaul - 11-10-2015 02:02 AM I too was hoping this would be implemented one day. ;-) Thanks, Pauli and Marcus, for the great workl (11-08-2015 09:28 PM)Dieter Wrote: what about a keyboard shortcut? For instance Ctrl+Shift+C and Ctrl+Shift+V?Sounds like a good hotkey, but it would conflict with my clipboard manager. So, ideally, the hotkey would have to be configurable... Now, with direct register export/import bypassing keyboard and display in place, two related feature suggestions appear to be in reach: - Raw copy & paste selected register(s) to/from clipboard via keyboard and mouse in "debug" mode - Allow to edit a number in a selected register in a popup window via keyboard and mouse in "debug" mode Greetings, Matthias |
