Where is my file - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Where is my file (/thread-4776.html) |
Where is my file - Powersoft - 09-22-2015 06:23 PM Hi all, When I push the "save button" in the HP Connectivity Kit, where is my file stored? Cheers, Jan RE: Where is my file - John Colvin - 09-22-2015 07:33 PM The Save icons save the file(s) to the connected device-either the Prime emulator or the real Prime. RE: Where is my file - eried - 09-22-2015 07:51 PM Inside the working folder (check Edit/Preferences) RE: Where is my file - Tim Wessman - 09-22-2015 09:00 PM (09-22-2015 06:23 PM)Powersoft Wrote: When I push the "save button" in the HP Connectivity Kit, where is my file stored? As stated, your file will be save to the device. If you want to keep a separate copy locally, drag from the tree to somewhere else (your desktop, the bottom left box which maps to /MyDocuments/Content/<here>", a network share, etc. |
