ON key - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: ON key (/thread-4782.html) |
ON key - primer - 09-23-2015 11:47 AM hello, I don't know if someone already collected ON key combination, I could not find an extensive list already, sorry if I missed. I know they are documented, but on different place (for example ON+T is documented in PRINT build-in help...) Here is the list I have, You are welcome to add the ones you know :
Best Regards, RE: ON key - StephenG1CMZ - 09-23-2015 03:26 PM A useful list. On the Android emulator ON T seems not to work. An alternative from the Home screen is: PRINT(CHAR(0)) RE: ON key - Joe Horn - 09-24-2015 04:58 AM (09-23-2015 11:47 AM)primer Wrote: Here is the list I have, You are welcome to add the ones you know...
