HP82240A Hardware - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP82240A Hardware (/thread-479.html) |
HP82240A Hardware - TomC - 01-20-2014 06:56 PM Is anyone familiar with the early variants of the 82240A Hardware? Existing Documentation (the very fine T.Duell schematics) show a KA2183 device as the IR front end IC. I've disassembled an 82240A and the IR front end is a TDA3047. I have the datasheet for this part, and am curious about the subsequent circuitry in the printer. It appears that the output of the TDA3047 connects to the base of a TO92pkg transistor. Before sliding down the circuit re-construction path, I would be curious is anyone else has traced this circuit and can share their findings. Thanks, TomC RE: HP82240A Hardware - Tony Duell - 01-21-2014 09:34 AM (01-20-2014 06:56 PM)TomC Wrote: Is anyone familiar with the early variants of the 82240A Hardware? I have seen, but not for long enough to reverse-engineer it, a version of the printer using the TDA3047. It may be the -A uses that IC, the -B uses the KA2183. The TDA3047, as I guess you've found, was a Philips IC. I have at least one data book that includes it. The transistor you mention is probably just a buffer/inverter. RE: HP82240A Hardware - TomC - 01-21-2014 11:55 PM Tony: Thanks; given time, I may investigae how much of the remaining circuitry is similar to the KA2143 type design. Regards, Tomc |
