Help, I have a syntax error - Printable Version
+--- Thread: Help, I have a syntax error (/thread-4850.html)
Help, I have a syntax error - Powersoft - 10-01-2015 06:20 PM
In this small code part I get an error.
The error is on the "else" and I marked the code.
Please have a look. I could not find the error.
Thanks for any help.
Jan
B23p_T(T);
p4_T(T);
//*3 Region Selection
//*3.1 Regions as a function of pT
EXPORT region_pT(p, T)
LOCAL dummy,ps;
IF T > 1073.15 AND p < 10 AND T < 2273.15 AND p > 0.000611 THEN
dummy := 5;
ELSE
IF T <= 1073.15 AND T > 273.15 AND p <= 100 AND p > 0.000611 THEN
IF T > 623.15 THEN
IF p > B23p_T(T) THEN
dummy := 3;
IF T < 647.096 THEN
ps := p4_T(T);
IF abs(p - ps) < 0.00001 THEN
dummy := 4;
ELSE
dummy := 2;
ELSE
ps := p4_T(T);
dummy := 4;
ELSE IF p > ps THEN
dummy := 1;
ELSE
dummy := 2;
ELSE <== ERROR ?????????
dummy := 0; //**Error, Outside valid area
RETURN dummy;
RE: Help, I have a syntax error - Han - 10-01-2015 06:25 PM
LOCAL dummy,ps;
    dummy := 5;
ELSE
    IF T > 623.15 THEN
            dummy := 3;
            IF T < 647.096 THEN
                ps := p4_T(T);
                    dummy := 4;
        ELSE
            dummy := 2;
    ELSE
        ps := p4_T(T);
            dummy := 4;
        ELSE IF p > ps THEN // <-- here is your problem; IF THEN without END
            dummy := 1;
        ELSE
            dummy := 2;
RETURN dummy;
IF THEN without END nested inside and ELSE statement... I commented the spot within your code
RE: Help, I have a syntax error - Powersoft - 10-01-2015 06:41 PM
Han thanks, but I'm lost in space.
This is my original Matlab code, but I have some problems with
the "elseif"
Please can you help me with this?
Jan
function region_pT = region_pT(p, T)
if T > 1073.15 && p < 10 && T < 2273.15 && p > 0.000611
    region_pT = 5;
elseif T <= 1073.15 && T > 273.15 && p <= 100 && p > 0.000611
    if T > 623.15
        if p > B23p_T(T)
            region_pT = 3;
            if T < 647.096
                ps = p4_T(T);
                if abs(p - ps) < 0.00001
                    region_pT = 4;
                end
            end
        else
            region_pT = 2;
        end
    else
        ps = p4_T(T);
            region_pT = 4;
        elseif p > ps
            region_pT = 1;
        else
            region_pT = 2;
        end
    end
else
    region_pT = 0; %**Error, Outside valid area
end
RE: Help, I have a syntax error - Han - 10-01-2015 06:58 PM
It's explained here: https://nf.nci.org.au/facilities/software/Matlab/techdoc/ref/elseif.html
Try:
LOCAL dummy,ps;
    dummy := 5;
ELSE
    IF T > 623.15 THEN
            dummy := 3;
            IF T < 647.096 THEN
                ps := p4_T(T);
                    dummy := 4;
        ELSE
            dummy := 2;
    ELSE
        ps := p4_T(T);
            dummy := 4;
        ELSE
            IF p > ps THEN
                dummy := 1;
            ELSE
                dummy := 2;
  ELSE
RETURN dummy;
