cross calling ppl and #cas ??? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: cross calling ppl and #cas ??? (/thread-4872.html) |
cross calling ppl and #cas ??? - ji3m - 10-04-2015 12:21 PM So what are the argument and evaluation rules when (1) a ppl function calls a #cas func (2) a #cas function calls ppl (3) a ppl fun passes cas variables I get different results and sometimed brutsl crashes depending on the args and functions. RE: cross calling ppl and #cas ??? - cyrille de brébisson - 10-05-2015 07:13 AM Hello, Easy answer: I can't even remember! Ok, looking in the code, here are the rules: From PPL to CAS - Parameters are NOT evaluated prior to the CAS call Unless it is a list - All local variables in the parameters are replaced by their values (because CAS does not have access to local variables) - Parameters which are Strings are parsed by the CAS parser - CAS default variable is changed to X, Y and theta depending on the current app - CAS function is evaluated - CAS default variable is restored - CAS Result is transformed into PPL construct and returned from CAS to PPL - All arguments are evaluated - Arguments are transformed into PPL constructs and PPL function is called - Result is transformed back into CAS and returned Cyrille RE: cross calling ppl and #cas ??? - ji3m - 10-05-2015 03:27 PM I presume you mean the CAS (....) call. How about calling a #cas function.. from ppl? e.g. #cas f (a,b):=......#end then in ppl call f a:= f (n,m); Anything different here? RE: cross calling ppl and #cas ??? - Han - 10-05-2015 03:36 PM (10-05-2015 03:27 PM)ji3m Wrote: I presume you mean the CAS (....) call. He means all instances of calling a program or command name that is associated with the CAS side of things. So whether it is a function you created using #cas or a built-in CAS command, what Cyrille posted is an explanation of how inputs are parsed when calling a CAS command/program from within a PPL program or calling a PPL program from within a CAS program. The CAS() command is a PPL command as is the CAS.command() construct. |
