Time measurement of a function - Printable Version
+--- Thread: Time measurement of a function (/thread-4901.html)
Time measurement of a function - Powersoft - 10-08-2015 10:46 AM
Hi all,
I need to know how long it takes to execute a function.
Please can you help me with this.
Cheers Jan
RE: Time measurement of a function - Powersoft - 10-08-2015 11:18 AM
Problem solved, using TICKS gives the right result
RE: Time measurement of a function - Tim Wessman - 10-08-2015 03:45 PM
TEVAL(function()) will give you your time in sec as well.
RE: Time measurement of a function - Joe Horn - 10-09-2015 03:15 AM
(10-08-2015 03:45 PM)Tim Wessman Wrote:  TEVAL(function()) will give you your time in sec as well.
In CAS (only), there's a cool shortcut for timing any expression; just press
Sto, comma, Enter
after the expression that you wish to time. It looks like "►," until you press Enter. (Sto can be typed either from the Sto menu button or Shift EEX).
Example: wait(2)►, Enter
Magically turns into: time(WAIT(2))
Returns: 2 (approximately!).
Notes: The time() function is similar to the TEVAL() function, but returns the seconds without any unit appended. Although the 3-keystroke shortcut only works in CAS, the time() function works in both Home and CAS... but "time" must be spelled in lowercase.
