HP82104A Card Reader repair - help needed - Printable Version
+--- Thread: HP82104A Card Reader repair - help needed (/thread-4927.html)
HP82104A Card Reader repair - help needed - Rsponholtz - 10-12-2015 12:45 AM
Hi everyone,
I was emboldened by all the information on repairing the HP82104A card reader (youtube video, article, etc) for the HP41C calculator, so I dived right in. Things went fairly well and I used the proper silicone tubing for the wheel and rebuilt the coupling. After putting things together enough to test, the reader pulls the card through, but immediately after the card starts moving, the calculator says "CARD ERR". Thinking this was a card I wrote about 20 years ago, I took a new card and did a "XEQ WSTS" which seemed to complete ok. When I try to read that card back in, I still get a "CARD ERR".
I used my multimeter to check the actions of the photodiode and the little switches, and everything seems to be working fine - looking at the white circuit board I get continuity on the rightmost two contacts when I push the card in far enough to make contact with the first switch. I get continuity on the third and fourth contacts from the right after the card moves a bit (i.e. hits the second switch), and I get about 6 volts between the last two contacts when the card is moving - this appears to be the signal from the photodiode.
So now I'm a bit stuck. I've looked at the service manual here, and it appears that I need the ET-11966 service module to make progress directly with the calculator-based troubleshooting.
I tried fiddling with R5 a bit to see if changing the speed of the motor might help. The speed of the card motion did change, but I still got "CARD ERR" every time.
Anyone have ideas on what the problem might be, or how I can debug the problem?
BTW here's what I have on-hand to tackle this:
41CV and a pack of old magnetic cards
a good multimeter
a Tek 465 oscilloscope (very old & non-storage),
a function generator, frequency counter and a power supply
some PCs (obviously)
I also have a couple of raspberry PIs and an Arduino that might be able to lend a hand :-)
Also, does anyone have a source for the actual PDF of the service manual?
Thanks for your help!
Ross
RE: HP82104A Card Reader repair - help needed - rprosperi - 10-12-2015 01:49 AM
(10-12-2015 12:45 AM)Rsponholtz Wrote:  Also, does anyone have a source for the actual PDF of the service manual?
The Card Reader Service Manual is a part of the MoHPC USB Thumb Drive set, (see here) which IMHO every member here should buy immediately. Virtually every document on there is worth the price of the full set, which means the other 6000+ files were free. Smile
RE: HP82104A Card Reader repair - help needed - BobVA - 10-12-2015 07:55 PM
(10-12-2015 12:45 AM)Rsponholtz Wrote:  When I try to read that card back in, I still get a "CARD ERR".
Kind of a left-field possibility, but if you can borrow another HP-41 it might be worth trying the reader on it.
I had a card reader I thought was malfunctioning and it turned out to be a bad interconnect in the HP-41. The card reader really stresses any high-resistance connections that can otherwise go unnoticed.
Bob
RE: HP82104A Card Reader repair - help needed - ignazio - 10-19-2015 11:18 AM
have you try to check the magnetic coils of the head?
RE: HP82104A Card Reader repair - help needed - Dave Frederickson - 10-19-2015 07:08 PM
(10-12-2015 12:45 AM)Rsponholtz Wrote:  I've looked at the service manual here, and it appears that I need the ET-11966 service module to make progress directly with the calculator-based troubleshooting.
A Clonix module from Diego Diaz can emulate the above service module with the card reader diagnostics. The overlays are even available.
