Frequency of HP Prime - Printable Version
+--- Thread: Frequency of HP Prime (/thread-4945.html)
Frequency of HP Prime - Powersoft - 10-14-2015 10:25 AM
Hi all
I found this info on the web.
What I not know is the possible to have two frequency modes.
Is it posible to switch between?
Wich commands?
Thanks for any help.
Jan
Processor
Architecture : ARM (ARM9 ; 32 bit)
Core : ARM926EJ-S
Manufacturer : Samsung
Reference : S3C2416
Specs : 16KB I-cache; 16KB D-cache/MMU
Frequency : 2 Modes : 266 MHz and 400 MHz
RE: Frequency of HP Prime - mandresve - 10-15-2015 01:00 AM
I think that the uP speed is locked on the kernel of the Prime OS, nothing to do for now.
RE: Frequency of HP Prime - cyrille de brébisson - 10-15-2015 05:36 AM
Prime runs at 400Mhz.
It will scale CPU speed down when not in use, but that is it. There is no user controllable way to change the CPU speed.
Cyrille
RE: Frequency of HP Prime - komame - 10-18-2015 09:26 AM
(10-15-2015 05:36 AM)cyrille de brĂ©bisson Wrote:  It will scale CPU speed down when not in use, but that is it.
I think the CPU scaling doesn't work quite well in HP Prime.
I can give examples of programs that sometimes runs for 10 seconds and sometimes for 7 seconds (if you run it several times without any modifications).
So the scaling down also happens (sometimes) when performance is required and program slows down.
