GETPIX_P values - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: GETPIX_P values (/thread-505.html) |
GETPIX_P values - Graan - 01-24-2014 12:44 PM When using a GETPIX_P(Gn,X,Y) command on a white (#FFFFFFh) pixel I get #F8F8F8h, seems the last 3 bits are not detected. GETPIX on a #070707h pixel gives 0. Why? /Andreas RE: GETPIX_P values - eried - 01-24-2014 01:41 PM Pixels are formatted as ARGB1555 (5 bits per color + 1 alpha) RE: GETPIX_P values - patrice - 01-24-2014 02:07 PM Screen is in 15 bits colors + 1 bit Alpha, but commands are using 24 bits color coding. The 24 bits color coding is used because it is the web standard. So GETPIX is reading the real 15 bits color and converting to 24 bits. The internal white #7fffH is converted to #f8f8f8H Here is a little program that display all colors Code: EXPORT SHOW_CLR() RE: GETPIX_P values - Graan - 01-24-2014 03:18 PM Thank you for the replies. I did not see this in the manual, but maybe its there. |
