wait(-1) kinetic scrolling - Printable Version
+--- Thread: wait(-1) kinetic scrolling (/thread-5074.html)
wait(-1) kinetic scrolling - fabila - 11-04-2015 12:36 AM
In a standard scrolling i get a list:
when i touch{0,x,x}, while scrolling {1,x,x}, when i stop touching {2}
in a kinetik scrolloing
when i touch{0,x,x}, while scrolling {1,x,x}, when i stop touching screen dont get nothing
How to identify a kinetic scrolling ?
sorry for my bad english
RE: wait(-1) kinetic scrolling - Tim Wessman - 11-04-2015 02:15 AM
Normally, you should not need to do so. What is happening with kinetic scrolling is that the system internally triggers a timer that counts down until stop. Scroll messages are sent until the timer runs out (with math to handle decreasing in a certain pattern as a function or initial velocity and length of the timer). As long as you are handling a scroll properly, nothing else is needed in your implementation. In fact, there is no where in the system that we've had a need to do any special handling on scrolling.
Is there a particular need or reason you feel you need a message at the end?
RE: wait(-1) kinetic scrolling - fabila - 11-04-2015 03:53 PM
I think there should be a pointer to start the kinetic scroll, to isolate and discriminate if its necessary.
Creo que es necesiario insertar un punto de control para el scroll cinetifoc para poder identificiarlo aislarlo y descriminarlos si fuese necesario.
Saludos.
RE: wait(-1) kinetic scrolling - Han - 11-04-2015 05:16 PM
(11-04-2015 12:36 AM)fabila Wrote:  In a standard scrolling i get a list:
Use MOUSE() in addition to WAIT(-1). Have WAIT(-1) detect if mouse events occur, and if so, use the MOUSE() command to determine kinetic scrolling.
  LOCAL key;
  // change run to 0 to exit the while loop
  key:=WAIT(-1);
  CASE
    IF TYPE(key)==6 THEN
      // we have touchscreen events
      CASE
        IF key(1)==0 THEN kmMouseDown(); END; // do kinetic scrolling here
        IF key(1)==1 THEN kmMouseUp(); END;
        // ... more mouse events
        IF key(1)==7 THEN kmMouseLongClick(); END;
        kmMouseEvent(); // default handler
    END; // end of touch events
    // at this point, all touch events were handled due to the
    // TYPE(key)==6 check; so only key-presses are left
    // and if a touch event occurred, these tests below are
    // never reached
    IF key==0 THEN kmDoAppsKey(); END;
    // ... more key definitions here
    IF key==50 THEN kmDoPlusKey(); END;
    kmOtherEvents(); // handle all remaining undefined keys
RE: wait(-1) kinetic scrolling - Carlos295pz - 07-25-2017 05:42 AM
It would be good that WAIT (-1) returns a "Mouse up" after completing the kinetic scrolling.
RE: wait(-1) kinetic scrolling - Tim Wessman - 07-25-2017 04:30 PM
Why? What would that be used for?
RE: wait(-1) kinetic scrolling - cyrille de brébisson - 07-26-2017 05:19 AM
From what I remember, there is one spot in the system where we do something special on Kinetic scroll, and I had to add some info (flag) to identify it, however, I do not remember the exact what/why. And this is, unfortunately, not user accessible. Sorry.
Cyrille
