CASIO fx-3600P scientific calculator from 1985 - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: CASIO fx-3600P scientific calculator from 1985 (/thread-5150.html) Pages: 1 2 |
RE: CASIO fx-3600P scientific calculator from 1985 - Csaba Tizedes - 06-04-2018 10:23 PM (06-01-2018 10:01 AM)xerxes Wrote:(05-31-2018 05:47 PM)Csaba Tizedes Wrote: I have one workable but not so good shaped CASIO fx-6300G. If inside I found a crystal oscillator, can I try to change it? Xerxes: the 3.2MHz is tested: turns on with only RESET and must to set the contrast. After that works, but if you turned OFF it can not to turn ON again, only with RESET. I wrote a little counter on it and measured the ~4× speed increase. After few RESET something went wrong and some trash generated in the program memory and after few OFF/ON cycle totally failed. I have removed batteries and I will soldering a little slower oscillator if I can find in our electronics store. Thanks for the tips, it seems to me this will works. The other project: I have dismantled my all CASIO fx this weekend and I decided I will speed-up my 3800P, because it has 220k resistor also on the motherboard and it has four program slot. I have calculated a good parallel resistor for it and I will use thermistor. With a little counter program stored in one slot I can measure temperature with my calculator, I need to calibrate only. Currently I need to measure the upper frequency limit, I will install a little 220k trimmer to find the limits of the calculator and I will install a few kOhms shift to set the maximal frequency and I will use a 100kOhm thermistor to measure temperature on the range 0°C ... +50°C. If I have any result I will post a new topic for that. Thanks again, Csaba RE: CASIO fx-3600P scientific calculator from 1985 - edryer - 11-22-2018 11:37 PM According to "Your Computer" (UK Magazine) December 1982... Quote:CASIO FX 3600P So this is actually a 1982 device originally... I am surprised as I also thought around 1984/1985, your model must be a later production version. At the time £22.95 was likely around $50.00. |
