Copy/clip - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Copy/clip (/thread-5158.html) |
Copy/clip - lrdheat - 11-18-2015 08:24 PM If I solve d/dx of some function, and then want to copy just the function, not the whole d(function)/dx statement to use elsewhere, how do I do this? Copy copies the whole line, can't figure out how to grab specific portion of line that I wish to use... RE: Copy/clip - Tim Wessman - 11-18-2015 08:55 PM (11-18-2015 08:24 PM)lrdheat Wrote: If I solve d/dx of some function, and then want to copy just the function, not the whole d(function)/dx statement to use elsewhere, how do I do this? Open it in the command line. Press COPY, you can then position the cursor and press begin/end to select specific areas. Or, hold down your finger for a bit and drag to select. RE: Copy/clip - CR Haeger - 11-18-2015 08:56 PM (11-18-2015 08:24 PM)lrdheat Wrote: If I solve d/dx of some function, and then want to copy just the function, not the whole d(function)/dx statement to use elsewhere, how do I do this? If you used d(function)/dx then want to go back and just copy the function, I copy the whole d(function)/dx to the command line then SHIFT COPY BEGIN END ESC SHIFT PASTE 1 ENTER. Sometimes its easier to just copy to the command line then backspace delete stuff you don't want. If I know that Ill be using the function more than a couple of times , Ill first define it (in CAS) using f(x):=function. Then, I can use d(f(x))/dx or f'(x) and still have f(x) handy and separate. There are probably other useful methods. |
