RCI and RCIJ [Solved] - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: RCI and RCIJ [Solved] (/thread-5301.html) |
RCI and RCIJ [Solved] - jrozsas - 12-09-2015 11:01 AM Hi! What is the function equivalent to RCI and RCIJ that exists in the 50 hp? The HP Prime manual there is nothing about it RE: RCI and RCIJ - DrD - 12-09-2015 11:26 AM There are several that might be applicable for a particular situation. Check the User Guide: search for Factorization, and in particular, the ref() and RREF() commands. -Dale- RE: RCI and RCIJ - jrozsas - 12-09-2015 11:45 AM (12-09-2015 11:26 AM)DrD Wrote: There are several that might be applicable for a particular situation. Check the User Guide: search for Factorization, and in particular, the ref() and RREF() commands.RCI and RCIJ has a particularity in the calculation matrix.HP 50 also has the ref and rref functions, in addition to rci and RCIJ RE: RCI and RCIJ - Didier Lachieze - 12-09-2015 01:16 PM (12-09-2015 11:01 AM)jrozsas Wrote: Hi! Have you checked SCALE and SCALEADD ? RE: RCI and RCIJ - jrozsas - 12-09-2015 01:34 PM (12-09-2015 01:16 PM)Didier Lachieze Wrote: Have you checked SCALE and SCALEADD ?Thanks Didier Lachieze! It is precisely this function that I need. |
