Built-in help for the function altitude [SOLVED] - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Built-in help for the function altitude [SOLVED] (/thread-5636.html) |
Built-in help for the function altitude [SOLVED] - JMB - 02-03-2016 08:08 PM Hello. I'd like to point out a mispelling in the built-in help for the function altitude (firmware 8151); the help says: "Given three non-collinear points, draws the of the triangle ..." I guess the word "altitude" in missing; the help should say: "Given three non-collinear points, draws the altitude of the triangle ..." RE: Built-in help for the function altitude - Tim Wessman - 02-03-2016 08:55 PM Thanks! RE: Built-in help for the function altitude - JMB - 04-29-2016 03:58 PM Corrected in firmware 10077. Thanks to the HP Prime Team! |
