Help with go41cx module loading on Nexus 5x? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Help with go41cx module loading on Nexus 5x? (/thread-5671.html) |
Help with go41cx module loading on Nexus 5x? - Bill Duncan - 02-12-2016 01:56 AM I recently was dragged into the twenty-teens by picking up a Nexus 5x replacing my blackberry bold.. I bought and loaded the hp15c emulator by hp.. Sweet. And bought the best hp41cx emulator I could find, which appears to be go41cx. Very sweet.. I'm having trouble figuring out a way to load modules however and I'd really like to load the advantage module. The go41cx system appears to be hardwired for an SD card (which the Nexus 5x does not have) at /go41cx/modules/. Has anyone got this to work? I've tried making a /go41cx directory and copying the module there, but no such luck.. RE: Help with go41cx module loading on Nexus 5x? - Bill Duncan - 02-12-2016 03:12 AM Found it. Searching through the archives I found another similar message. I moved the module to /Android/data/o2s.hp41cx/files/modules and it worked. Thanks Oliver for such great emulators! RE: Help with go41cx module loading on Nexus 5x? - boniholmes - 02-12-2016 09:08 AM Pardon my dumb question, where to get MOD and RAW files of those "classical" modules from? RE: Help with go41cx module loading on Nexus 5x? - boniholmes - 02-12-2016 09:24 AM I typed dumb as "dump". It must have been a Freudian slip/type. RE: Help with go41cx module loading on Nexus 5x? - Massimo Gnerucci - 02-12-2016 09:31 AM (02-12-2016 09:08 AM)boniholmes Wrote: Pardon my dumb question, where to get MOD and RAW files of those "classical" modules from? Start here (Sorry, can't make direct referral to [TOS URL] here...) RE: Help with go41cx module loading on Nexus 5x? - boniholmes - 02-12-2016 10:03 AM Hi Massimo, Thank you, I was able to download it from TOS. RE: Help with go41cx module loading on Nexus 5x? - Massimo Gnerucci - 02-12-2016 10:11 AM (02-12-2016 10:03 AM)boniholmes Wrote: Hi Massimo, You're welcome. Glad you found it quickly! |
