Carmichael Numbers (Updated 2/21/2016) - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Software Libraries (/forum-10.html) +--- Forum: HP Prime Software Library (/forum-15.html) +--- Thread: Carmichael Numbers (Updated 2/21/2016) (/thread-5691.html) |
Carmichael Numbers (Updated 2/21/2016) - Eddie W. Shore - 02-16-2016 02:05 PM Blog entry: http://edspi31415.blogspot.com/2016/02/hp-prime-carmichael-numbers.html Program (Updated 2/21/2016: I was mistaken on the definition of squarefree integers, the program is now corrected.) Code: EXPORT ISCARMICHAEL(n) The commands isprime and ifactors are generated from the CAS-Integer (Options 6 then 1 for isprime; option 3 for ifactors) submenu. However, I think in order for this program to work properly, the “CAS.” must be deleted and the command should be in all-lowercase. Introduction An integer n is a Carmichael number (1910) when the following holds: a^n ≡ a mod n (or for a>0 and n>0) a^n – integer(a^n/n) * n = a For all integers a. The program ISCARMICHAEL tests whether an integer n qualifies as a Carmichael number based on the Korselt’s Criterion: 1. n is a positive, composite integer. That is, n can be factored into a multiplication of prime numbers. 2. n is square-free. 3. For each prime factor p dividing n (not 1 or n), the following is true: (p-1) divides (n-1) evenly (without fraction). RE: Carmichael Numbers (Updated 2/21/2016) - C.Ret - 04-24-2020 06:18 PM Hello, I just compose a code for testing if a number n is a Carmichael Number. By inadvertence, I used exactly the same ifactors instruction. By using it, we don’t need to test if n is prime. The length of the vector produce by ifactors is exactly 2 for any prime number. A prime number always decomposes in the only one factor which is exactly itself. For example, ifactor(13) returns [ 13 1 ] This lead to a shorter code : Code: EXPORT IsCARMI(n) ISCARMI(561) returns 1 ISCARMI(2588653081) returns 1 ISCARMI(4991) returns 0 (is prime) ISCARMI(1.23) returns 0 (not integer) ISCARMI(-561) returns 0 (negative integer) |
