Can the Prime's serial number be recalled from internal memory? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Can the Prime's serial number be recalled from internal memory? (/thread-581.html) |
Can the Prime's serial number be recalled from internal memory? - veeblefester - 01-31-2014 11:40 AM Can one recall the serial number from internal memory of the Prime in hand? If so, how? Thanks in advance for any help. RE: Can the Prime's serial number be recalled from internal memory? - Miguel Toro - 01-31-2014 12:54 PM (01-31-2014 11:40 AM)veeblefester Wrote: Can one recall the serial number from internal memory of the Prime in hand? [Help], [Tree], touch twice on About HP Prime. or [On]+[Symb] and then very fast: [F]+[C]+[O]. The serial number is the bottom of the window. Regards, Miguel RE: Can the Prime's serial number be recalled from internal memory? - Tim Wessman - 01-31-2014 04:29 PM There is no equivalent to the SERIAL command on the 50g however. |
