TICKS incorrect on my 48SX? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: TICKS incorrect on my 48SX? (/thread-5861.html) |
TICKS incorrect on my 48SX? - jbhp55 - 03-12-2016 09:46 PM My HP48SX never returns a number over 4096 for TICKS. However, the clock time and date are fine. Is there a setting, or is this a sign something is wrong? Has anyone seen this before? The serial nr is 3109S00371. RE: TICKS incorrect on my 48SX? - Brad Barton - 03-13-2016 03:30 AM I've never had this problem, but TICKS is supposed to return a rather large binary integer equal to the system time. Are you using the command available in the TIME menu, or are you typing out the command? RE: TICKS incorrect on my 48SX? - Gerson W. Barbosa - 03-13-2016 03:45 AM Check your word size. RCWS probably will return 12. Change it to 16 or greater, up to 64: 16 STWS RE: TICKS incorrect on my 48SX? - Brad Barton - 03-13-2016 04:02 PM This is a great tip Gerson. I like how changing the word size automatically updates the results in the stack. They must be stored somewhere in full precision, because it up-samples values recorded under smaller word size settings. It also makes elapsed time calculations much simpler. Thanks! Brad RE: TICKS incorrect on my 48SX? - jbhp55 - 03-13-2016 07:03 PM Thank You, Gerson! This had solved my problem. I suspected it might be something like this, but there are clearly many more settings than are selected by flags. I'm gladit wasn't a problem in the hardware. Best regards, Jaap. RE: TICKS incorrect on my 48SX? - Dave Britten - 03-13-2016 07:44 PM (03-13-2016 04:02 PM)Brad Barton Wrote: This is a great tip Gerson. I like how changing the word size automatically updates the results in the stack. They must be stored somewhere in full precision, because it up-samples values recorded under smaller word size settings. The word size is mostly just a display setting, though I believe it may affect the behavior of shift/rotate operations, and interpretation of negative numbers. Contrast this with the 16C, where numbers are only stored and manipulated with as many bits as specified. RE: TICKS incorrect on my 48SX? - jbhp55 - 03-14-2016 10:05 AM In my case the elapsed time calculations went wrong, as soon as the elapsed time was more than 0.5 s. It seems the conversion B->R uses only the number in the stack, so if wordsize is 12, the resulting real is also never bigger than 4096. The stopwatch from the One Minute Marvels, for instance, does not work in that case. I wonder why the previous owner had set the wordsize to 12. |
