NaN message? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: NaN message? (/thread-6007.html) |
NaN message? - Tim O - 04-08-2016 08:32 PM I am trying to integrate the function f(x)=ln(2+sin(x)) from x=3 to 5 and I get NaN message. Can someone tell me why? RE: NaN message? - lrdheat - 04-08-2016 09:58 PM I get a complex answer in CAS, an invalid input message in HOME. Physical software version 7820, and same behavior on iPad emulator. RE: NaN message? - roadrunner - 04-08-2016 10:31 PM (04-08-2016 08:32 PM)Tim O Wrote: I am trying to integrate the function f(x)=ln(2+sin(x)) from x=3 to 5 and I get NaN message. Try this: ∫(ln(2+sin(x)),x,3.0,5) Note the 3 is typed 3.0 not just 3 Then you get about 0.555 for an approx answer. It's an approx/exact issue. -road RE: NaN message? - informach - 04-09-2016 02:03 AM Hi!, all: If configure HP PRIME, for CAS and in CAS Setting in Approximate mode, Standar mode with 12 digits, the result is ... 0.555085197181 In Plot, if any value, of function is <=0, the result is NaN (Not an Number). See, the attachment's in HP PRIME and Wolfram Alpha. |
