Voyager bezel removal - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Voyager bezel removal (/thread-6017.html) |
Voyager bezel removal - Harald - 04-10-2016 08:23 PM Thanks to "damaltor" I will have a new front for a quite worn 12c which I got off TAS. This gave me an old 12c front to play with. I have tried to remove the bezel from the old front (I have an 11c that I want to replace the bezel on as well), but I don't seem to be able to remove the bezel without either bending it, or applying too much heat and warping the plastic. Is there a way to keep both parts intact, or do I have to sacrifice the the plastic if I want to reuse the bezel? Cheers, Harald RE: Voyager bezel removal - Geoff Quickfall - 04-10-2016 08:29 PM Check out this: http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv019.cgi?read=153539 Geoff RE: Voyager bezel removal - Dave Frederickson - 04-10-2016 08:46 PM (04-10-2016 08:29 PM)Geoff Quickfall Wrote: Check out this: I am also interested in removing a Voyager bezel and I've examined the above thread. Quote: Removing the bezel is a long process that must be carefully done with precautions. It requires lots of heat so the LCD must be removed in the early two piece versions (HP-15 I don't think was ever the two piece PCA) or protection of the LCD panel with cloth. You will have to wait for the book for that! Until the book is released, a few more details would be greatly appreciated. Dave RE: Voyager bezel removal - Harald - 04-10-2016 09:07 PM Dave Frederickson Wrote:Until the book is released, a few more details would be greatly appreciated. I second that! Thanks for the link Geoff, I had already seen it. But it doesn't really answer the question wether the bezel can be removed without warping the plastic. I was lucky to have a bad case with a bad bezel to practice. I applied heat until I could lift the bezel without bending it, but the front case has not survived the procedure. Cheers Harald RE: Voyager bezel removal - Geoff Quickfall - 04-10-2016 09:45 PM The bezel in the post was removed from a totally destroyed 11c and added to the 10c without warping or destruction. A hair dryer was used as a heat source. I was not concerned with the donor case and applied sufficient heat to soften the glue completely and then remove the remove the bezel without concern to the styrene case. The condition of the bezel removed from the 10c was not a concern but the case was so, less heat was applied to that bezel. Granted the knife scarred the styrene case but since that was covered by the replacement bezel I was not concerned. With the good bezel removed I the resurfaced it with scotchbrite scouring pad. I cut cardboard to fit perfectly over the LCD panel lens. Then taped it in place to direct the heat away from the LCD and clear lens. However, if your bezel is not dented then removal is not a concern. Masking the case around the bezel, covering the LCD panel and applying parallel strokes with a scotchbrite pad will resurface the bezel. You may then Lacquer the cover when you have a satisfactory finish. Geoff RE: Voyager bezel removal - Harald - 04-11-2016 10:05 AM (04-10-2016 09:45 PM)Geoff Quickfall Wrote: The bezel in the post was removed from a totally destroyed 11c and added to the 10c without warping or destruction. Thanks Geoff, I'll let you know how I got on when I find a suitable donor... |
