Crashing HPprime with sequence APP - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Crashing HPprime with sequence APP (/thread-6127.html) |
Crashing HPprime with sequence APP - wawa - 04-24-2016 10:39 AM Hi I have found a way to crash the prime with the sequence APP (FW 10077). To do so: - Launch the Sequence APP - tap two times on the U1(N) label (not the entry field) and the calc reboots. Do you have the same issue on your own calc ? Nevertheless, I do love the possibility to define a sequence using a U(N+1)=f(U(N)) expression ! RE: Crashing HPprime with sequence APP - Arno K - 04-24-2016 11:00 AM Confirmed, so does the PC-emulator. Arno RE: Crashing HPprime with sequence APP - Tim Wessman - 04-25-2016 03:30 PM Thanks. On the list for correction. |
