Unable to update my prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Unable to update my prime (/thread-613.html) |
Unable to update my prime - Marcelo Vanti - 02-04-2014 05:20 PM Hi all, I followed the footsteps of hp conectivity kit to update the fimware to my new Prime, but it not worked for me. When the update starts, the calc disconnects from CK, and an error message (update failed (104)) is shown. The same thing occurs in all USB ports. The calculator remains in recovery mode and so I need to reset it. Please, any help is welcome RE: Unable to update my prime - Tugdual - 02-04-2014 08:53 PM I shall recommend that you try a different USB port. I was very surprised to have to use the docking port since the laptop USB would produce similar failures. I wonder if the docking is USB1 while the laptop is USB2. RE: Unable to update my prime - Tim Wessman - 02-04-2014 09:37 PM 1) have you updated the connectivity kit to the most recent 2013.11.25 version? 2) When the calculator goes into the update mode and you see the large HP logo, does your computer go through a long "installing driver" process that takes a long time? If it does, I assume it is not finishing before attempting to start the update process. You could try directly running the updater.exe from the install folder once the "installing driver" process has finished. As stated before, going through a hub can sometimes not work for some reason. Another port? RE: Unable to update my prime - Karl-Ludwig Butte - 02-05-2014 09:21 AM I had massive difficulties to update my Prime, too. In my case the problems were cuased by firmware files which were corrupted during the download from the Internet. Downloading the firmware again solved the problem. You may have a look at this thread, maybe it will help you, too. Best regards Karl RE: Unable to update my prime - Marcelo Vanti - 02-05-2014 01:39 PM Dear all, Thanks for the replies. Finally, I managed to update the Rom, just tried again on my home desktop. And this time, after I downloaded the new Rom with the conectivity kit, I did restart the computer, before update the calc. Marcelo RE: Unable to update my prime - FHSPSU67 - 02-09-2014 02:13 PM Had the same problems yesterday while trying to update the firmware on my new Prime. Many thanks to this thread and the other thread mentioned. In my case I finally solved the problem by using my Microsoft Surface Pro with Win 8.1 instead of my Win 7 desktop.I had tried both USB 2.0 and 3.0 on my desktop to no avail. RE: Unable to update my prime - MicroBeta - 02-09-2014 05:13 PM (02-09-2014 02:13 PM)FHSPSU67 Wrote: Had the same problems yesterday while trying to update the firmware on my new Prime. Many thanks to this thread and the other thread mentioned. In my case I finally solved the problem by using my Microsoft Surface Pro with Win 8.1 instead of my Win 7 desktop.I had tried both USB 2.0 and 3.0 on my desktop to no avail.Mine worked from my laptop which is also Win 8.1. Maybe it has problems with other versions of Windows. Mike |
