Badly corroded HP-41c - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Badly corroded HP-41c (/thread-6186.html) |
Badly corroded HP-41c - Dziugas2001 - 05-01-2016 01:27 PM Hello everyone, I have finally found a HP-41c in the wild. Unfortunately, it is badly corroded and I mean REALLY badly. Not only the flex cable for the battery is ruined, but the mainboard contacts are also completely destroyed. I wanted to ask you, could I just solder some balls to the mainboard and fix it? All answers are appreciated. RE: Badly corroded HP-41c - Didier Lachieze - 05-01-2016 01:56 PM You can take a look here, a nice solution from a forum member. RE: Badly corroded HP-41c - Dziugas2001 - 05-01-2016 01:59 PM Yeah, that looks like a good solution, unfortunately I don't know if the calculator works, so I just want to do it myself, because I like restoration projects like that. |
