units anomily - Printable Version
+--- Thread: units anomily (/thread-6201.html)
units anomily - roadrunner - 05-04-2016 05:47 PM
Version 10077, emulator
In CAS:
5_(°F)▶_(Rankine)
returns "Some units could not be converted to MKSA Error: Bad Argument Value"
convert(5_(°F),1_(Rankine))
While in home:
5_(°F)▶_(Rankine)
returns 464.67_(Rankine) OK
5_(°F)+5_(°F)
returns Error: Invalid input
CAS.(5_(°F)+5_(°F))
returns (10_(°F)) OK
It appears some unit operations are allowed only in CAS while other unit operations are allowed only in Home.
RE: units anomily - informach - 05-04-2016 07:30 PM
Hi!, roadrunner:
You can only CONVERT, for MKSA ... Meters, Kilograms, Seconds, Amperes.
Converts a complex unit, into the base components, of the MKSA system.
Example : MKSA(8.175_cm/s) returns .08175_m/s
Too, see ... http://en.hpprime.club/docs/reference/MKSA
For your example for added, in °F, (see image).
Kind Regards.
informach.
RE: units anomily - roadrunner - 05-04-2016 08:56 PM
Thanks for the reply informach,
I would have expected something as simple as units conversion to be easier than that on the Prime.
-road
RE: units anomily - compsystems - 05-05-2016 03:10 AM
Hi, the following code is compiled successfully, but not run in HOME MODE. why?
#cas
  test():=
    return 5_°F+5_°F;
#end
CAS MODE VIEW
test() [ENTER] 10_°F
HOME MODE VIEW
test() [ENTER] program({},{},{RETURN 10_(°F)}) ??
Because when you enter the function [VAR] [CAS] does not automatically add the parentheses?
test [ENTER] (NULL)->BEGIN RETURN(5_(°F)+5_(°F)); END;
default should automatically place the brackets, otherwise placed on the history the program source code =[
test()
RE: units anomily - cyrille de brébisson - 05-05-2016 05:51 AM
Hello
Unit conversion are anything BUT simple (unfortunately).
The problem of °C and °F set aside, the 'sto' shortcut as in 1_m▶_cm is quite simple and pretty much to the point with very few keystrokes (considering the possibility range of Prime).
Now, working with °C and °F, this is a whole other can of worms.
°C and °F are not technically units. This is because they are not 0 based. ie, 0°C does not denote the absolute 0 with negative units denoting anti-heat.
This is where the problem lies.
This means that 1°C is not (always) equal to 1°C.
If I say: the temperature is 1°C, I mean by that that the temperature is 247K
When I say the temperature change is 1°C, I mean that the temperature change is 1K
But, the calculator does not get the context. When you tell it to convert 1°C to °F or K, it does not know if the 1°C is the result of a previous subtraction or an 'absolute' temperature.
Bernard, in the the CAS has decided that no serious (real life) math/physics calculations will/should use °C and °F, and is basically banning them. It is a defendable position, which makes sense, and which also makes the software developer life much much easier.
In home, we recognized that some users would want to do some computation on °C and °F, so we did some extra work to allow, with restrictions, in order to reduce the occurrences of "vitum pillum" (pig latin for "javelot in foot", (sorry I forgot the declination), or, as we would say in modern english: shooting oneself in the foot).
But it still fall short of expectations, due to the problem mentioned above, the calculator can not know, when you use 1°C if this is 0 based, or 246°K based.
Cyrille
RE: units anomily - Thomas Radtke - 05-05-2016 01:32 PM
(05-04-2016 05:47 PM)roadrunner Wrote:  It appears some unit operations are allowed only in CAS while other unit operations are allowed only in Home.
Most has been said already by Cyrille. I'd like to add a tiny bit out of the real world: In e.g. refrigeration engineering, where I work, you are required to express differences in Kelvin. No idea how the Prime handles this, but you should be able to add 5K to 5°F.
RE: units anomily - informach - 05-05-2016 02:58 PM
Hi!, Thomas Radke:
Today, is impossible, in HP PRIME directly.
You must program for allow result.
In Wolfram Alpha, you have the conversion (see image).
You have a single formula, for create program ...
T(°F) = T(K) × 9/5 - 459.67
Kelvin to Fahrenheit
K = 5/9 * (F - 32) + 273.15
King Regards.
informach.
RE: units anomily - Fortin - 05-06-2016 02:32 AM
I'm assuming you want a 5K change starting at a temp of 5°F with the final result expressed in °F. To do this, all temp units must first be converted to K so that they have a common zero reference.
(CONVERT(5_°F,0_K)+5_K)▶_°F
RE: units anomily - roadrunner - 05-06-2016 01:55 PM
(05-05-2016 05:51 AM)cyrille de brébisson Wrote:  Unit conversion are anything BUT simple (unfortunately)
Indeed, when I used the word “simple,” that was my naiveté speaking. About the rest: understandable and reasonable.
On a side note, my 48SX thinks 5_°F + 5_°F is 469.67_°F. At least the prime gets that right.
-road
RE: units anomily - informach - 05-06-2016 02:25 PM
Hi!, roadrunner:
In Hp48/49/50 series, the convertion's, are incompatible, the K to °F and viceversa.
And your example, to 5_°F+5_°F isn't ... 469.67_°F.
The correct result, is ... 10_°F
Kind Regards.
informach.
RE: units anomily - Claudio L. - 05-06-2016 10:06 PM
For the interested, there was a recent thread discussing these issues and possible solutions:
http://www.hpmuseum.org/forum/thread-4783.html
RE: units anomily - Joe Horn - 05-07-2016 05:14 PM
(05-06-2016 01:55 PM)roadrunner Wrote:  On a side note, my 48SX thinks 5_°F + 5_°F is 469.67_°F. At least the prime gets that right.
(05-06-2016 02:25 PM)informach Wrote:  In Hp48/49/50 series, the convertion's, are incompatible, the K to °F and viceversa.
Please note that the logic of temperature arithmetic is different between the 48S/SX and 48G/GX. Roadrunner is correct that the 48SX says that 5_°F + 5_°F is 469.67_°F. The 48G/GX agrees with Informach, saying that 5_°F + 5_°F is 10_°.
RE: units anomily - Paul Berger (Canada) - 05-07-2016 06:33 PM
(05-06-2016 02:25 PM)informach Wrote:  Hi!, roadrunner:
Kind Regards.
informach.
I can confirm that a 48SX does indeed return 469.67_°F, it would seem that it messes up the units but not in an entirely random manner because 5_°F is 464.67_°R so it would seem that for some reason it converts to °R to make the calculation but does not convert back, 469.67_°R = 10°F
It does a similar thing with °C but converts to Kelvin in that case, adding degrees Rankine or Kelvin work as expected.
Paul
RE: units anomily - roadrunner - 05-07-2016 07:41 PM
Paul,
Internally it converts 5_°F to 464.67_°R, then adds 464.67_°R + 464.67_°R to get 929.34_°R then converts 929.34_°R back to 469.67_°F.
Once I lost more than a couple points on a homework assignment because of that anomaly. Those were the good ol' days.
-road
