Fun little math problem - Printable Version
+--- Thread: Fun little math problem (/thread-6228.html)
Pages: 1 2
Fun little math problem - David Hayden - 05-09-2016 07:24 PM
I was at a high school reunion this weekend and former teacher of mine gave me this little gem. It isn't hard to solve, but it's interesting that there is exactly one solution.
Find two positive numbers such that:
  1. Adding them produces the same number as multiplying them
  2. Subtracting them produces the same number as dividing them (although a different number from above)
  3. Their difference is less than 1.
RE: Fun little math problem - Gerson W. Barbosa - 05-09-2016 08:29 PM
1+sqrt(2), 1+(sqrt(2))/2
RE: Fun little math problem - Tugdual - 05-09-2016 10:00 PM
I also have \(1-\frac { \sqrt { 2 } }{ 2 } \) and \(1-\sqrt { 2 } \)
Thanks 50G Smile
Ooops sorry it was said positive numbers. Only one solution then.
RE: Fun little math problem - BarryMead - 05-10-2016 09:17 AM
(05-09-2016 08:29 PM)Gerson W. Barbosa Wrote:  1+sqrt(2), 1+(sqrt(2))/2
I think you misplaced a parenthesis, and that you meant to say
1 + sqrt(2), 1 + (sqrt(2)/2)
I admit that the operator precedence rules for most computer languages would perform the division operation before the addition operation anyway, but I think most people would agree that the meaning is more clear if the parentheses are arranged as shown in the second example.
Take Care, Barry Smile
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 11:11 AM
I admit that most machine code parsing algorithms would perform the division operation before the addition operation anyway, but I think most people would agree that the meaning is more clear if the parentheses
Actually only one pair of parentheses would have been enough: 1 + sqrt(2)/2. But redundant parentheses wouldn't hurt: (1+((sqrt(2))/2)) Smile
This is better: \(1+\frac { \sqrt { 2 } }{ 2 } \)
Gerson.
RE: Fun little math problem - Paul Dale - 05-10-2016 11:14 AM
Gerson,
Quote the reply and see how it is done. Then create your own response.
\(1+\frac 1 { \sqrt { 2 } } \)
Pauli
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 11:19 AM
(05-10-2016 11:14 AM)Paul Dale Wrote:  Gerson,
Pauli
Thanks! I'd just figured that out and edited my reply before I saw your post.
This used to work in the old forum and still does :-)
Gerson.
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 11:31 AM
(05-09-2016 10:00 PM)Tugdual Wrote:  I also have \(1-\frac { \sqrt { 2 } }{ 2 } \) and \(1-\sqrt { 2 } \)
Thanks 50G Smile
I didn't take a 50g for this one, but I did use the wp34s to solve a quadratic equation:
1 ENTER 2 +/- 1 +/- SLVQ --> 2.41421356237 x<>y --> -.414213562373⁻¹
Gerson.
RE: Fun little math problem - David Hayden - 05-10-2016 03:08 PM
Thanks for playing folks. It's interesting to graph to two functions also. You'll see that there is a limit to the solution at (0,0). Hmm. I'm sure I have the terminology wrong there, but the x+y=x*y has a solution at (0,0) and x-y-y/x = epsilon as x,y approach 0 (for the right small values of x&y)
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 05:07 PM
(05-10-2016 03:08 PM)David Hayden Wrote:  Thanks for playing folks. It's interesting to graph to two functions also. You'll see that there is a limit to the solution at (0,0). Hmm. I'm sure I have the terminology wrong there, but the x+y=x*y has a solution at (0,0) and x-y-y/x = epsilon as x,y approach 0 (for the right small values of x&y)
Nice little problem. Thanks for posting! It reminds me of another one, worked-out allegedly in half a minute by a 14-year old student, about one hundred years ago:
\(\left \{ _{\sqrt{y}+x=11}^{\sqrt{x}+y=7} \right.\)
No ordinary student, though.
Gerson.
RE: Fun little math problem - damaltor - 05-10-2016 05:22 PM
These are too easy if you sit in front of a computer. Big Grin
[Image: gif&amp;s=30]
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 06:11 PM
(05-10-2016 05:22 PM)damaltor Wrote:  These are too easy if you sit in front of a computer. Big Grin
Neither computer nor calculator needed, at least for the previous one:
[Image: 26903769166_71d1f9c958_b.jpg]
RE: Fun little math problem - Tugdual - 05-10-2016 06:58 PM
Gerson.
I could NUM.SLV it but no chance with CAS on the 50g, keeps saying "not exact system" whatever this means...
RE: Fun little math problem - Gerson W. Barbosa - 05-10-2016 08:22 PM
(05-10-2016 06:58 PM)Tugdual Wrote:  I could NUM.SLV it but no chance with CAS on the 50g, keeps saying "not exact system" whatever this means...
What are your initial guesses? Starting with [1. 1.] the answers are found in 23 seconds. [0. 0.] gives me "- Error: Negative Underflow".
Gerson.
RE: Fun little math problem - Massimo Gnerucci - 05-10-2016 08:25 PM
Do you really need a calc for this one?
RE: Fun little math problem - Tugdual - 05-10-2016 09:13 PM
Gerson.
I used [5 5] and it does work for NUM.SLV but the error is returned with the standard SOLVE.
(05-10-2016 08:25 PM)Massimo Gnerucci Wrote:  Do you really need a calc for this one?
Why not? This is kind of a cal forum here...
RE: Fun little math problem - Massimo Gnerucci - 05-10-2016 09:43 PM
Of course you may, but do you use one when you see 1+2+3=?
RE: Fun little math problem - Paul Dale - 05-10-2016 10:45 PM
(05-10-2016 05:07 PM)Gerson W. Barbosa Wrote:  \(\left \{ _{\sqrt{y}+x=11}^{\sqrt{x}+y=7} \right.\)
I got the answer without a calculation aid in well under thirty seconds.
I'm several times 14 though.
Pauli
RE: Fun little math problem - Dieter - 05-11-2016 06:31 AM
(05-10-2016 10:45 PM)Paul Dale Wrote:  I got the answer without a calculation aid in well under thirty seconds.
How did you do it?
I have to admit I only got a (very) quick-and-dirty solution: Since x=(7–y)² and y=(11–x)² I assumed x and y to be the squares of integers, i.e. 4 or 9 or 16, etc. A simple substitution yields 22x – x² – sqrt x = 114. Omitting the root as the smallest term yields x = 11 ± sqrt 7, i.e 8,35 and 13,65. So two candidates are 9 and 16. I first tried x=9, et voilà... #-)
Dieter
RE: Fun little math problem - Paul Dale - 05-11-2016 07:57 AM
(05-11-2016 06:31 AM)Dieter Wrote:  How did you do it?
I figured the missing values were integers & it was then clear that they must be small. There were not a lot of options left: 2 & 4, 3 & 9, 4 & 16. I got it right first go after this.
Pauli
