Connect two Prime - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Connect two Prime (/thread-6232.html) |
Connect two Prime - salvomic - 05-11-2016 12:50 PM hi everybody, I know that the answer would be "definitely NO", but I wonder: is there some thing to do to connect a Prime version C with another version A to clone or pass data without CK? I've the cable, but in the Prime C I can see (Mem) the softly "clone" and "send", but not in the Prime A (see image)... Thank you Salvo UPDATE: I tried to invert the cable and "clone - send" appeared on the calc A... Then inverted the cable (from C to A) I sent a note (2 kb) from calc C to calc A but in the calc A the note wasn't received... RE: Connect two Prime - cyrille de brébisson - 05-12-2016 04:49 AM Hello, You should be able to connect a A and a C together, assuming that the C is the usb host... You should then be able to send data either way... Now, for the sent data to be received and work, you need the 2 calcs to have compatible firmware. Cyrille RE: Connect two Prime - salvomic - 05-12-2016 07:41 AM (05-12-2016 04:49 AM)cyrille de brébisson Wrote: Hello, hi Cyrille, I was able only to receive data in C from A and not vice versa (also inverting the A-B cable)... Salvo RE: Connect two Prime - BERNARD MICHAUD - 05-16-2016 11:39 PM I have the two calculators, version C and A, I send data back and forth between them without any problem. However if when I connect them SEND appears only on one of them, you cannot send from either one. keep the calculators connected and do a reset in the back of both calculators with a pin and let them reboot. This does not affect your programs or notes. After they have rebooted both calculators have the SEND active when the program lists is called. (Shift - Program). Works for me, hope it works for you. RE: Connect two Prime - salvomic - 05-17-2016 06:15 AM (05-16-2016 11:39 PM)BERNARD MICHAUD Wrote: I have the two calculators, version C and A, I send data back and forth between them without any problem. However if when I connect them SEND appears only on one of them, you cannot send from either one. keep the calculators connected and do a reset in the back of both calculators with a pin and let them reboot. This does not affect your programs or notes. After they have rebooted both calculators have the SEND active when the program lists is called. (Shift - Program). Works for me, hope it works for you. Thank you Bernard! I wonder if they works in this way as a feature or ...a bug ![]() However I'll try it. Salvo RE: Connect two Prime - Maro - 05-18-2016 02:58 PM (05-16-2016 11:39 PM)BERNARD MICHAUD Wrote: I have the two calculators, version C and A, I send data back and forth between them without any problem. However if when I connect them SEND appears only on one of them, you cannot send from either one. ... with my version A and C it works fine (back and forth, both units) and SEND appears on both calculators: plug in the Micro A end of the USB cable into Prime version C and the Micro B end into Prime version A. Then with both Primes off switch on only Prime C and both units will power up and SEND will show up on each unit. (Prime A and C Software version 2016 04 14, 10077) RE: Connect two Prime - salvomic - 05-18-2016 03:12 PM thank you! now it worked here with Notes! I had to invert the cable, insert the A (is it the part with rectangular connector, isn't it?) in the C Prime and the B in the other (here the "trapezoidal connector" with two little holes...), then switch on only the C and so on... Salvo RE: Connect two Prime - Maro - 05-18-2016 03:23 PM yes, look here: http://www.hpmuseum.org/forum/thread-477.html?highlight=USB+cable |
