Symbolic assumption - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: Not HP Calculators (/forum-7.html) +--- Forum: Not remotely HP Calculators (/forum-9.html) +--- Thread: Symbolic assumption (/thread-6256.html) |
Symbolic assumption - rsfjr - 05-16-2016 06:08 AM Hello all! I wish to know if anyone knows how to (or if it is possible) to set the assumption of a symbolic variable within the TI NSPIRE CAS CX? All the best RE: Symbolic assumption - roadrunner - 05-17-2016 01:45 AM There is a constraint operator, but it's not as powerful as the assume() command of the Prime. Have you asked here: http://tibasicdev.wikidot.com/forum:home RE: Symbolic assumption - rsfjr - 05-18-2016 08:17 PM (05-17-2016 01:45 AM)roadrunner Wrote: There is a constraint operator, but it's not as powerful as the assume() command of the Prime. Thanks for the reply. I tried there and no response. I have tried, it looks like that the constraint operator is like in math |. But I need to invoke it every time I call an expression. All the best Ronaldo |
