selecting text - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: selecting text (/thread-6325.html) |
selecting text - roadrunner - 05-30-2016 11:00 AM On the handheld prime running the older versions, in the program editor, one could touch and hold for a second, then drag to select text. With version 10077 that action either does nothing or scroll the text, depending on what is displayed and the direction of the drag. I tried holding for various amounts of time from as short as I could muster to 5 or so seconds with the same results. The emulator running 10077 selecting text still works by left click, hold, then drag. It's only the physical handheld device that seems to have lost this ability. 1. Has anyone else noticed this; 2. Is there a new technique to achieve the same result, or; 3. Are my fingers just to fat? -road RE: selecting text - John Colvin - 05-30-2016 08:10 PM Works fine with my Prime and I am using 10077. RE: selecting text - CH3791 - 05-31-2016 12:46 PM Same, I am using 10077 and it works. RE: selecting text - roadrunner - 05-31-2016 04:16 PM Thanks guys, It must be my fat fingers. I'll use begin and end on the copy menu from now on. -road RE: selecting text - Fortin - 05-31-2016 11:07 PM Out of curiosity, are kenetic scrolling and long hold menu selection still working? Have you tried an On+Symb restart? RE: selecting text - roadrunner - 06-01-2016 12:16 AM I just tried on + symb and that fixed it. Thanks, Fortin. Kinetic scrolling and long hold menu items were also not working, but now everything is OK. -road |
