Power off broken? - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Power off broken? (/thread-639.html) |
Power off broken? - massimo - 02-08-2014 07:40 PM Last night my Prime has shown a strange behavior. Immediately after switching off, the calculator turned on right away. After several attempts with different resets, I solved by formatting the memory of calculator. Someone else had the same problem? Massimo RE: Power off broken? - Tugdual - 02-08-2014 08:31 PM Probably the calculator knows you love it, and now it doesn't want to leave you any longer ;-) Dont' remember witnessing that glitch. RE: Power off broken? - massimo - 02-08-2014 08:42 PM Can be! Perhaps the calculator is jealous of other technological gadgets and wants to control me. Anyway now it is fine. RE: Power off broken? - Han - 02-08-2014 09:12 PM Was it plugged via USB when this was happening? RE: Power off broken? - didier.gosseau - 02-09-2014 05:04 PM Dear Massimo, How to you do to format the memory? I have another strange behavior. The keyboard does not react anymore as it should. When a press SHIFT MEM, my PRIME enters in reset mode instead of displaying the memory. Normal reset procedure does not help. RE: Power off broken? - massimo - 02-09-2014 05:24 PM (02-08-2014 09:12 PM)Han Wrote: Was it plugged via USB when this was happening? Probably it started when plugged but it continued when the calc was unplugged. RE: Power off broken? - massimo - 02-09-2014 05:35 PM (02-09-2014 05:04 PM)didier.gosseau Wrote: How to you do to format the memory? I used the diagnostics menu. I activated pressing the reset on the back of the calc (using a clip) and pressing 'C' 'F' 'O'. Then I choosed the FLS Utility from the menu. You can find more info into the forum. |
