Math/Stat pac - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: Math/Stat pac (/thread-6419.html) |
Math/Stat pac - student - 06-16-2016 08:22 PM Does the Math/Stat pac combine the routines in the Math pac and the Stat pac? Thanks RE: Math/Stat pac - Dieter - 06-16-2016 08:44 PM (06-16-2016 08:22 PM)student Wrote: Does the Math/Stat pac combine the routines in the Math pac and the Stat pac? If you refer to the HP41 Math/Stat ROM module: yes, it does. In my case the box included one module and two separate manuals, one for the Math Pac and one for the Stat Pac. Dieter RE: Math/Stat pac - student - 06-16-2016 09:25 PM Thanks for clarifying . RE: Math/Stat pac - student - 06-16-2016 09:27 PM So the math/stat pac was an improvement on the situation of two separate pace? RE: Math/Stat pac - Sylvain Cote - 06-16-2016 09:52 PM (06-16-2016 08:22 PM)student Wrote: Does the Math/Stat pac combine the routines in the Math pac and the Stat pac? The Math/Stat module is simply a module repackaging of the initial Math and Stat modules. Code: 00041-15002 STATISTICS PAC Code: 00041-15003 MATHEMATICS PAC Code: 00041-15049 MATH/STAT PAC RE: Math/Stat pac - student - 06-16-2016 10:56 PM Thanks. And are these the only overlays in that math/stat pac: [attachment=3680] (May also be seen at http://www.enterhp.com/images/41c_math_overlay.JPG) RE: Math/Stat pac - Massimo Gnerucci - 06-17-2016 06:09 AM (06-16-2016 10:56 PM)student Wrote: Thanks. And are these the only overlays in that math/stat pac: Yes, they are. RE: Math/Stat pac - Namir - 06-17-2016 01:22 PM I remember when my friend Jim DeArras took a MATH Pac ROM and STAT pac ROM, combined them into one module. I was amazed that they worked together! That module remained in my HP-41CX until 1999. One day that year, I had my 41CX at work and spilled coffee on it by accident. The calculator would not turn on, I decided that it was dead and I tossed the calculator with the dual MATH/STAT module, Advantage module, X-Memory modules in the trash can!!! Little did I know that there was a market for the machine. I learned that later in 2001, when I started buying HP calculators from that auction site. I was a bit surprised to eventually learn that HP itself sold the MATH and STAT pac ROMS combined. Now I own several copies of that dual ROM. Namir RE: Math/Stat pac - student - 06-17-2016 02:12 PM Thank you Massimo for the clarification, and thank you Namir for sharing your experience. I just acquired a refurbished HP 41CX and a used math/stat pac (in working order). So I'll probably be coming up with more questions of the simple kind as I work my way through. RE: Math/Stat pac - Massimo Gnerucci - 06-17-2016 02:22 PM (06-17-2016 02:12 PM)student Wrote: Thank you Massimo for the clarification, and thank you Namir for sharing your experience. You are welcome. The 41 is my preferred calc. :) |
